Brake pads and rotors
by mobilaltima - 12/12/19 12:26 AM
This oil looks interesting but not avail in US
by jkhawaii - 12/11/19 10:39 PM
Castrol Engine Shampoo (Oil Flush)
by adams355 - 12/11/19 10:03 PM
How Dumb can she get #2
by KeithS_NW_Ohio - 12/11/19 09:45 PM
Dodge Transmission
by Butterbean - 12/11/19 09:38 PM
Pay Raise
by KeithS_NW_Ohio - 12/11/19 09:17 PM
Mid-size SUVs for exploring/DD
by AZjeff - 12/11/19 09:05 PM
3.5 Ecoboost issues solved for 2018?
by JLTD - 12/11/19 08:30 PM
14 Grand Caravan Broken Exhaust Valve
by cptbarkey - 12/11/19 07:48 PM
Put the winter tires on the Impala today.
by JimPghPA - 12/11/19 07:31 PM
Chasing down a brake issue
by HawkeyeScott - 12/11/19 07:14 PM
Total Quartz 9000 Energy 5w40
by BurntMusic - 12/11/19 06:53 PM
Mazda 3 i-ACTIV AWD diagonal test
by buster - 12/11/19 05:35 PM
Tires or Toyota ABS
by ford46guy - 12/11/19 05:33 PM
RV chase straight out of the Movies
by KeithS_NW_Ohio - 12/11/19 04:56 PM
Will the octane change?
by Mar57 - 12/11/19 04:45 PM
DIY brake lines help
by LeakySeals - 12/11/19 04:20 PM
random misfire code but not missing
by bowlofturtle - 12/11/19 03:31 PM
oilylp, Motorapido, TyMillerfc, AcadiaDave, lmt1911
70106 Registered Users
17 registered members (Aero540T, Danno, jkhawaii, gfh77665, 4 invisible), 249 guests, and 18 spiders.
Topics298,608
Posts5,139,086
Members70,106
Most Online3,589
Nov 2nd, 2019
PENZOIL Platinum HM lower oil pressure #5158023 07/11/19 04:41 PM
R
Rattler Offline OP
R
Hi all. I have a 97 ram 1500 with a 3.9 magnum. It has 110,000 on the clock. I normally use Mobile 1 EP 5w30 but the price with rebate was too good to pass up on the Penzoil Platinum High Mileage 5w30.
I've only got 14 miles on the oil but have noticed significantly less pressure with the PP at idle. Anyone have an idea what is going on?
Re: PENZOIL Platinum HM lower oil pressure [Re: Rattler] #5158031 07/11/19 04:52 PM
A
atikovi Offline
A
The old filter was loaded with dirt causing a restriction and resulting in higher pressure. New filter, less restriction, lower pressure.
Re: PENZOIL Platinum HM lower oil pressure [Re: Rattler] #5158043 07/11/19 05:07 PM
Z
zfasts03 Offline
Z
My 1997 Ram 1500 4x4, 5.9 also has lower oil pressure with some oils. I think Pennzoil is slightly lighter of an oil at operating temps.
As long as the oil pressure doesn't get below about 1/4 on the gauge at idle you should be good. Mine still comes to a little over 1/2 when cold and higher RPM's. Also it is hotter out so the oil is running hotter and thinner.
The oil pressure sender is after the filter, so I don't think a new filter would cause lower pressure. The way I understand your old restricted filter would cause lower pressure readings not a new filter.
- 03 Corvette Z06
Amsoil 5w-30 SS
- 07 Honda Accord 2.4L
Amsoil 5w-20 SS
- 16 Suburban 5.3L
Amsoil 0w-20 SS, XG10575(16-28 by-pass)
- 18 4Runner TRD Off Road
Amsoil 0w-30 SS, TRD filter
Re: PENZOIL Platinum HM lower oil pressure [Re: Rattler] #5158049 07/11/19 05:20 PM
R
Rattler Offline OP
R
Alright, thank you guys. I'm not going to worry about it then. Zfasts03 that's exactly how my dash pressure gauge is behaving. I'm glad I asked before chasing a problem that wasn't there with a new sending unit and high volume oil pump!
