Need earbud recommendations!
by cwilliamsws6 - 11/21/19 01:50 PM
Snow Shovel Recommendations ?
by Dwight_Frye - 11/21/19 01:29 PM
Torque Wrench Accuracy
by BMWTurboDzl - 11/21/19 12:32 PM
Does Discount Tire sell seconds?
by sasilverbullet - 11/21/19 11:23 AM
Tires for my 2007 Dodge Grand Caravan
by diyjake - 11/21/19 10:26 AM
Fair price for a brake job?
by Ddub - 11/21/19 10:09 AM
Anyone backing up their data online?
by gonefishing - 11/21/19 09:52 AM
Fram Ultra C&P
by mpgo4th - 11/21/19 09:19 AM
2001 Nissan Sentra / trans issue?
by Mark72 - 11/21/19 09:10 AM
CVT Maintenance for CVT Dummies
by Brons2 - 11/21/19 09:00 AM
Wix/ Napa best oil Filters
by edward51956 - 11/21/19 08:54 AM
Mahle OC84, 1974 BMW 2002
by wings&wheels - 11/21/19 08:48 AM
Oil is staying clean on Kubota L3560!
by Rglossip - 11/21/19 08:41 AM
7317 or 6607?
by cwilliamsws6 - 11/21/19 08:00 AM
Dana S110 Lube change
by Parkman - 11/21/19 07:21 AM
2003 GMC Sierra 1500HD 6.0L
by Redright9 - 11/21/19 07:17 AM
Canadian Tire Early Black Friday
by Snagglefoot - 11/21/19 07:07 AM
Viscosity at 85°C vs 100°C
by doyall - 11/21/19 06:58 AM
jtowndtk, Bogie247, VST, AlVan, gagecalman
69931 Registered Users
93 registered members (1978elcamino, 330indy, 5azzmonkey, 2004tdigls, 53' Stude, 2010Civic, 9 invisible), 2,267 guests, and 18 spiders.
Topics297,727
Posts5,121,475
Members69,931
Most Online3,589
Nov 2nd, 2019
Anatomy of an OEM Oil Catch Can (CCV Filter) #5125458 06/04/19 09:20 PM
DoubleWasp Offline OP
Came time to change my CCV. Because it was plugged. Because I was careless and forgot to do it sooner. Anyway......
This is the oil catch system that is built into the valve cover of my Cummins 6.7 diesel engine. Why does it have one? Older diesel engines simply have a pipe that blows out crankcase gases into the atmosphere. Once it was required for these gases to be directed into the air intake, they knew they needed a way to keep the turbo from sucking oil out of the engine and blowing it all over the charge air system. Pretty much any decent diesel engine that ingests it's own crankcase gases has some version of this. It works. If I pull the hose that leads to the turbo off, it is dry to the touch.
This is a true coalescing filter. Even oil vapor ends up trapped and recombined into fluid form before dropping back into the engine. Sorry about the poor lighting. Tonight was the only time I had to do this, so that's what happened.
[Linked Image]
Above you can see the old filter vs. the new filter, and pretty much how it works. You are looking at the bottom of both filters. The large hole is fed crankcase gases by the area under the valve cover. The smaller hole is fed crankcase gases by a hose that feeds up from the actual crankcase and then into a cavity integrated into the valve cover. Neat how they do that.
[Linked Image]
Above is a good look at the filter element itself. Both the valve cover feed and the lower crankcase feed get their own dedicated element that resembles a long and narrow oval of fleece. The elements are open on all sides so that oil may simply drip down into the cavity built into the valve cover. There is a hole at the back of this cavity that feeds a hose returning oil to the crankcase. That hose has a check valve in it so that it can only allow oil to return to the crankcase and cannot allow anything up. It stays a one way street for oil return at all times.
You can see the dirty old filter, and the good new filter media of the new filter.
[Linked Image]
Above is the cavity in the valve cover itself. You can see wires going to one of the injectors through the large hole.
[Linked Image]
Above here, we see the all the way in the back of the cavity, on the right side is the drain hole and hose going back to the crankcase.
Now, "so just how bad was the old one", you say?
This bad:
[Linked Image]
[Linked Image]
crush
It didn't break up at all until I started messing with it. I tried blowing air through it before I took it apart and it was like trying to blow through mud. Very restrictive. The solids that make up a tiny portion of crankcase gases eventually take their toll on the filter media. As well as age.
