Anyone with a golf cart?
by Pat in Speedway - 10/23/19 06:05 AM
Motorkote, Amsoil test says it has lots of chlorine
by sdowney717 - 10/23/19 05:53 AM
Buying Used BMW Checklist
by chims - 10/23/19 05:46 AM
Freedom 95 furnace doesn't keep house warm long
by laoshanren - 10/22/19 11:36 PM
2006 Altima 2.5 oil leak
by LeakySeals - 10/22/19 10:34 PM
fishing licenses on boats
by motor_oil_madman - 10/22/19 10:16 PM
Tokyo Motor Show 2019
by PimTac - 10/22/19 10:14 PM
More Quick Chargers
by Snagglefoot - 10/22/19 09:48 PM
'08 Chrysler Sebring Test Drive
by Fifth87 - 10/22/19 08:42 PM
Testing old coolant
by ARB1977 - 10/22/19 08:20 PM
Pennzoil Maximum Power 0W30
by HoosierJeeper - 10/22/19 07:44 PM
Bought a unknown air rifle and need help.
by jakewells - 10/22/19 07:26 PM
What happens to used cars that don't sell?
by WhyMe - 10/22/19 07:11 PM
No spark
by Eric Smith - 10/22/19 06:57 PM
So you need a new engine?
by Skippy722 - 10/22/19 06:40 PM
flyyamata, laoshanren, Vincenze, Alex_CB300R_ABS, TSOC
69652 Registered Users
53 registered members (bernau, AurionX2, billt460, Astro_Guy, BigShug681, 8 invisible), 920 guests, and 27 spiders.
Topics296,366
Posts5,096,389
Members69,652
Most Online3,532
Jul 30th, 2019
Sealant Suggestion #5112226 05/22/19 10:13 AM
L
Lubener Offline OP
L
I just replaced the water pump on my F150 4.9. Several mounting bolts went into the water jacket. One will not stop dribbling. I used Permatex 2 on the threads prior to inserting. Is there something better to apply to the threads to seal this up better?
The "thinking" man's friend.
Re: Sealant Suggestion [Re: Lubener] #5112244 05/22/19 10:28 AM
W
WyrTwister Offline
W
Are the bolts of different lengths ? Did you get the correct bolts into the correct holes .
I would use the non hardening Permatex . Is that # 2 ?
Did you use a gasket or sealant between the block & the water pump .
I would go get the non-hardening Permatex & a new gasket . A good , sharp gasket scraper ( I use a wood chisel from HF ) .
Remove the pump , lean the block and the fasteners . Coat the fasteners that go into the water jacket with the non-hardening sealant and use the sealant to " glue " the gasket to the pump ( gasket oriented correctly ) . I do not use sealant on the block side of the gasket . Much easier to remove the pump latter and less scraping .
Install the pump , with the correct fastener in the correct hole , tightening in a chis-cross pattern . Either torque the fasteners fown by feel or with a torque wrench .
Install the belt and any thing else you removed , fill it up and asd a prayer .
Please let us know how it turned out .
I drove small block Fords in the late 60's and 70's . I got fairly good at changing remain water pumps . Do not know how similar they were to your engine ?
Best of luck to you , :-)
Wyr
God bless
Re: Sealant Suggestion [Re: Lubener] #5112246 05/22/19 10:30 AM
CT8 Offline
If the threard are good in the block use teflon sealant link to product
2015 F150 2.7
2018 F350 6.2
Re: Sealant Suggestion [Re: Lubener] #5112269 05/22/19 10:49 AM
L
Lubener Offline OP
L
To add, all bolts were same length. I wire wheeled all bolts to clean them up. I applied the non hardening, permatex 2 to the bolt threads and a thin layer on both sides of the gasket. I had everything on the block very clean, sprayed a little brake cleaner on all surfaces and wiped.
Re: Sealant Suggestion [Re: Lubener] #5112293 05/22/19 11:19 AM
das_peikko Offline
Did you apply the Permatex 2 to the bolt threads only? I always apply it to the threads and the non threaded portion as well.
And I don't know how you put a thin layer on the gasket. The way the stuff is comprised and how thick it is, my gaskets always look like a frosted cake.
Re: Sealant Suggestion [Re: das_peikko] #5112330 05/22/19 11:59 AM
K
kschachn Offline
K
Of course if the gasket was designed to be installed with no applied sealant and you used it anyway, that could be the cause of your leak right there.
1994 BMW 530i, 246K
1996 Honda Accord, 280K
1999 Toyota Sienna, 420K
2000 Toyota ECHO, 284K
Re: Sealant Suggestion [Re: Lubener] #5112511 05/22/19 03:12 PM
L
Linctex Offline
L
Permatex #14 with PTFE is fanatastic
maybe good ol' "Ultra Blue" would also work great