Re: PENZOIL Platinum HM lower oil pressure [Re: Rattler] #5158299 07/12/19 12:58 AM
O
OilUzer Offline
O
When the light comes on something is wrong.
My oil pressure gauge has no marking on it ... No numbers, no color (red, good, bad, ok) ...
It's usually somewhere near the middle. It's a boring garage and I ignore it most of the time.
I think they wired the oil light to it. If the light is on, the gauge may go all the way up or down.
If light is off, stays in the middle.
Old cars or most new cars have no oil pressure gauge.
I prefer a digital readout. Analog gauges with no numbers or scale are meaningless!
Re: PENZOIL Platinum HM lower oil pressure [Re: Rattler] #5158317 07/12/19 02:45 AM
M
Mad_Hatter Offline
M
PP HiMi has a VI of 170 so it shouldn't be thinning that much at operating temp, if at all. (higher the # the less susceptible to the effects of high operating temperature?) And it has a 10.1kv @100c so it's a middle of the road Xw30, right?
Can you get a low oil pressure light with these numbers and it not be something else causing it??
Re: PENZOIL Platinum HM lower oil pressure [Re: Rattler] #5158394 07/12/19 06:22 AM
L
littleant Offline
L
2002 Jeep 4.0 162,000 miles Have the same results with Pennzoil Platinum High Mileage 5w30 and 10-30. About 20 psi at idle where as the same conventional oil presure is 30 psi at idle. But I will not worry about it because this winter at -30 to -40 with fram ultra filter the Pennzoil flows great far superior at cold temps then the conventional.
I can't prevent getting old but I REFUSE to grow up.
2010 Mountaineer 4.0
2002 Jeep Wrangler TJ 4.0
Re: PENZOIL Platinum HM lower oil pressure [Re: Rattler] #5159498 07/13/19 10:26 AM
R
Rattler Offline OP
R
My oil light isn't kicking on. The pressure gauge reads the 1/4 Mark at idle once warm at idle and 40 or a bit over while driving. Mobil 1 the needle barely moved.
Re: PENZOIL Platinum HM lower oil pressure [Re: Rattler] #5159514 07/13/19 10:54 AM
demarpaint Offline
I would confirm actual oil pressure with a mechanical oil pressure gauge and eliminate any guess work. Dash oil pressure gauges are for the most part a glorified idiot light and don't tell much of anything in cases like this.
God Bless Our Troops
Re: PENZOIL Platinum HM lower oil pressure [Re: Rattler] #5159540 07/13/19 11:38 AM
T
Triple_Se7en Offline
T
I agree withe Demar. If you are changing oil brands ...aka... formulations - changing viscosities, your oil gauge will show changes also. Gauges also change with our four seasons here in Michigan.
Best way to judge a factory oil gauge reading is thru consistency. Keep things the same with your oils and document how differing, drastic weather changes your readings. Then compare year-to-year.
Most owner manuals sitting in your glovebox has several pages on the back for taking notes. Most have never written a thing on those pages.
19' Hyundai Santa Fe 2.4 GDI - Valv Syn 5w30 / Napa Proselect filter / 6oz Liqui-Moly
20' Kia Soul X-Line 2.0 Multi-port / Factory-fill oil / filter
04' Colorado 3.5 / Castrol Edge 0W40 / K&N filter
Re: PENZOIL Platinum HM lower oil pressure [Re: Rattler] #5159678 07/13/19 03:19 PM
R
Rattler Offline OP
R
I'll hook up a real mechanical pressure gauge. I know exactly what to expect from Mobil 1 on the gauge by the season, the pphm is a big change that is unexpected though in the way the gauge is acting.
