My latest battery load test
by Char Baby - 10/22/19 05:18 AM
MB Loctite 5970
by The Critic - 10/22/19 01:18 AM
Amazon Special on Lubegard LXE
by Marco620 - 10/21/19 11:42 PM
ATF Life in Sealed Bottle
by ZeeOSix - 10/21/19 11:34 PM
Pumpkin Pie
by kstanf150 - 10/21/19 11:18 PM
Delphi ecu and segment swap
by P10crew - 10/21/19 10:06 PM
Close Call!😨
by Mad_Hatter - 10/21/19 10:06 PM
12 bolt truck rear
by P10crew - 10/21/19 09:57 PM
More painful motorcycle hill climbing footage
by Reddy45 - 10/21/19 09:57 PM
Charging for parking
by madRiver - 10/21/19 08:59 PM
OxyClean car wash
by dawgn86 - 10/21/19 08:58 PM
Oil Catalogue Idea
by GaryPoe - 10/21/19 08:51 PM
Liqui Moly longtime vs 4605
by jkhawaii - 10/21/19 08:17 PM
Name a good alcohol wine/beverage for a beginner.
by Vern_in_IL - 10/21/19 07:06 PM
Pulling a bumper pull keystone outback
by ram_man - 10/21/19 06:54 PM
Another fuel mileage thread
by tiger862 - 10/21/19 06:54 PM
Winter Truck: RWD w/ locking diff OR 4x4 w/o locking diff
by PotatoFarmer77w - 10/21/19 05:36 PM
M1 ESP 0W30 (8200 km run for an 2018 VW Golf R)
by 21Rouge - 10/21/19 05:11 PM
Allis Chalmers 50/50 4X4
by mem - 10/21/19 05:03 PM
Finner, Haiducek, NoRegrets, SouthDakotaDad, StaceyWoolsey
69640 Registered Users
58 registered members (BigCahuna, 2015_PSD, atikovi, Bailes1992, 2002 Maxima SE, 5 invisible), 1,021 guests, and 19 spiders.
Topics296,310
Posts5,095,351
Members69,640
Most Online3,532
Jul 30th, 2019
Craftsman floor jack rebuild #5113488 05/23/19 01:14 PM
I
i6pwr Offline OP
I
Surely enough as I'm nearing the end of my rod bearing replacement, my floor jack decides to start leaking down.
This is the jack, has anyone rebuilt these and/or replaced any seals?
I can crank the handle down as hard as I can but it will slowly drop with weight on the cup.
I don't think its low on oil, but possibly.
All input appreciated.
Re: Craftsman floor jack rebuild [Re: i6pwr] #5113499 05/23/19 01:25 PM
M
maxdustington Offline
M
Check out the jack repair threads on The Garage Journal. Import jacks seem to be fairly generic, so you can probably rebuild it. Old imports might be worth it (1970s-1980s), but new ones probably aren't unless you are looking for a project. You might need a pin spanner to get the tank nut off, but this one might not require that tool.
97 GMC RCLB K2500LD L30/4L60
Re: Craftsman floor jack rebuild [Re: i6pwr] #5113528 05/23/19 01:46 PM
T
Touring5 Offline
T
That looks exactly like my (leaky) Craftsman jack. I got mine around 2003? I happened across a video that explained how to replace the o-rings, but I could never get the nut off the cylinder. I believe these jacks are examples of how far Craftsman had fallen - just Chinese jacks painted and labeled for Sears. As I recall the jack only had a 90-day warranty.
https://m.youtube.com/watch?v=vIp8GO5PIFA
FIRST LAW OF DEBATE
Never argue with a fool - people might
not know the difference.
Re: Craftsman floor jack rebuild [Re: i6pwr] #5113582 05/23/19 02:33 PM
Dave9 Offline
^ How far they've fallen? I consider it reasonable service life to get 16 years out of a *budget* jack before it needs repaired.
I have an older version of that C-Man, back when they made them just as sturdy but were rated for only 2.(something) tons and were light silver with a black handle.
I do recall that once I had my C-Man on its side or upside down or something (I was cleaning it, IIRC) and had to bleed air out and top off the fluid to get it to stay up, and it has worked fine since then.
Definitely try to bleed it and top off the oil before planning a rebuild. It also looks like it could use some cleaning and lubing from the second pic.
Re: Craftsman floor jack rebuild [Re: i6pwr] #5113585 05/23/19 02:36 PM
DoubleNickels Offline
Hydraulic fluid is not leaking. Maybe it's all leaked out.
First, purge air from the system. Then top off fluid. Now clean off exterior and lubricate all moving parts. If all is well, it will work. If not, you will see the leak. If there's a leak, you will need new seals, gaskets, and o-rings.
