Pfft.. piece of cake!
by Mad_Hatter - 11/11/19 06:17 PM
Garage door lack of signal/reception issue
by dja4260 - 11/11/19 06:05 PM
low voltage triggers abs and parking brake light?
by motor_oil_madman - 11/11/19 06:03 PM
Kendall GT-1 MAX 5W30 2017 Crosstrek
by Voleak - 11/11/19 05:51 PM
Wife’s Oil Change
by KevGuy - 11/11/19 05:48 PM
AZ $10 off of $50
by BlakeB - 11/11/19 05:41 PM
B&S riding mower long filter short filter etc.
by j_mac - 11/11/19 05:32 PM
Covering the cowl vent
by painfx - 11/11/19 05:31 PM
Project: DuckHead Arm
by RayCJ - 11/11/19 05:29 PM
I Found The Perfect Garage Door Oil
by billt460 - 11/11/19 02:03 PM
Oil recommended for Old Snowthrower
by Ckerch - 11/11/19 01:58 PM
Choo Choo train maintenance and repairs?
by Chris142 - 11/11/19 01:58 PM
Hemi Oil Use
by Zap1967 - 11/11/19 01:27 PM
Who Makes the Best Class 8 "Semi" Truck These Days?
by LoneRanger - 11/11/19 01:21 PM
Update to my Wide Open West Broadband Thread
by LoneRanger - 11/11/19 01:15 PM
Is it worth changing my Corolla oil before 10k?
by oxband - 11/11/19 01:10 PM
Blowing smoke in 1970 Chevelle
by 007 - 11/11/19 12:05 PM
Coolant leak parked in the cold
by OCDriver - 11/11/19 11:58 AM
Where can I get a dumb battery charger?
by Chris142 - 11/11/19 11:56 AM
oxband, coachmorin, michaelpbreen, Zap1967, corleco
69826 Registered Users
119 registered members (25ring, 1978elcamino, Astro_Guy, 2015_PSD, 2_Tall_Mitchell, 69Torino, 8 invisible), 2,221 guests, and 22 spiders.
Topics297,281
Posts5,112,210
Members69,826
Most Online3,589
Nov 2nd, 2019
Page 1 of 4 1 2 3 4
Oil and filter 9000miles trip with 7000lbs trailer. #5118296 05/28/19 02:00 PM
M
MagneticFX Offline OP
M
2017 F150 V8. What oil you will recommend for 9000 miles summer trip East- West- East trip with 7000lbs travel trailer ,also by Canadian Rocky Mountain 2ways.
16000 miles on truck at the moment and will keep my F for next 10+ years .
Should I go with higher HTHS and viscosity oil fro that trip ?!
At the moment i'm running PUP 5W20 ( Ford specs ) with Purolator Boss filter . Will change oil after get to west coast.
Re: Oil and filter 9000miles trip with 7000lbs trailer. [Re: MagneticFX] #5118303 05/28/19 02:07 PM
GumbyJarvis Offline
I'd bump the PUP to the 5w30 and whatever filter suits your taste if it still falls under Ford specs and roll with it.
Safe travels!
2018 RAM 1500 SLT 5.7L
Formula Shell Conventional 5w20 - Fram Tough Guard
Disabled US Army Vet
OEF 2013-2014
Re: Oil and filter 9000miles trip with 7000lbs trailer. [Re: MagneticFX] #5118305 05/28/19 02:11 PM
diyjake Offline
I would change the oil filter with a Fram Ultra, much better filter than the Purolator Boss.
Re: Oil and filter 9000miles trip with 7000lbs trailer. [Re: MagneticFX] #5118319 05/28/19 02:23 PM
DoubleNickels Offline
Ford specs are minimum for daily driving. Go to the back of the the owners manual, and you will find maintenance schedule for severe duty. 5W-20 synthetic blend should be switched to full synthetic, and maybe even 5W-30. Although some people will say that the engine was engineered for the lower viscosity oil, and a thicker oil may be harmful.
Re: Oil and filter 9000miles trip with 7000lbs trailer. [Re: diyjake] #5118320 05/28/19 02:25 PM
GumbyJarvis Offline
Both are good filters, both are different brands "top of the line" filters. Both will work for what hes trying to accomplish.
Plenty of 1/2 ton pickups in fleet/construction uses run with OEM spec Oils/Filters or even whatever is the cheapest. Some of these pickups go hundreds of thousands of miles without an issue. Either a Boss or a Ultra are gonna do the jobs they were intended to do
OEF 2013-2014
Re: Oil and filter 9000miles trip with 7000lbs trailer. [Re: MagneticFX] #5118333 05/28/19 02:35 PM
PimTac Offline
That is severe service. Why not change the oil at a predetermined point along the way? Towing 7000 pounds over the Rockies is hard work for any engine no matter what the commercials say.
2017 Mazda CX5
Havoline Pro DS 0w20
Roki OEM filter.
