98 Expedition heating system flow diagram
by Fitz98. 07/18/19 12:39 AM
How did I become the constable?
by Chris142. 07/17/19 11:05 PM
Changed oil, Ravenol FullSynth Turbo VST 5W-40
by NotEnoughSpeed. 07/17/19 08:30 PM
Blending TCW3 in diesel
by 32319. 07/17/19 08:27 PM
Leaking Batteries
by ecotourist. 07/17/19 08:22 PM
Shake down tow complete!
by ls1mike. 07/17/19 08:22 PM
Looking for cheap int'l air tix
by daves66nova. 07/17/19 08:05 PM
Not *new* per se, but $3.98 for 5 quarts of M1
by mrdctaylor. 07/17/19 07:45 PM
Winter tires for 2019 Ram
by NissanHauler. 07/17/19 06:16 PM
Is the car hobby/enthusiast a dying breed?
by Redright9. 07/17/19 05:48 PM
Mobil One design change M1C-154A
by piesled. 07/17/19 05:26 PM
crazy granny gear spotted
by Number_35. 07/17/19 04:32 PM
Grease gun suggestions
by rideon. 07/17/19 04:16 PM
17 Imprezza 2.0
by JHogan. 07/17/19 03:42 PM
new boat, considering twin f 150 yamis
by 1978elcamino. 07/17/19 03:20 PM
Preventative repair - 2009 Ford Flex water pump
by KGMtech. 07/17/19 02:56 PM
patman3d, Oillogger, Rob707, rageyourdreams, Beemer25
68692 Registered Users
34 registered members (crainholio, Chesterr, clinebarger, chemman, A_Spruce, 4 invisible), 824 guests, and 19 spiders.
Topics292,010
Posts5,015,187
Members68,692
Most Online2,967
Mar 10th, 2019
Bias or Radial 13'' Trailer Tires #5124834
06/04/19 07:31 AM
06/04/19 07:31 AM
Central NY
Miller88 Offline OP
Miller88  Offline OP
Central NY
Working with a friend on putting together a Jeep toter trailer. It's currently on two 3500 pound axles running 175/80-13 wheels. Verified by measuring spindle size, looking up bearings and comparing to another known 3500 pound axle. They are legitimate trailer tires but only rated for 1300 pounds each. 2 are brand new, 2 are original. All four will have to get replaced as the new ones won't be up to the Jeep and the weight of the trailer.
I could step up to 14s or 15s - the hub and brakes are supposed to be compatible with 14 or 15'' wheels. However, I know I won't have a 1 ton truck forever. It's very likely that my F350 will be replaced by a 2020 ranger somewhere around 2023 or 2024 depending on reliability. We're trying to keep weight and COG low so I'd really like to stick with the 13s.
I'm finding a few different higher capacity options on etrailer. Both Load Range E.
Radial Tire, 1650 pounds https://www.etrailer.com/Tires-and-Wheels/Kenda/AM10210.html
Bias Tire: 1710 pounds https://www.etrailer.com/Tires-and-Wheels/Kenda/AM1ST79.html ... these are a slightly larger tire.
The Bias tires will have 200 more pounds of fudge factor and will be running at less capacity all the time. They will also handle a lot of the crappy gravel roads and trails I'll be dragging it up now and then. However, I do tow 200+ miles occasionally and they will be subject to 200+ miles at 65 MPH. That does concern me as bias tires tend to run hot.
Radials will handle the longer trips better, tow nicer (they tend to not sway as bad). However, they have a lower load rating and the tires themselves are weaker.
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: Bias or Radial 13'' Trailer Tires [Re: Miller88] #5124842
06/04/19 07:39 AM
06/04/19 07:39 AM
KS
FordBroncoVWJeta Offline
KS
https://www.walmart.com/ip/Carlisle-Radial-Trail-HD-175-80R13-D/508064664
I'd probably go Bias Ply if you need the higher weight rating, if not drop down to a radial. Both of those in your links are load range D. I dont believe they even make a E for this size.
2017 Volkswagen Jetta 1.4T - 2015 Honda CRV 2.4 - 2012 Volkswagen Jetta 2.0 - 2007 Chevy Trailblazer 4.2 - 2003 Ford Taurus 3.0 Vulcan
Re: Bias or Radial 13'' Trailer Tires [Re: Miller88] #5124866
06/04/19 08:05 AM
06/04/19 08:05 AM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
can you fit 185/80r13 ?
Re: Bias or Radial 13'' Trailer Tires [Re: Miller88] #5124867
06/04/19 08:06 AM
06/04/19 08:06 AM
Central NY
Miller88 Offline OP
Miller88  Offline OP
Central NY
Unfortunately those Carlisle Radial Trail HD are only rated for 1570 each. It looks like the bias might be the best bet for me.
Yep! That's the size of the higher rated bias ones.
They might not clear the current fenders, but the current fenders are coming off and we will be making custom drive over fenders.
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: Bias or Radial 13'' Trailer Tires [Re: Miller88] #5124883
06/04/19 08:21 AM
06/04/19 08:21 AM
Ajax,Ontario, Canada
Pelican Offline
Pelican  Offline
On a trailer the benefit of radials will be moot. Go with bias.
Re: Bias or Radial 13'' Trailer Tires [Re: Miller88] #5124887
06/04/19 08:27 AM
06/04/19 08:27 AM
NH
supton Offline
supton  Offline
NH
What's the speed rating? I think the last set of trailer tires I got were radial and rated for 75mph.
Do they derate tandems like they do for dual tires on an axle? I'd think they'd run warmer from tire scrub.
