Originally Posted by Sayjac
'Ime' and observation louvers are punched/opened/facing in two directions half facing dome end and half facing thread end. Thus half the openings may not 'always' be ascertained merely by looking down the centertube.
Yep, every louvered center tube I've looked at has louvers pointing in both directions. IMO, if the openings facing the base are seen to be formed well, then it's pretty much a given the ones facing the dome end will be formed the same. If you can see the media through the louvers while looking through the base end, then I'd say all is well. If they look almost closed up like shown in the photos, don't use it.
