Please explain beta ratios. I'm lost.
by tony1679 - 10/16/19 12:45 AM
Is sump pumps necessary?
by joy786 - 10/16/19 12:18 AM
Sensen Struts - Any Good?
by Nick1994 - 10/15/19 11:54 PM
Quiet Oil--Cause?
by jimbrewer - 10/15/19 11:05 PM
IFJF (Chinese Magnefine)
by mcwilly - 10/15/19 10:40 PM
Let the truck warm up?
by Dragon44 - 10/15/19 10:14 PM
6.4L Powerstroke under the knife
by clinebarger - 10/15/19 10:01 PM
Alternatives to SAE 90 gear oil?
by qwerty11 - 10/15/19 09:34 PM
2010 Infiniti G37x Feedback?
by maverickfhs - 10/15/19 09:30 PM
M1 0W20 High Mil 40C visc
by Silver - 10/15/19 09:14 PM
Havoline 6 Qt Box $11.99 / Free Shipping
by Mr_Luke - 10/15/19 09:02 PM
Oil Recommendation for LS7 Z06 Street & Track Usage
by randomhero439 - 10/15/19 08:46 PM
QSUD 0W20 in 5qt jugs
by faltic - 10/15/19 08:41 PM
Mission Impossible: The Giraffe
by MONKEYMAN - 10/15/19 08:20 PM
Alternative to 10w-40 in Rotella?
by qwerty11 - 10/15/19 08:18 PM
Oil Changes and Ramps
by perfect_oil - 10/15/19 07:50 PM
Where to use T4 15W-40 in a 10W-30 World?
by Astro_Guy - 10/15/19 07:37 PM
How Does Toyota Do It?
by lovcom - 10/15/19 07:29 PM
ARedStart, viper74656, Tar, cast71, bamadog1
69573 Registered Users
53 registered members (billt460, 2015_PSD, AlienBug, Bailes1992, 4WD, 8 invisible), 903 guests, and 15 spiders.
Topics296,029
Posts5,089,587
Members69,573
Most Online3,532
Jul 30th, 2019
Page 1 of 3 1 2 3
Help me evaluate this used car inspection - 2003 Civic LX (Long post) #5114027 05/23/19 09:44 PM
O
Oro_O Offline OP
O
So about a week at I asked here for some tips about a used 2003 civic, a first car for a 16 year old. A neighbor has one to sell on behalf of a friend who moved to Alaska. Got some good advice. Today I drove it and inspected it closely (pulled plugs, put it on jacks and crawled underneath, etc.). If we get it I'll go find a good Honda forum to ask specific questions - but for general stuff I always get good answers here I have found. I know cars but not Hondas. They were asking $1500 which is close to private party Edmunds price for a clean car that needs little ($1400 they said), BUT car prices around here are usually way above "book" prices (Seattle). Looking on CL there isn't anything in price like this, or it needs more work.
Since the owner is gone, complete story is unknown. He was a recent immigrant from Russia they were helping get on his feet; he bought the car from a mechanic who had it for several years was the story (inspection supported that). Even were he here, I'd not learn much more I think. 182k, Silver LX w/cloth interior and auto. Per some advice from my 1st question, I dug deeper into the AT on these and found the 01 and 02 ones had issues, but the TC was redesigned by 03 and it's not as prone to issues. This is an 03 I verified on the title (clean, not salvage or anything).
Good things I found:
- minimal evidence of body repair, front end at some point (new lower valance and re-sprayed hood and fenders, LF headlight newer than RF based on some yellowing in it), decent quality job.
- Quality NGK laser platinum plugs looking perfect. Peak inside oil fill cap shows what valve train I can see is super-clean.
- Tight suspension, looks like new 1/2 shafts, struts, and LCA's at some point, bearings, ball joints, tie rod ends all tight, new sway bar bushings.
- Evidence of mild oil leak in the past but new valve cover gasket, so likely no more.
- All fluids look ok and not totally ignored. AT fluid was clean and correct color, not totally worn.
- No bad tears or stains inside, can clean up OK, just replace the center armrest cover (latch broken and a little stained).
- No codes, pending codes, etc.
- AC works acceptably and all climate control all ok.
- Brakes felt good, front rotors not that old, pads have good life left
- Car drives nicely, with good suspension, steering, AT works perfectly.
- New tires, only 5k on them (budget all season tires - "Caldera"? or something). Borbet alloy wheels.
- Can clean up and look decent inside and out; body issues minor, paint ok, interior OK.
- Observation: Someone has done quality maintenance/upkeek on this car for a while.
Negatives:
- Car does not rev past 5,500; stutters (red line is 6,800). I do not think they even knew this as you wouldn't normally wring it up to that rpm.
- Some minor body dings, nothing terrible - long but thin dent on driver's door the worst. Not terribly noticeable.
- Unknown Timing belt history (might be able to get ahold of prior mechanic owner; not sure if I can).
- Central locking system has a problem - Key won't turn in driver's door. System works from inside car though if I manually pull the knob.
- Driver's seat rocks slightly. Maybe a broken mount? could not see and did not remove lower trim to fully check it out.
