Dodge Ram 2500 Transfer Case leaking
by diyjake - 09/19/19 11:24 AM
Have you seen anything like this?
by JDubyah - 09/19/19 11:06 AM
Valvoline Premium blue, Ram 3500
by TOLSON - 09/19/19 10:55 AM
Little engine, big filter
by brages - 09/19/19 10:54 AM
Thoughts on adding AC/Heat to attached garage.
by FADEC - 09/19/19 10:31 AM
What to do with old cores?
by Brybo86 - 09/19/19 09:49 AM
Which additive for best MPG?
by cwilliamsws6 - 09/19/19 08:25 AM
Clock radio lights failing on '08 Honda CR-V
by dpaldino - 09/19/19 08:14 AM
16 F150 3.5EB ~8K VPB 15W40
by BeerCan - 09/19/19 07:55 AM
Old skool carburetor rebuilding.
by Chris142 - 09/19/19 07:50 AM
Construction - Vintage Warning
by MasterSolenoid - 09/19/19 06:55 AM
Toro 12-38
by supton - 09/19/19 06:36 AM
EV tuktuk batteries
by Superflan - 09/19/19 02:09 AM
Car engine issues
by Espada - 09/19/19 01:12 AM
2002 chevy tahoe 5.3 oil selection
by Zahndkile - 09/19/19 12:20 AM
Considering Solar
by mbacfp - 09/18/19 11:16 PM
2008 Duramax
by Firemedic15 - 09/18/19 11:02 PM
Fleetguard LF777 performance
by Pyrotechnic - 09/18/19 10:54 PM
Any Vacuum experts? :)
by maverickfhs - 09/18/19 09:50 PM
15 F150 Gear & Transfer Case Question
by BISCUT - 09/18/19 09:24 PM
JDubyah, 05SentraRed, TSpinner, bbrown, Firemedic15
69326 Registered Users
119 registered members (4WD, aquariuscsm, Andrei, Alfred_B, 2015_PSD, anonobomber, 14 invisible), 2,114 guests, and 29 spiders.
Topics294,775
Posts5,066,346
Members69,326
Most Online3,532
Jul 30th, 2019
Remove baseboard moulding for floor planking? #5112280 05/22/19 11:06 AM
J
JLawrence08648 Offline OP
J
I want to install snap together vinyl floor planking on a concrete slab. Wouldn't I get a better job where I wouldn't see the cuts at the ends if I removed all the baseboard moulding? This way I would not have to be to concerned about being so precise with my end cuts as they would be covered by the moulding. Also it seems no matter how careful and concerned I am with my cuts, there are going to be some cuts you will still see a space between the end and the moulding if the moulding is not removed.
Re: Remove baseboard moulding for floor planking? [Re: JLawrence08648] #5112286 05/22/19 11:13 AM
PimTac Offline
It is always best to remove the baseboard. There should be a small gap between the flooring and the wall. The baseboard covers that. When you remove the baseboard number the board itself and the wall behind it to make the reinstall easier.
2017 Mazda CX5
Havoline Pro DS 0w20
Roki OEM filter.
Re: Remove baseboard moulding for floor planking? [Re: JLawrence08648] #5112288 05/22/19 11:15 AM
K
KGMtech Offline
K
Yes, you have the right idea. Additionally if there is any expansion / contraction of the new flooring, having the end cuts hidden by the baseboard keeps any gaps from showing. A little work ahead of the project means a very nice look forever afterwards. grin2
2017.5 Nissan Rogue SV FWD
2013 Nissan Maxima SV
2009 Ford Flex SEL FWD
1984 Yamaha XJ750RL
Re: Remove baseboard moulding for floor planking? [Re: JLawrence08648] #5112296 05/22/19 11:26 AM
sloinker Offline
Replace the baseboard with something extra thick to help hide your poor cuts....j/k
'16 Tiguan TSI Ravenol VST 5W40
'15 VW Golf TDI Ravenol VMP 5W30
'15 VW Golf Sportwagen TDI VMP 5W30
'14 Dodge Grand Caravan 3.6 Red Line Blue Label 5W20
'64 Plymouth Fury440 Red Line Blue Label 10W40
Re: Remove baseboard moulding for floor planking? [Re: JLawrence08648] #5112321 05/22/19 11:47 AM
M
maxdustington Offline
M
Yank the baseboard or install quarter round after. You need to have somewhat ornate baseboard for quarter round to not look out of place.
It sucks that you had to learn that the hard way, but you will probably be able to re use those pieces you cut too short depending on how far along you are.
Make sure you cut the top edge of the baseboard with a knife so you don't tear the paint off the wall when you pull the baseboard.
03 Jetta AWP/09A 210k kms
Edge 0W40 + Mann 719/30
Re: Remove baseboard moulding for floor planking? [Re: JLawrence08648] #5112332 05/22/19 11:59 AM
Dave9 Offline
Of course, that's why it's there. I wouldn't expect much expansion and contraction compared to wood, but you're always better off a couple millimeters too short than too long.
Re: Remove baseboard moulding for floor planking? [Re: JLawrence08648] #5112363 05/22/19 12:29 PM
ls1mike Offline
I have done a bunch of laminate and always remove the baseboard. Makes it easy and hides the gap required by luxury vinyl plank and laminate type floors.
Mike
00 Trans Am WS6 5.7 LS1
17 Silverado 3500HD 6.0
14 Caprice PPV 6.0
15 Malibu LTZ Turbo
12 Passport TT
Re: Remove baseboard moulding for floor planking? [Re: JLawrence08648] #5112390 05/22/19 01:13 PM
J
JLTD Online Shocked
Online Shocked
J
Yes, baseboard off then reinstalled above the new flooring.
I use the overseas manual to choose my oil viscosity.
Using AMSOIL
Hers: 2008 Jeep Liberty 149k, SS5w30/Amsoil
His: 2015 4Runner 55k, SS 5w20/Amsoil
Re: Remove baseboard moulding for floor planking? [Re: JLawrence08648] #5112562 05/22/19 04:03 PM
sdowney717 Offline
I just did our downstairs. I used Lowes smartcore ultra blue ridge pine color.
It is 100% waterproof, does not expand or contract with humidity, instructions have no mention of keeping a gap between floor edge and walls, like they do with other kinds of flooring.
I removed all base boards.
One trick in hallways and doorways, cut the piece so you know it will fit, then slide the piece under the floating floor, and bring it up into position around the doorway and lock it in. The doorway side molding, I did not wish to remove and when your finishing the last row, there is no way you can clear it any other way.
And if you have trouble getting pieces together, you can somewhat warp it to start it fitting into the slot, and on long rows, if you get the end going in then keep on tapping it down the entire plank and it will slip together. I had several small cut offs I locked into planks I was tapping to fit, and of course the flat black bar. I used a 3 lb sledge hammer to whack things together. You will know your fully together, when it is fully flat and tight, no light colored seam showing on plank edges.
I like it a lot, it is very flexible, so it conforms to the floor. It has texture ridges in the surface.
One thing, be careful to make sure edges are locked tight. I had to fix an area because I had not locked planks together all the way.
That was not fun pulling out flooring pieces.
https://www.lowes.com/pd/SMARTCORE-...-Locking-Vinyl-Plank-Flooring/1000196679