2011 Toyota Camry, base, 2.5L/6MT, 187k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 152k, ours
1999 Toyota Camry LE, 2.2L/4AT, 208k, his
Re: Bias or Radial 13'' Trailer Tires [Re: Miller88] #5124937
06/04/19 09:42 AM
06/04/19 09:42 AM
Lakeville, MN
MNgopher Offline
MNgopher  Offline
Lakeville, MN
The bias-ply tire will serve you well. I've used that particular tire (different size) for many years in boat trailer service with excellent results (never had a failure of these tires in service, including one taking a decent gash in the sidewall (unknown to me) but making it home without incident. (Side note: I tried a set of Taskmasters recently and never again. Nearly impossible to mount and had one fail with less than 7 months in service - 5 of them in storage...)
Be aware that shops typically will not have a tire (the 185 bias ply tire) in stock. It is a bit of an oddball tire size (though it appears to have been used on a lot of pop up campers).
For the relatively short distances you are towing, there is not a lot to be gained with the radials.
Re: Bias or Radial 13'' Trailer Tires [Re: MNgopher] #5124949
06/04/19 09:53 AM
06/04/19 09:53 AM
Central NY
Miller88 Offline OP
Miller88  Offline OP
Central NY
It's a size I haven't seen before. I May buy 4 and keep the current two for spares just to get me home. As long as there's no issues with towing 65 or so for 200 miles I'll probably go with the bias.
Speed rating is only 81MPH on all of them. I try to keep my speed at 65 or lower when towing. Sometimes I don't have a choice and my top speed is 40 in the slow lane with 4 ways on. Not derated for tandems, luckily.
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: Bias or Radial 13'' Trailer Tires [Re: Miller88] #5124955
06/04/19 10:02 AM
06/04/19 10:02 AM
Canada
weebl Offline
weebl  Offline
Canada
Not the greatest choices in small sizes. They were tough to find years ago, and I imagine even tougher now.
A near unicorn size my tent trailer came with from the factory was ST185/80D13 in Load Range D. A pair came to a load rating right around the 3,500 lb mark.
I replaced them by upgrading to a 14", and was towing with a minivan at the time, so I don't think you should have an issue for the future when you downsize your truck. The size I used was a slightly less unicorn of a size, still not easy to find: 185R14C in Load Range D. It is a Euro size "van" tire as they call them, basically an LT tire.
Another option is LT195/75R14. I think Load Range D, but again, a tough size to find.
Then there's ST205/75R14, I believe these are Load Range D. Might be the easiest of the 14" to find.
2006 Toyota Sienna - 3.3L 3MZ-FE
2013 Chevrolet Silverado 3500 - 6.6L Duramax LML
2018 Volkswagen Tiguan
Re: Bias or Radial 13'' Trailer Tires [Re: Miller88] #5125014
06/04/19 11:28 AM
06/04/19 11:28 AM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
They also have radial in that size that are higher 1700+, I dont think you have anything to gain by using bias ply.. they will tow harder, get hotter, and not as stable.
The extra capacity is due to the larger tire not being bias ply
https://www.amazon.com/dp/B017KY98II/ref=psdc_404866011_t3_B01KOKUV90
is the kenda in the larger size.
Re: Bias or Radial 13'' Trailer Tires [Re: Miller88] #5125040
06/04/19 11:52 AM
06/04/19 11:52 AM
Lakeville, MN
MNgopher Offline
MNgopher  Offline
Lakeville, MN
Seeing as how the image is not of a Kenda tire in that Amazon link, that doesn't exactly inspire confidence.
With all of one review, not sure I'd hang my hat on those...
Re: Bias or Radial 13'' Trailer Tires [Re: MNgopher] #5125043
06/04/19 12:10 PM
06/04/19 12:10 PM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
There are plenty of others.. The OP posted a link to a radial kenda one size smaller, and was considering buying bias play because the larger size has more capacity... plenty of radials in the larger size too.
Personally I'd just upgrade the wheels to 14" or 15" while I was at it.
but buying bias ply for more load rating was not true since radial trailer tires in decent variety are available in 185/80r13
Re: Bias or Radial 13'' Trailer Tires [Re: MNgopher] #5125051
06/04/19 12:17 PM
06/04/19 12:17 PM
Canada
weebl Offline
weebl  Offline
Canada
My tent trailer came with Kenda tires. I took that trailer across the country one summer, and had no issues, though by the fifth year of their life, they were wearing quite unevenly. My replacement 14" radials have had no such wear issues.
The tire in the picture is not a Kenda, though. Not sure I would trust that tire, or that particular seller.
Re: Bias or Radial 13'' Trailer Tires [Re: Miller88] #5125226
06/04/19 03:48 PM
06/04/19 03:48 PM
CA
user52165 Online content
user52165  Online Content
CA
Go with 14 or 15" wheels. Most trailers are spec'd to the bare minimum or inadequately as a cost savings. No such thing as too much wheel/tire here.
You get many more choices and with the conditions of towing mentioned it is everyone's best interest. I see so many trailer failures with the off road crowd in the desert.
Guys spend mega $$$$ on their toys and cheap out on the trailer.................... straight from the factory that way.
Re: Bias or Radial 13'' Trailer Tires [Re: Miller88] #5125310
06/04/19 06:31 PM
06/04/19 06:31 PM
out there
spasm3 Offline
spasm3  Offline
out there
I had a dual axle travel trailer with 13 inch tires. I ran Maxxis 8008 tires. Better than the cheap tires. Had 2 sets, the first i replaced due to age at 7 years.
13 elantra 78k 5w30 synpwr
17 mazda cx-5 12300 miles m1 0w30
