Replaced kitchen faucet
by WyrTwister - 12/08/19 03:25 AM
508.00-509.00 oil for Honda K24Z3?
by allepunta - 12/08/19 01:36 AM
2020 Toyota Sequoia TRD Pro
by john_pifer - 12/08/19 01:26 AM
Liqui moly viscoplus
by Toh1 - 12/07/19 10:14 PM
Bought me a lemon 15 focus
by gabriel9766 - 12/07/19 10:12 PM
New axle fixed steering pull?
by Chris142 - 12/07/19 09:52 PM
E-core super tech vs Fram orange can 10k
by Doublehaul - 12/07/19 09:01 PM
Interesting trend at my local walmarts
by N Heat - 12/07/19 08:39 PM
Stp S2 oil filter come with silicone ADBV for $4.99
by MetalSlug - 12/07/19 07:50 PM
RATS
by MrQuackers - 12/07/19 07:46 PM
First Day of Summer in New Zealand.
by Silk - 12/07/19 07:02 PM
Gumout Regane Complete 6pk for $22.79
by volk06 - 12/07/19 06:15 PM
Basement sewer smell/Plumbers info req'd.
by irv - 12/07/19 06:03 PM
Project Farm tests car batteries
by cwilliamsws6 - 12/07/19 05:59 PM
Is this normal?
by TurboLuver - 12/07/19 05:12 PM
Any Scooter Riders?
by Passport1 - 12/07/19 03:20 PM
High Performance Lubricants
by wwillson - 12/07/19 02:27 PM
Student laptop needed.
by irv - 12/07/19 01:13 PM
4 unifi AP
by BeerCan - 12/07/19 12:25 PM
AutopartsTester8, Wamanada, Mblegends, smlobx, bithebay87
70066 Registered Users
33 registered members (czbrian, Brad_C, bmod305, Blkstanger, 4WD, BBDartCA, 5 invisible), 1,007 guests, and 61 spiders.
Topics298,432
Posts5,135,280
Members70,066
Most Online3,589
Nov 2nd, 2019
rear axle grease? #5128030 06/07/19 03:09 PM
J
Jimkobb Offline OP
J
Just wonder how often to pull the rear axle and re-grease in there?
green_bay_packers_logo_small[1]
Re: rear axle grease? [Re: Jimkobb] #5128062 06/07/19 04:02 PM
K
Kamele0N Offline
K
I did it after my third season.....and had to change conuses and balls also....there was still grease inside...but in insufficient quantities!
I used NLGI 0 calcium/lithium grease....it is very tacky one!
2008 Toyota Yaris 1ND-TV 1.4 D4-D Tech9 5W30 C3 VW 504/507
1997 Toyota Landcruiser KZJ95 3.0 TD Elf Evolution NF900 5W40
Re: rear axle grease? [Re: Jimkobb] #5128351 06/08/19 06:47 AM
J
Jimkobb Offline OP
J
Kameleon , were any special tools needed ? I have all the basic tools for working.
Re: rear axle grease? [Re: Jimkobb] #5129123 06/09/19 07:59 AM
K
Kamele0N Offline
K
You need "special" cone spanners...wich are basically thinner version of an "french key" (at least we call it so)
YouTube is your friend here!
Re: rear axle grease? [Re: Jimkobb] #5129280 06/09/19 11:37 AM
J
Jimkobb Offline OP
J
Yea, I thought you may need those "cone spanners" . I don`t have them .
Re: rear axle grease? [Re: Jimkobb] #5129578 06/09/19 05:44 PM
B
BikeWhisperer Offline
B
Depends on the brand and model of hub you have. Some are quite serviceable (Shimano or Shimano like) with loose ball bearings and cone races. Others use sealed cartridge bearings that aren't really that serviceable and generally are just replaced when they are no longer smooth.
I go through my Shimano hubs annually with Bel Ray water proof grease. Mostly preventative maintenance and they are always clean inside.
2015 F150 XLT SCrew 2.7 Eco-Boost
5w-30 Magnatec, FL2062
2018 Ford Edge SEL Eco-Boost 2.0
5w-30 Magnatec, FL-910S
Re: rear axle grease? [Re: Jimkobb] #5129706 06/09/19 07:41 PM
J
JLawrence08648 Offline
J
Use only synthetic grease.
Re: rear axle grease? [Re: JLawrence08648] #5129876 06/10/19 12:56 AM
CR94 Offline
Use only highly water-resistant EP grease, whether it's synthetic or not. Others will wash out if you ever get caught in rain.
2011 Toyota Prius now at 107K
Re: rear axle grease? [Re: Jimkobb] #5130082 06/10/19 08:47 AM
supton Offline
Some good videos out there, along with various threads on bicycle sites.
I picked up my cone wrenches years ago, I think they are cheapo Spin Doctor stuff from Performance bike. Nothing special. Don't use them for anything other than cones, they are thin and won't take to being used on any "real" bolts or nuts.
That reminds me, I should probably go through mine, it's been a few years. Oh and you might want to go on ebay or similar and buy a ball bearing kit. The usual advice is, if you drop a ball just toss it. Or just replace in the first place. And don't put in just one new ball with a bunch of old balls as the sizes won't match. I forgot how the grading works but I think it refers to how well matched the balls are to one another--so 25's are better than 100, that sort of thing. Me, I'm not competitive enough to notice so I run just a decent of bearings, nothing ceramic for me.
2011 Toyota Camry, base, 2.5L/6MT, 196k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 155k, ours
1999 Toyota Camry LE, 2.2L/4AT, 217k, his
Re: rear axle grease? [Re: Jimkobb] #5130296 06/10/19 12:32 PM
K
Kamele0N Offline
K
Any bike store or "wallmart" should have them...they are not expensive!
Re: rear axle grease? [Re: CR94] #5130298 06/10/19 12:33 PM
K
Kamele0N Offline
K
Exactly...usually that means calcium or calcium/lithium thickener...
Re: rear axle grease? [Re: Jimkobb] #5130379 06/10/19 01:44 PM
J
Jimkobb Offline OP
J
https://shop.harborfreight.com/medi...25d08d6e5fb8d27136e95/i/m/image_8176.jpg
Well, I got both front and rear wheels axles all cleaned up with a carbureter cleaner from Harbor Freight and wiped clean with a towel. I used "Super Lube" also from Harbor Freight. 3 ounces for $7 . It is a multi-purpose synthetic grease and has a NLGI on the listing.On their website it has a 120 reviews with a 5 star rating. Also on my "Diamondback" bike I did not need the cone spanner wrenches. One thing I do recommend is tag the parts that come off the left side and right side separate so you don`t mix them up.
Re: rear axle grease? [Re: Jimkobb] #5130882 06/10/19 08:57 PM
U
UG_Passat Offline
U
Cheapo Walmart Supertech marine grade grease.
Even if you don't have Shimanos with loose bearings, hubs with cartridge bearings still have an axle to maintain also, but may not require lubrication.
2016 VW Tiguan|APR Stage 1|Neuspeed P-Flo|Osram CBI|Redline 5w30
Re: rear axle grease? [Re: JLawrence08648] #5131028 06/11/19 04:42 AM
L
Lubener Offline
L
Automotive wheel bearing grease will be fine. No need for fancy stuff.
The "thinking" man's friend.
Re: rear axle grease? [Re: Jimkobb] #5142096 06/23/19 06:03 PM
J
J
I would either use bicycle specific grease or grease in a tube cartridge.
I have the Spin Doctor cone wrenches and they are cheap and work fine, also have a heavier set of Pedro's cone wrenches.
