Fury -Wilder 3?
by pbm - 02/23/20 06:41 AM
toro super recycler
by passgas55 - 02/23/20 06:05 AM
Chain style for ag tires
by puma4440 - 02/23/20 04:25 AM
2014 GMC Terrain 2.4L AWD
by Char Baby - 02/23/20 02:06 AM
Conventional VS Synthetic In The Winter Months
by BlueOvalFitter - 02/23/20 01:36 AM
Paint Splatter
by rrretiree7 - 02/23/20 12:54 AM
The Jeep Made it to 150k Miles - Storytime
by Nick1994 - 02/23/20 12:54 AM
Supertech vs Dexcool
by WA1DH - 02/22/20 11:44 PM
Spark plug gap f
by Rohan - 02/22/20 10:28 PM
Mad mike hughes.rip
by Chris142 - 02/22/20 10:15 PM
MTF drain = chocolate milk
by Texasdoc - 02/22/20 10:02 PM
New Valvoline looks promising?
by kr_bitog - 02/22/20 08:45 PM
rock like debris in generac generator 17kw
by jb5150 - 02/22/20 08:25 PM
FL820S C&P BAD GLUE JOB
by naterbomb - 02/22/20 08:21 PM
Photo Uploader Not Working
by ZeeOSix - 02/22/20 07:49 PM
Faulty clutch master cylinder 17” Honda Civic
by parshisa - 02/22/20 07:33 PM
Ford drain plugs
by buck91 - 02/22/20 07:09 PM
What's the greatest amount of miles you've heard of someone
by Speak2Mountain - 02/22/20 05:53 PM
Oil Jug - Leaking
by MasterSolenoid - 02/22/20 05:40 PM
Which one
by tiger862 - 02/22/20 05:05 PM
Chaucha, UofA, Jeffrey78, Markovchain, o_s
70787 Registered Users
81 registered members (55hambone, 4WD, 53' Stude, Aero540T, aba4430, 2010Civic, 6 invisible), 1,767 guests, and 19 spiders.
Topics301,818
Posts5,203,279
Members70,787
Brake Surge - Lexus #5166766 07/20/19 08:55 PM
M
MaximaGuy Offline OP
M
Experiencing brake surge from my Lexus ES, it has OEM front pads and OEM rotors.
The pads have 20K miles on them and unhappy with the surge.
Any recommendations of good non-OEM pads for Lexus (front heavy vehicle) - will flush the lines along with the change!!!
2018 MB GLE350
2011 Lexus ES350
2006 Toyota Highlander 4WD
Re: Brake Surge - Lexus [Re: MaximaGuy] #5166800 07/20/19 09:31 PM
The Critic Offline
Brake surge?
2011 Toyota Prius 1.8L - 203K - Valvoline Premium Blue Restore 10W-30
2007 Honda Accord 2.4L - 143K - Valvoline Premium Blue Restore 10W-30
Re: Brake Surge - Lexus [Re: The Critic] #5166802 07/20/19 09:33 PM
K
kschachn Online Content
Online Content
K
I was kind of wondering about that myself.
1994 BMW 530i, 251K
1996 Honda Accord, 280K
1999 Toyota Sienna, 430K
2000 Toyota ECHO, 284K
Re: Brake Surge - Lexus [Re: MaximaGuy] #5166803 07/20/19 09:34 PM
gathermewool Offline
+ 1 Brake surge?
What ever happened to the fine art of actually describing a problem in more than three lines?
14 Forester XT Touring FA20DIT (Cobb Stage 1)
Castrol Magnatec 5W-30 D1G2 + FU filter (72,320mi, 8/24/19)
15 Legacy Premium FB25
Magnatec 5W-20 + FU filter (47,300mi, 5/11/19)
Re: Brake Surge - Lexus [Re: MaximaGuy] #5166810 07/20/19 09:48 PM
M
M
Brake Surge - when braking at > 60 MPH the vehicle lunges ahead when the brakes are applied much like the pads don't have the bite.
Checked the rotors and there isn't any scoring that is obvious to the eye or touch.
2018 MB GLE350
2011 Lexus ES350
Re: Brake Surge - Lexus [Re: MaximaGuy] #5166813 07/20/19 09:55 PM
K
Online Content
K
Interesting, I don't think I've ever had that happen where the vehicle lunges forward on brake application. I have no idea what would cause that.
