Fram XG7317 20k miles cut open
by dbeau - 11/17/19 09:46 PM
2021 Ford Mach-E Electric SUV
by KeithS_NW_Ohio - 11/17/19 09:05 PM
Walker mower Oil
by Joey737 - 11/17/19 09:03 PM
Rough service tough light bulb 1ยข at Home Depot
by JLawrence08648 - 11/17/19 08:40 PM
2015 F150 5.0 8592 miles
by Buzzinhalfdozen - 11/17/19 08:36 PM
MOPAR MO-285 FACTORY OIL FILTER CUT OPEN
by 53' Stude - 11/17/19 07:43 PM
Best Garage Door Seals
by Gebo - 11/17/19 07:18 PM
Bar oil as fogging oil
by WA1DH - 11/17/19 06:47 PM
Fram PH2 ExtraGuard Cut Open
by A310 - 11/17/19 06:38 PM
C&P Pentius UFXL PH16-equiv.
by 92saturnsl2 - 11/17/19 06:18 PM
Fleetguard WF2074 Coolant Filter Cut Open
by Pyrotechnic - 11/17/19 05:24 PM
Cuts on tire sidewall
by mclasser - 11/17/19 03:19 PM
Hyundai Theta II Engine in Newer Years
by smc733 - 11/17/19 02:41 PM
Walmart deals
by Deere John - 11/17/19 02:33 PM
Grumpy Kid
by wings&wheels - 11/17/19 01:57 PM
h9/95R FLA Batteries
by TXCarGeek - 11/17/19 01:40 PM
Preventative parking brake service
by Donald - 11/17/19 01:26 PM
Should I run an AC Delco Ultraguard gold?
by JHZR2 - 11/17/19 01:13 PM
Ford Ecoboost 400 at Homestead Miami Speedway
by bdcardinal - 11/17/19 01:08 PM
Strut mount, Moog vs KYB?
by jbutch - 11/17/19 01:07 PM
JimBobSeeker, Joey737, bdavis218, XTR74, 2009Caraman
69899 Registered Users
54 registered members (bdcardinal, 2009Caraman, AC1DD, 5 invisible), 1,161 guests, and 22 spiders.
Topics297,566
Posts5,118,159
Members69,899
Most Online3,589
Nov 2nd, 2019
1953 Corvette engine oil specifications. #5123295 06/02/19 06:01 PM
7
79sunrunner Offline OP
7
Oddly 20 weight is specified for summer temperatures. I remembered my friends '54 Chevy Special also recommended 20 weight for summer. I wonder if this is still the correct viscosity of oil for these engines today? At least in good condition engines such as 5w20. Also note British manufactures such as Jaguar and MG suggested 30 and 40 weight for +32F and +80F weather.
[Linked Image]
2005 s60r for sale
'79 MG Midget 10w30
Passat tsi 2.0 Pentosin 5w40
Re: 1953 Corvette engine oil specifications. [Re: 79sunrunner] #5123303 06/02/19 06:08 PM
Chris142 Offline
My uncle worked for Gulf oil way back then. He said to Run sae20 until consumption went up,then sae30 then once to sae40 a rebuild was due
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: 1953 Corvette engine oil specifications. [Re: 79sunrunner] #5123306 06/02/19 06:12 PM
G
Garak Offline
G
The HTHS of a monograde 20 might be a bit higher than the 5w-20 and 0w-20 ILSAC options we see today.
Plain, simple Garak.
Re: 1953 Corvette engine oil specifications. [Re: 79sunrunner] #5123307 06/02/19 06:12 PM
F
faltic Offline
F
Interesting
19 Tacoma 3.5 2wd AT. Under 1K
17 Highlander 3.5 2wd AT 20k+
07 EX250 21k+
09 EN500 11k+
11 PCX 125 5K+
Re: 1953 Corvette engine oil specifications. [Re: 79sunrunner] #5123312 06/02/19 06:15 PM
B
bubbatime Offline
B
I would not run 5W20 in it.
Id run 15W40 heavy duty engine oil in it. You wont find any roller camshaft or roller rockers in that thing... all flat tappet stuff.
2019 Honda CRV 1.5T factory bulk
2017 Chrysler Pacifica SuperTech synthetic 5W20
2013 Yamaha XT250 Valvoline motorcycle 10W40
2006 GMC Sierra SuperTech high mileage 5W30
Re: 1953 Corvette engine oil specifications. [Re: 79sunrunner] #5123320 06/02/19 06:23 PM
J
JeffKeryk Offline
J
Blue Flame 6 cylinder and 2 speed auto.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: 1953 Corvette engine oil specifications. [Re: 79sunrunner] #5123327 06/02/19 06:28 PM
wwillson Offline
Administrator
Administrator
John Deere tractor manuals from the 1960s had similar viscosity recommendations.
Re: 1953 Corvette engine oil specifications. [Re: 79sunrunner] #5123329 06/02/19 06:29 PM
B
bullwinkle Offline
B
5W20 would be a bit thinner & more shear prone than SAE 20-but it would work a lot better in cold weather. I would (like said above) 15W40 or straight SAE 30 HDEO in it-zero emissions equipment, not even a PCV valve, and a little lead substitute in the fuel wouldn't hurt anything either, due to the non-hardened valve seats.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: 1953 Corvette engine oil specifications. [Re: Garak] #5123330 06/02/19 06:30 PM
O
OilUzer Offline
O
Good point.
Monogrades don't have any vii either. Isn't that true?
Re: 1953 Corvette engine oil specifications. [Re: 79sunrunner] #5123337 06/02/19 06:39 PM
T
tig1 Offline
T
I used Valvo 20wt in the late 60's and early 70's.
2007 Ford Fusion 249,000 miles
M1 5-20HM
2017 Ford Fusion 80K
M1 0-20EP
M1 ATF and Valvoline LV
M1 10-30 in all OPE
MC filters
Re: 1953 Corvette engine oil specifications. [Re: 79sunrunner] #5123339 06/02/19 06:42 PM
R
rfeir Offline
R
Oil today is nothing like the oil offered back in 53. I have a 59 and run 0W-40 European Formula Mobil 1.
The Car is used infrequently and runs great on this modern oil. No sludge, no varnish and it starts quickly.
I take it to the redline with no effort.
RPF
Re: 1953 Corvette engine oil specifications. [Re: OilUzer] #5123356 06/02/19 07:01 PM
G
Garak Offline
G
Yes. SAE 20 and 20w-20 were common recommendations at one time.
Re: 1953 Corvette engine oil specifications. [Re: OilUzer] #5123381 06/02/19 07:24 PM
Nickdfresh Offline
Good point.
They were 1950's Group I oils with almost no additive pack. Do you think they're anywhere near the full syn 20W's of today?
Re: 1953 Corvette engine oil specifications. [Re: Nickdfresh] #5123395 06/02/19 07:38 PM
G
Garak Offline
G
The additive pack today will be much better, but the viscosity won't be there. I would suggest one jump a grade, or track down a modern SAE 20 or 20w-20, if such can be found. Castrol had the last 20w-20 I saw, just a few years ago.
Re: 1953 Corvette engine oil specifications. [Re: 79sunrunner] #5123399 06/02/19 07:39 PM
Carbon12 Offline
I remember reading somewhere that SAE 20 has an HTHS near 3.0-3.1 cP which is similar to modern ILSAC 5w30 or 10w30.
Old tractors have similar viscosity/temperature charts. I have 52 Farmall Super C and I use Rotella 10w30. HTHS of 3.5 (near most SAE 30's) yet would be much better in cold weather. Higher ZDDP too.