- Air bag light is on.
I am thinking to negotiate a little and address the issues. Here's what I think and would like ideas; I have to figure out totally what I need to do as money is really tight and insurance is going to hurt a lot. He won't get a license for 6 months so I have plenty of time to address things.
Rev/stutter - I think it's a partially clogged cat, but not positive. I saw this in a friend's Accord I fixed, it was a solenoid in the variable valve control body BUT that consistently and immediately through a code. There are no codes. Cars I have seen with cat issues, it comes on more gradually; this is more abrupt. It kinda feels like a rev-limiter; I'm not sure on this issue. Replacing the cat on this engine does not look very hard and I'll go price one, but have to figure out exactly what is going on.
Central locking - probably not a big deal, an actuator or something, but confused why the key won't turn.
Seat - Worst case I imagine is a cracked mount ear; pull seat and get it welded (I don't weld unfortunately. I should learn - maybe I'll make this the reason).
Airbag - I assume it has an airbag in it - I didn't pull the cover. I guess the airbag deployed when the front was damaged. Have to figure this out and I'll have to get advice on how to figure this out.
Timing Belt - if I can't get the history, I can pull the cover and eyball the belt and wp and guesstimate it. Given the obvious good maintenance I am guessing it has been done once and is not way over due. If it comes up on my watch I have no trouble doing that.
If I can solve the things I found, this seems a good car to me, as someone has done a lot of the things that need done at this mileage. I really don't think I can get anything as decent close to this, or it would need even more work. Also, does anyone know the best Honda forum for asking advice?
Re: Help me evaluate this used car inspection - 2003 Civic LX (Long post) [Re: Oro_O] #5114032 05/23/19 09:49 PM
slacktide_bitog Offline
Doesn't seem much better or worse than other cars in that price range.
Is that won't go over 5500 rpm when in park, or actually when driving? Some cars do have an earlier cutoff for cars in P
The car is probably worth it and as good as any other car in that price range.
Re: Help me evaluate this used car inspection - 2003 Civic LX (Long post) [Re: Oro_O] #5114033 05/23/19 09:50 PM
Marco620 Offline
At 1500.00 I would buy it and do the regular drain and refills along with timing belt/waterpump. All cars have issues even those at Barrett Jackson I imagine.
15' Civic 1.8 i-vtec 273,000 mi Redline 0w20, BP CVT Fluid,Redline Si-1
Doberman Whisperer!
Redline Oil,Honda,Doberman,CZ & SONY Aficionado
Re: Help me evaluate this used car inspection - 2003 Civic LX (Long post) [Re: Oro_O] #5114035 05/23/19 09:52 PM
Marco620 Offline
Around here a truck that runs at minimum will fetch 2 grand.
Doberman Whisperer!
Re: Help me evaluate this used car inspection - 2003 Civic LX (Long post) [Re: Oro_O] #5114038 05/23/19 09:56 PM
2
2010Civic Offline
2
The airbag light would be my biggest worry. They can be hard to figure out.
2010 Honda Civic LX
Valvoline SynPower 5w-20 - Napa Gold oil filter
59,992 miles
Re: Help me evaluate this used car inspection - 2003 Civic LX (Long post) [Re: Oro_O] #5114042 05/23/19 09:59 PM
T
TheLawnRanger Offline
T
I agree with the others. You could likely use the negatives to get 2-3 hundred off. However, the asking price sounds fair.
2011 Impala
2012 Colorado
Oil: 5w30 synthetic
Filters: Wix 51522 for both
Re: Help me evaluate this used car inspection - 2003 Civic LX (Long post) [Re: Oro_O] #5114043 05/23/19 10:00 PM
JohnnyJohnson Offline
Yes but you have to understand in Seattle a car in tent city is a status symbol.
2004 Corolla 136159
Out: EDGE EP 5W-30 Bosch 3311 7156 Miles
In: Havoline Pro DS 10w-30 Purolator PureOne 3-14-19 129693
2006 Duramax 76552
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: Help me evaluate this used car inspection - 2003 Civic LX (Long post) [Re: Oro_O] #5114046 05/23/19 10:05 PM
R
rubberchicken Offline
R
Check the title- it might be a salvage or reconstructed vehicle, so that is a $$ ding, possible negotiating point. As a first car for a 16 year old, it needs to be disposable: most kids are going to tear it up in the first 6-18 months.
Re: Help me evaluate this used car inspection - 2003 Civic LX (Long post) [Re: Oro_O] #5114067 05/23/19 10:22 PM
L
Leo99 Offline
L
I use the rule of 10 cents per mile. At $1500, if you get 15000 miles out of it, you've done good. Therefore, if the car will go 15000 miles, those imperfections are not a big deal.
