Would you spend the money on OEM parts on a vehicle that is 9 years old and has a quarter million miles on it?
I did last week, front rotors and pads, shims for my 2015 Lexus RX350. This was the second brake job on the front that I've done on it, the first I chose to use the PowerStop OE rotors and pads. I'm done with brake components from that company. I have had absolutely horrible service from anything from Powerstop. I put the premium Z23 rotors and pads on my Tundra and they didn't make it 40k miles before the vibration was just too much.
I spent about $100 more in Toyota OEM parts than the Powerstop package of rotors and pads. The Powerstop stuff on the RX350 didn't make it 35k miles before the pulsation was just too much. Now the car has pretty much brand-new factory fresh brake components all the way around. I rebuilt the front calipers 35k miles ago, every seal/etc on them looked brand new at 190k miles. I was impressed. Saturday I do as I always do, wire brush the daylights out of the hub, wire brush the pad bracket, clean the caliper pin sockets with brake clean and booger-remover paper towel rolled up and shoved down in there, clean the pins and re-grease with a light coat of Sylglyde. I use the Toyota grease on the backs of the pads. Did the rears about 4 months ago with all OEM rotors and pads and same procedure. I always flush the fluid before beginning a brake job and then do a couple of bleeds after the pads are in.
Better than 99% of the shops out there are going to do.