There is a sensor for crankcase pressure that goes off if it gets too high. My rings are tight enough that it never got that bad, but I did figure out the issue from elevated potassium and low TBN from my latest UOAs. When these things plug, their effectiveness goes down the toilet. Oil gets into the engine after washing potassium out of the intercooler. TBN goes in the hole as well due to poor crankcase ventilation. Immediately after receiving my UOAs, I went straight for the hose coming off of the filter and yep. Oil wet. Nice.
There is an unholy mess waiting for me in my turbocharger that I know looks like the devil took a dump into it. The piping and intercooler will need a good mineral spirits cleaning as well. Going to have to pop the intake horn off of the charge air heater and the plate off of the intake manifold to see what I managed to do there as well. Fun fun fun.
Might have just found the sorry excuse I need to order up a turbo with a fatter hot side, Steed Speed exhaust manifold, bigger and more efficient intercooler, fancy charge air pipes and connectors, a Banks intake horn, grid heater relocate kit, and Double Shot water injection. 😎😎😎
Service life of one of these is 60-70K miles, so it's an easy thing to forget. I won't again.
So there it is. If you ever wanted to know what a "real" "catch can" looks like (and why most of the aftermarket ones being sold are of questionable effectiveness due to lack of this level of engineering), there it is!
Re: Anatomy of an OEM Oil Catch Can (CCV Filter) [Re: DoubleWasp] #5125473 06/04/19 09:41 PM
carviewsonic Offline
Very good write up. I had no idea diesels had these. How many miles on your Cummins for the filters to get like that?
'18 Impala
'05 Park Avenue
'03 Park Avenue
'07 Honda Accord
'09 VStar 1300
Re: Anatomy of an OEM Oil Catch Can (CCV Filter) [Re: DoubleWasp] #5125511 06/04/19 10:36 PM
O
oldhp Offline
O
That's neat!!!
"None of us are getting out here alive.....drink that beer.....eat that pizza......drive that Hot Rod"
"When others cut you down, remember where they came from."
"I don't run...........I just wait"
Re: Anatomy of an OEM Oil Catch Can (CCV Filter) [Re: carviewsonic] #5125523 06/04/19 11:02 PM
Almost half a million on my engine.
112,000 miles on the filter.
crush
Not all emissions diesels have them. Powerstroke 6.0 just has a baffle box with a tube coming out of it that goes straight into the intake tube.
Re: Anatomy of an OEM Oil Catch Can (CCV Filter) [Re: DoubleWasp] #5125599 06/05/19 04:42 AM
demarpaint Offline
Nice write-up. I wonder how many people have no clue the filter exists, let alone know it has to be serviced.
God Bless Our Troops
Re: Anatomy of an OEM Oil Catch Can (CCV Filter) [Re: DoubleWasp] #5125653 06/05/19 06:32 AM
T
Trav Offline
T
Yet all the catch can advocates fail to realize or accept that a coalescing type filter is the only real way to separate oil from the air be it from a compressor or vehicle PCV system. A catch can with no coalescing filter is nothing more than a particle/water trap, not very effective.
Re: Anatomy of an OEM Oil Catch Can (CCV Filter) [Re: DoubleWasp] #5125759 06/05/19 08:35 AM
Pretty much. The PSD 6.0's CCV "filter" (baffle box stiffed with steel wool) eventually gave way to a coalescing filter like mine in the later PSD engines.
A lot of companies have a Provent coalescing filter (the only catch can that actually works) retrofit kit for the PSD 6.0 for this very reason.
Re: Anatomy of an OEM Oil Catch Can (CCV Filter) [Re: DoubleWasp] #5126156 06/05/19 02:59 PM
N
nthach Offline
N
How come the diesel engines have this, and gasoline engines still use a crude system for PCV? I recall seeing a bare vent pipe on trucks and buses that would spew crankcase vapors.
Honda tried to use a gas/liquid separator on the R18 Civic engines, and Subaru did something similar. Both have issues with the oil/air separator plate leaking. Those were a labyrinth design that caused oil to separate via deceleration of the air path.
Re: Anatomy of an OEM Oil Catch Can (CCV Filter) [Re: nthach] #5126209 06/05/19 03:44 PM
B
BMWTurboDzl Offline
B
Gas engines do and some can have a cylonic separator which works well. Fortunately for gas soot less of a problem.
435i