Without data you're just another person with an opinion. W. E. Deming
2003 Corolla 250,000 miles (RIP)
2004 Corolla 125,000 miles
2004 Rav4 392,000 miles
2015 Camry 90,000 miles
Re: Help me evaluate this used car inspection - 2003 Civic LX (Long post) [Re: Oro_O] #5114087 05/23/19 10:58 PM
P
pezzy669 Online Content
Online Content
P
The seat rocking was a common issue on the 7th gen even when they were brand new, I imagine there were some owners that either did not notice it or just overlooked it. I test drove brand new '02 Civic EX coupe with ~17 miles on it where the drivers seat ever so slightly rocked back and forth during shifts, acceleration and braking. Drove me up the wall. Felt like an old school desk chair with a couple of the screws holding the seat down were a turn or two loose.
2012 Volkswagen Jetta Sportwagen TDI - 69k - Castrol Edge Professional LL03 5W30
2011 Volkswagen Jetta Sportwagen TDI - 49k - Castrol Edge Professional LL03 5W30
Re: Help me evaluate this used car inspection - 2003 Civic LX (Long post) [Re: 2010Civic] #5114099 05/23/19 11:12 PM
O
Oro_O Offline OP
O
That is my biggest worry, yes. I can sort the rest. I actually don't think the airbag deployed. The wheel wear matches everything else, it's not a lot newer. And the front body work is not that old, and it's well done so likely insurance and they would have covered the airbag correctly. I can't have him driving around w/o an airbag.
I agree with most all comments. The title is clean, btw. The rev thing happens in gear or in N sitting still. I took a video of it w/my phone and will see if I can link it. And that seat rock is not dangerous, but dang it would drive me crazy. I know I can fix it somehow.
It can be a really decent, respectable car and still cheap enough to meet that "disposable" criteria, so that has me pleased.
Re: Help me evaluate this used car inspection - 2003 Civic LX (Long post) [Re: Oro_O] #5114104 05/23/19 11:30 PM
P
Online Content
P
I agree with most all comments. The title is clean, btw. And that seat rock is not dangerous, but dang it would drive me crazy. I know I can fix it somehow.
Don't forget to look to see if Takata airbag recall has been done, if not you might luck out in that one of the inflators is causing the airbag light and the replacement airbags may fix it. Might be worthwhile to find someone who can read the airbag module to see what is causing the fault.
Re: Help me evaluate this used car inspection - 2003 Civic LX (Long post) [Re: pezzy669] #5114123 05/24/19 12:39 AM
O
Oro_O Offline OP
O
I will have to see how to scan the airbag codes, I just read on a forum that was possible somehow.
I think I have a good guess now, though. I did some googling, apparently it's probably not the airbag that is the issue, it's the seat belt, or possibly a connector. There's a sensor in the female end of the buckle, and it lights that off if the seatbelt isn't fastened. They fail quite a lot. There's an open recall on this, so you can go get it repaired at a dealer free. Apparently it's a real nagging issue and the fix is poor - some people said they've had it done three times.
Another person said their light was on because there is a seat position sensor in the driver's seat. It has two yellow connectors under the seat and if they are disconnected, this also lights this light. When I was trying to see why the seat rocked, I looked under the seat and I did notice two yellow connectors, not connected. I assumed they were for heaters or some option not installed, but wondered why they were on the underside of the seat and not coming out of the floor (made no sense). I bet that's it, or the belt sensor like many others. I'll check the Takata issue, too, good point.
So that just leaves the 5,000 cut out to figure out; I bet that's easy for someone who knows these engines. I'll post the video on a Honda forum somewhere and once I have that.
This is the car:
[Linked Image]
Re: Help me evaluate this used car inspection - 2003 Civic LX (Long post) [Re: Oro_O] #5114125 05/24/19 12:45 AM
dishdude Offline
That's a really clean $1500 car. That will sell fast.
2018 Challenger SRT 392 PUP 0w-40 Wix 57899XP
2018 GTI M1 Euro 0w-40 Wix WL10024
2019 Tiguan
Re: Help me evaluate this used car inspection - 2003 Civic LX (Long post) [Re: dishdude] #5114142 05/24/19 01:25 AM
O
Oro_O Offline OP
O
It's not being advertised yet so we don't have to jump instantly. The (proxy) seller is a close friend and will wait to hear what we say.
More sleuthing and I think the rev issue may be solved - oil level. I played the video on my phone and saw it was a hard stop at 5k, which I didn't notice as precisely while driving. Also, the cat idea didn't play well in my mind after I looked at the plugs, and also the tail pipe was pretty clean, I couldn't see enough oil ever burning to damage the cat that badly even in 180k miles.
I googled "civic 5k rev limit" and saw that is "limp mode" which is an ECU cut-out if Vtech codes present, oil pressure too low, in neutral/park (as someone said above), or oil level too low. I have no codes and no oil pressure light, and it did it both driving and parked. But when I looked it over hard after I got back, I noticed the oil was a tad low (just below the low mark). I topped it up but I didn't try revving it hard again. Apparently oil just a bit low will trigger the cut-out. I'll try that on Sat. when I have a chance again and hopefully we are good.
If those work out, then it leaves only the central locking to sort out besides some cosmetic issues. I know the locking can be annoying but is not bad. So if I can get the belt/airbag light off on Sat and rev it fully, then we are good to go. I mean, we'll probably take it anyway; I just want to know what I need to fix and costs.
Page 1 of 3 1 2 3
