Firstly, apologies for another post on the topic of silicates and their potential harm to water pump seals, especially OEM Japanese/asian type.
Does anyone have experience or information on this?
Are the mechanical seals different, are the Japanese using a soft/hard (carbon/ceramic) mechanical seal faces & the Europeans a hard/hard (silicon carbide/tungsten carbide) seal faces, at least industrially hard/hard mechanical seals are specced where abrasive media is expected to be encountered.
Where I work we overhaul (electrically driven) cooling water pumps that run 24/7 at 5 year intervals, most make it without failure, using either nitrite/borate treatment or Radicool SF, these are not silicated, however they are large open systems that are not be free from some abrasive particles.
@Gene K had the below to share, an appreciated post.
And @paulo57509 had this interesting Honda information.
Does anyone have any information or experience to add?
“Silicates definitely affect water pump life. A large trucking fleet (thousands of trucks) had water pump failures drop by something like 78% after 1 year of running EC-1 Coolant. After 2 years it dropped to almost none. I used to have to replace water pumps every 200,000-400,000 miles. I have had trucks with over a million miles on the water pumps since EC-1 came out. As a matter of fact since going EC-1 I havnt had to replace a single water pump.”
FWIW, a copy of this was in with the paperwork I received when I get the Legend. While I don't use Honda branded coolant, I do use a non-silicate coolant.