Re: Craftsman floor jack rebuild [Re: i6pwr] #5113611 05/23/19 03:05 PM
I
i6pwr Offline OP
I
I agree it's not the cleanest, I had just finished R&R my oil pan to replace rod bearings, and the jack has seen its share of fluids from the vehicle during the whole process.
It will lift all the way up, just won't hold a reasonably heavy load...over maybe 100 lbs. It will very, very slowly leak down, holding up a crossmember under the trans, it leaks down about maybe 1/4" per second.
It has a rubber plug on the cylinder and if I try to pry it up I can hear air either escaping to trying to enter.
Re: Craftsman floor jack rebuild [Re: i6pwr] #5113635 05/23/19 03:20 PM
Yah-Tah-Hey Offline
You can find rebuild kits on the internet. I have a Craftsman 2 ton floor jack purchased in the 1980. Have changed fluid regularly. One thing I have noticed is the jack will puke oil out the fill plug if filled with too much oil. Search for repair kits by entering your jack's model number.
Re: Craftsman floor jack rebuild [Re: i6pwr] #5113660 05/23/19 03:43 PM
CT8 Offline
Buy a new jack.
2015 F150 2.7
2018 F350 6.2
Re: Craftsman floor jack rebuild [Re: Touring5] #5113774 05/23/19 05:36 PM
M
M
They were rebranding Japanese jacks as early as the late 1960s IIRC. 1970s for sure.
Re: Craftsman floor jack rebuild [Re: i6pwr] #5113779 05/23/19 05:41 PM
KJSmith Offline
Re: Craftsman floor jack rebuild [Re: i6pwr] #5113791 05/23/19 06:01 PM
O
OnTheRocks Offline
O
Start with cleaning and lubricating. Get fresh fluid. Be sure to buy hydraulic fluid sold as jack oil. Do not substitute with transmission fluid, motor oil, brake fluid, or anything else you think will work. Drain the jack. Add fresh fluid. Purge air. Then top off the jack. You may not need to rebuild at all. Plenty of videos online showing you how to purge the air and refill the jack.
Re: Craftsman floor jack rebuild [Re: i6pwr] #5113844 05/23/19 06:52 PM
H
HangFire Offline
H
In rebuilt my 3-ton, 1990's, Japan built floor jack over the New Year's holiday. Half the battle is identifying the right parts kit. It will come with extra parts, for similar jacks, which always makes it interesting. For my jack, the main problem was the large seal at the end of the ram had shrunk over time. I replaced everything soft, and the ball bearings. Should be good for another 30 years.
I got my kit from Lazzar's Floor Jack aka HCRCnow.com. If you can't identify the jack from their website and your jack markings, give them a call.
When my jack started bleeding down, everything in my garage ground to a halt. I almost purchased a HF jack, glad I didn't. I spent $60 for a rebuild kit, would have spent $90 for a HF jack, but it wouldn't be the rebuildable plate steel 85 pound beast that this thing is.
jackfix_10x7_143552095.jpgjackfix_10x7_144734453.jpgjackfix_10x7_175237323.jpgjackfix_10x7_175243948.jpgrings_10x7_BURST001.jpg
Various musings: http://hangfire.net
Re: Craftsman floor jack rebuild [Re: i6pwr] #5113880 05/23/19 07:21 PM
O
OnTheRocks Offline
O
At the heart of almost every piece of hydraulic lift equipment - pallet jack, floor jack, et cetera - there is a simple bottle jack or similar operating system. Fluid in one reservoir, gets pumped into another reservoir, whereby pushing a piston. Almost every one I've seen is the same. Those pieces all have gaskets, seals, and o-rings. These wear items eventually give out, and fluid leaks. Even if you can't find your jack model - and you should be able to since that Craftsman jack is so common that hundreds of thousands were probably sold - you can always take any jack apart, then order the seals, gaskets, and o-rings by diameter size. Parts sellers will have a whatever diameter gasket, if you ask for it. A gasket, seal, or whatever, will work in any and every jack, as long as you are using the correct size.
Re: Craftsman floor jack rebuild [Re: i6pwr] #5113959 05/23/19 08:30 PM
P
philipp10 Offline
P
oh I'm sure if you had changed the oil on a regular basis you wouldn't be having these issues.....but don't go and have a flush now....much too risky... crush
Re: Craftsman floor jack rebuild [Re: i6pwr] #5114112 05/23/19 11:52 PM
G
Gasbuggy Offline
G
How often should you change the hydrauilic fluid?
Cadillac CTS-V 6.2L 10w30PP
Volvo P1800 Euro L
76 Mercedes 300D Rotella T4
Series III Land Rover VWB
02 Yukon 10w30 PP
01 P71 M1 EP-HM 0W20
95 Accord - 386k. Mobil 2 RIP
