Originally Posted by WisconsinDavid
The manual calls for sg/sh/sj/sl ... but says no sm.
Specifically, the Owner's Manual is worded as if they are concerned about
too much Friction Reducer (modifier, or 'FM') interfering with clutch action. ( SM GF-4 oils (and subsequent SN GF-5 oil too) has to pass a Sequence VID fuel economy improvement test which almost all oils use FM to achieve. )
The Owner's Manual (below) really meant to say "SM
and GF-4", since it is possible to have an SM or SN oil that is high friction, but if an oil has GF-4 or GF-5, that means friction is too low.
Remember friction is not the same as wear. You can be low wear with high friction, just sayin'.
Certainly JASO MA will probably be the spec to look for, as it tells you it is low FM, the higher friction needed for those clutches, and
Rotella T6 5w-40 is JASO MA.
Interestingly, Shell Rotella T6 5w40 does have a
light amount of moly FM (60 ppm), but its not enough to be a problem, apparently: "
I have been using this oil in my 1998 Honda F6 Valkyrie Tourer for 6 years now, and have had no issues with clutch operation. Even at full throttle with the big 6 cylinder engine, no clutch slippage." --- from a review on Shell's website
