What does a Bosch D+ 3312 fit?
In the shop
Good evening BITOGERS. Got a massive oil filter porn box from Subyrubieroo
Have a Bosch d+ 3312 filter from him. This fits Honda's correct?
Thank You gentlemen and ladies
Go to Wix filters and look up 51334 (crosses to your 3312). There is a long list of applications for this equivalent filter, including Honda.
Ok, so since I have saw many kia/hyundais towed to our shop from aftermarket filters and incompetent quick lube places; should I cut this one open or??
How were the aftermarket filters causing those cars to die and need a tow?
Sure, cut 'em all open.
Originally Posted by MParr
You can if you like. It will probably look like many other Purolator filters.
Yes, but a very HEAVY can and plate
These are different media that doesn't tear or make holes like other Purolators
A few vehicles came back with engine knock. Filter on loose, other problems. Hyundai/Kia forbids us from using "aftermarket" filters on our fleet. Something about bypass not being correct and other stuff. I'd use this if I had a Kia or Hyundai; BUT I dont
Yeah, the Fram site crosses it over to a 9688 or 3593a size.
I would use it on a Hyundai (I actually have a D+ 3323 (little taller, but smaller diameter than the 3312) ready to go on my sisters Hyundai Santa Fe, and have a D+ 3323 on my motorcycle right now)
I know you do enough Hyundai's for family/friends, I would use it without hesitation (only Purolator I use with no worries).
Originally Posted by SubieRubyRoo
Cut it Cut it... tonight
This was a $0.75 WM clearance so just slice it already
May give it to brothers friend that has a couple Honda's
I feel like I'm back in the locker room with my
14 year old buddy's
Puberty kicking in big time !!!...³...³ðŸ¤”🤔🤔
Sorta strange
Kstanf, not sure where you went to HS, but glad I wasn't there to observe.
53' and me just have lots of fun doing this for the board. He's been kicking back all week in NC so have to get him back in the mood LOL
I'm on board with ya
Those other post was kinda wth
On with the show
Next ??ðŸ‘ðŸ‘
Y'all we're sorta freaking me out 👽👽👽
I've used them on three Hyundai/KIA without incident. Tell whomever advised your shop not to sway from OEM, to go fly a kite.
I think newer Hondas use a xx7317 (Fram number) but this may still fit. My '99 Accord (4-cyl) uses a xx3593 and I'm wondering if Honda eventually switched all models to the 7317.
Comparing dimensions, it will fit pretty much any Honda. At some point, Honda went to a slightly larger diameter.
Originally Posted by KenshinHimura
Hyundais, Kias, Hondas and almost anything with a Yanmar in it
And pretty much all the compact diesel tractors coming out of South Korea also use this same 20mm x 1.5mm thread filter.