1994 BMW 530i, 251K
Re: Brake Surge - Lexus [Re: MaximaGuy] #5166817 07/20/19 09:58 PM
The Critic Offline
Sounds like a lack of bite. Either the pads/rotors are glazed or the slide pins are stuck. The pin with the bushing tends to get swollen on that caliper design.
Re: Brake Surge - Lexus [Re: MaximaGuy] #5166840 07/20/19 10:24 PM
L
Lolvoguy Offline
L
I'd make sure I'm not accidentally pressing the gas with the brake at the same time.
Aside from that it's almost impossible for that to occur.
06 Lexus IS350- Wife
88 BMW 325is- Mistress
Say "no" to Turbo!
Re: Brake Surge - Lexus [Re: MaximaGuy] #5166856 07/20/19 11:33 PM
R
Reddy45 Offline
R
This is bizarre, but if you believe the pads are at fault, then my only recommendation is to avoid ceramic pads, and possibly to go with semi-metallic ones.
Ceramic pads have less initial bite upon braking, but tend to create less dust.
Semi metallic are dirty, but grab well.
Re: Brake Surge - Lexus [Re: MaximaGuy] #5166885 07/21/19 01:55 AM
R
rubberchicken Offline
R
Perhaps the last time pads were installed, they were high performance track pads, racing pads etc. ? Those pads tend to not develop much grip when they are cold- they require a bit of a heat cycle before they start working well. If you replace the brakes, use a formulation specific for street use.
Example- Hawk HP+ pads are the entry level to motorsport pads, but were also popular for sporty cars on the street. The initial bite is not the same as OEM pads. Same for EBC Orangestuff pads- more of a race pad than a street pad.
Re: Brake Surge - Lexus [Re: MaximaGuy] #5166967 07/21/19 06:57 AM
A
Audios Offline
A
Its posssible the inner face of the rotor is glazed or rotting away, the dust shield can trap moisture and cause the inner side only to rot. Ive always like Akebono for their low dust and decent initial bite. Otherwise OE dusty pads will offer great initial bite.
2002 VW Golf TDI-T5 10/30
2007 Mercedes GL320 CDI-T6 5/40
2005 BMW M3 BMW-Twin Power 10/60
2003 BMW M5-M1 15/50
1998 BMW M3/4/5-M1 10/40
Re: Brake Surge - Lexus [Re: MaximaGuy] #5167028 07/21/19 07:55 AM
E
eljefino Offline
E
Mechanical problem like sticking pins. Hard to hit the highway without a few stops to warm the pads up.
Re: Brake Surge - Lexus [Re: MaximaGuy] #5167071 07/21/19 08:41 AM
M
M
Thanks all for your feedback. These are the steps I am going to use to correct this behavior (vehicle has 87K on the odometer)
a) Remove the rotors and check for glazing - if glazed put front on stands and run the car and use 320 sand paper to sand the front and back surfaces of the rotor
b) Remove the slide pins and check they float, clean the boot and grease cleanly and they install with new grease. Check the boot on the pin.
c) Check the pads for wear and flush the lines whiles the wheels are off.
I intend to preserve my rotors since my Highlander rotors are still going strong w/ 200 K on it.
2018 MB GLE350
2011 Lexus ES350
Re: Brake Surge - Lexus [Re: MaximaGuy] #5167074 07/21/19 08:43 AM
G
gman2304 Online Content
Online Content
G
My wife’s es350 has “touchy” brakes. I rarely drive her car but the slightest touch seems way too sensitive for my tastes with no brake feel. She says the brakes are fine so I leave it alone. Don’t get me started on the numb electric steering and “go, no go and nothing in between” throttle. I hate that car but she drives it and loves it, so we’re good.
Re: Brake Surge - Lexus [Re: MaximaGuy] #5167075 07/21/19 08:44 AM
R
Rand Offline
R
When making up names for braking issues you might want to describe them, also there is no way for the vehicle to "surge" ahead when braking..(unless you hit the gas)
and there is a piece of equipment called a Surge Brake.. so probably not the best name.
I'd agree though it sounds like a mechanical issue... I would tear them down and inspect.. plan on having transportation available to go buy parts... or if your brakes are old maybe preorder some pads and rotors online for cheapness.
Regardless it sounds like a serious safety issue so you might want to park it.