Re: Oil and filter 9000miles trip with 7000lbs trailer. [Re: MagneticFX] #5118334 05/28/19 02:38 PM
V
volk06 Offline
V
Personally with that trip and towing, I'd use M1 or Edge 0w-40, if you do not care about the required weights. If you want to stick with a 5w-20, I'd get M1 EP or Castrol Edge, as edge is a very thick 20wt.
2011 F-150 Ecoboost
2012 Focus S
2001 Taurus
Re: Oil and filter 9000miles trip with 7000lbs trailer. [Re: MagneticFX] #5118363 05/28/19 03:08 PM
carviewsonic Offline
That's severe service IMO, so I would run a full syn 5W30, and change at 7-8000 kms during the trip.
'18 Impala
'05 Park Avenue
'03 Park Avenue
'07 Honda Accord
'09 VStar 1300
Re: Oil and filter 9000miles trip with 7000lbs trailer. [Re: MagneticFX] #5118367 05/28/19 03:14 PM
J
JC1 Offline
J
I'd go with PUP 5W-30 and the Fram Ultra. Leave it I for the full trip.make sure you check the level and top it up if necessary.
2015 Grand Caravan SXT Plus 5w-30 Valvoline White Bottle/Fram Ultra Filter
1997 Honda Civic CX 5w-30 Shell Conventional/Fram Ultra Filter
Re: Oil and filter 9000miles trip with 7000lbs trailer. [Re: MagneticFX] #5118370 05/28/19 03:16 PM
H
hemitom Offline
H
i see you are another brother from Ontario.
i'm from the east and have been on the 0w30 kick , easy winter starts even unaided down to -30 and more than ample summer protection.
Thinking i will stay with 0w30 from now on.
I'm sure its the best of both worlds for your up and coming trip.
2009 Saturn Vue.
2015 Mustang GT Convertible.
Re: Oil and filter 9000miles trip with 7000lbs trailer. [Re: PimTac] #5118377 05/28/19 03:23 PM
M
M
I will change oil at 4000-4500 miles thats should be 1/2 of the trip.
Re: Oil and filter 9000miles trip with 7000lbs trailer. [Re: MagneticFX] #5118380 05/28/19 03:27 PM
U
UncleDave Offline
U
Whatever brands grade and filter you settle on - you'll benefit from a magnet on the filter- or anywhere you can put one.
That little small block is going to be screaming its guts out and those cam chains and valve train flying- it behooves you to keep as much iron out of them as you can.
In my Nissan titan I run 5/10-30, or 0w40 , an ultra, a filtermag, and a magnetic drain plug. Mostly these brands- M1/M1EP/PP/Idemitsu
The titan is a shear beast as (Im guessing the coyote is as well especially with a DI pump) and it shears M1 0w-40 out of grade in 7500 miles of towing.
I haven't leaked it down but in 100K of mostly towing miles from 3500-9K through the brutal az desert - it still doesn't consume oil, smoke and mileage is identical to what it was at 3500.
UD
Uncle Dave
Cat 3126/2 MB3500/Titan/RX400H/17 Ridgeline
700HP V10/ 725HP BBC/ Raptor 700/ KFX450/ YZ250/Onan 8K/ Cat3011C
Re: Oil and filter 9000miles trip with 7000lbs trailer. [Re: MagneticFX] #5118382 05/28/19 03:28 PM
M
Mainia Offline
M
5w-30
Re: Oil and filter 9000miles trip with 7000lbs trailer. [Re: diyjake] #5118383 05/28/19 03:29 PM
M
M
Iwould change the oil filter with a Fram Ultra, much better filter than the Purolator Boss.
Can you tell me more about the difference F ultra / P Boss, ( Media microns?! )
Re: Oil and filter 9000miles trip with 7000lbs trailer. [Re: MagneticFX] #5118389 05/28/19 03:40 PM
GumbyJarvis Offline
The main difference is people have a hatred towards Purolator due to the semi recent tearing issues in their regular/classic filters.
As someone who’s been on here since the days of “Use Purolator not Framz!” People are gonna say what they’re gonna say, and there’s always a slight bias toward one brand of oil or filter.
AFAIK, the boss hasn’t had issues with tearing, and is more than likely just as good as a ultra in this case.
Find a ford spec 5w30, use it, with the hauling I’d find something with a good lump of Moly in it, which is more than likely going to be a SOPUS product
I’d use QSUD 5w30 or Pennzoil Platinum 5w30 and a decent filter
In this case, if I did use a Fram, a tough guard will be both cheaper and more than enough for the job at hand.
I swear the love for fram ultras on here is crazy, they’re good filters, but yeesh, people just say “filter” and people scream “FRAM ULTRAS!!” Y’all probably use them on your lawnmowers and weed trimmers too.
OP just find a filter rated for your severe service oci and call it a day.
Edit: now might even be a good time to try the new Rotella Gas Truck 5w30!
OEF 2013-2014
Page 1 of 4 1 2 3 4
