Thread Repair Question
by The Critic - 08/19/19 02:48 AM
Genuine Mercedes-Benz 229.5 5W-40 Engine Oil
by The Critic - 08/19/19 02:25 AM
Is it safe to use 100% synthetic
by Espada - 08/19/19 02:16 AM
Cobb Air Filter Cleaning
by The Critic - 08/19/19 01:58 AM
PCV side of the engine is cleaner
by OilUzer - 08/19/19 01:50 AM
Which is Better: Old or New Castrol Edge 0W-40?
by nielkfj - 08/19/19 01:18 AM
Discount Tire Warranty
by Maddog1337 - 08/19/19 12:26 AM
Mobil One Super Synthetic Euro 5W-40
by hellokitty - 08/18/19 11:26 PM
Help Me Search
by Gebo - 08/18/19 09:29 PM
2018 Camry Transmission Drain & Refill Procedure
by painfx - 08/18/19 09:11 PM
.325 pitch vs .375 pitch saw chain
by The_Eric - 08/18/19 09:04 PM
House buying opinions on houses.
by ram_man - 08/18/19 08:50 PM
How to get nails out of my driveway?
by Chris142 - 08/18/19 08:37 PM
Used cars imported from Canada to USA on the rise?
by BobsArmory - 08/18/19 08:28 PM
2010 Accord P1009 Code
by Phishin - 08/18/19 08:15 PM
Espada, samhainlimon, CrazyElf, mattkocanda95, HardCoreHawkFan
68995 Registered Users
22 registered members (billt460, ctechbob, Bailes1992, A_A_G, Boosted240, 4WD, 2 invisible), 610 guests, and 22 spiders.
Topics293,497
Posts5,041,229
Members68,995
Most Online3,532
Jul 30th, 2019
Page 2 of 2 1 2
Re: Alignment problem - help me understand [Re: SlavaB] #5084967 04/24/19 04:20 PM
A
ARCOgraphite Offline
A
The cross camber in front axle looks too large to me 0.4 deg, 0.8 deg. That's basically -1 deg neg on one wheel and -1/2 deg on the other. And its on the wrong side of the road crown for a beneficial countersteer up the crown.
2019 VW Jetta S 6MT OCI#1 5885mi-Castrol Edge Prof? VW508+VW Service Filter; '17 Subaru Crosstrek CVT OC#7 52665mi-Castrol GTX Magnatec 5W20 + SOA Filter
Re: Alignment problem - help me understand [Re: SlavaB] #5084970 04/24/19 04:22 PM
DuckRyder Offline
From a Kia Forum:
Quote
From the Kia Global Information System web site (all numbers are in degrees):
Front:
Toe-in (Individual) 0.05 +/- 0.05
Toe-in (Total) 0.1 +/- 0.1
Camber -0.5 +/- 0.5
Caster 4.60 +/- 0.5
King pin angle 13.96 +/- 0.5
Rear:
Toe-in (Individual) 0.1 +/- 0.1
Toe-in (Total) 0.2 +/- 0.2
Camber -1.0 +/- 0.5
The ? instead of a decimal is concerning (aside form the reading difficulty).
What kind of machine was this and was it actually set up on a rack and calibrated at the time of these pictures or was it one of those quick drive across set ups?
I agree that I would have installed the correct size tires, but depending on wheel size it might be fine...there is about .3 inches difference in height and 10 or so revs per mile. so its a small change.
Robert
  • 2019 Volkswagen Jetta R-Line
  • 2005 Honda Civic Sedan
  • 1972 F100 Ranger XLT (390/C6/9” 3.50 Truetrac)
  • 2002 Ford Ranger XLT 4D Supercab 3.0L
Re: Alignment problem - help me understand [Re: SlavaB] #5084988 04/24/19 04:34 PM
A
A
Have them check ride height too. I dintr understand the "leaning": issue. Is your car seat broken, maybe?
Or maybe you mean pulling to the right?
Re: Alignment problem - help me understand [Re: ARCOgraphite] #5085020 04/24/19 05:02 PM
SlavaB Offline OP
Maybe I've used the wrong term, sorry.
To describe better: when going straight on a highway in the middle lane, after I'm releasing the steering wheel - the car doesnt go straight but pulling to the right by itself.
So in order to go straight I keep adjusting it while driving.
17 Kia Sportage EX 2.4 GDI / Mobil1 5w20, OE 26300-35505
15 MB GLA250 4Matic 2.0T / Mobil1 0w40, Hengst E818H
Re: Alignment problem - help me understand [Re: SlavaB] #5085027 04/24/19 05:07 PM
A
A
Ahh . yes I saw too much inward tilt on your driver side wheel.
Tilt wheels steer the direction they tilt ( think motorcycle) and that wheel is tilted right MUCH more than the right wheel is tilted left.
Re: Alignment problem - help me understand [Re: SlavaB] #5085045 04/24/19 05:28 PM
DuckRyder Offline
Does it pull or lead...?
Pull = goes immediately
Lead = drifts after a short time.
The graphics and numbers on you report don’t make sense really, did they give you a printed report?
Robert
Re: Alignment problem - help me understand [Re: ARCOgraphite] #5085046 04/24/19 05:29 PM
SlavaB Offline OP
Now as you said it I see it too, somehow only paid attention to the fact it's in the green zone.
Will need to get it done properly somewhere else
Re: Alignment problem - help me understand [Re: DuckRyder] #5085050 04/24/19 05:32 PM
SlavaB Offline OP
1. Ok, I can't tell it jumps immediately into the right lane, but at the same time it's happening quickly.
2. I don't have any printed report, they only shared these pictures with me and a printed receipt
Re: Alignment problem - help me understand [Re: SlavaB] #5085056 04/24/19 05:39 PM
E
eljefino Offline
E
Could it be they haven't licensed and updated their alignment machine software recently?
Those guys suck.
Re: Alignment problem - help me understand [Re: SlavaB] #5085060 04/24/19 05:43 PM
das_peikko Offline
Any shop that has a big fancy machine with a color screen that prints out colored pictures --- doesn't know how to do alignments. I'm not the least bit impressed with those machines or the fancy pictures. Usually it's the tire shops that pull that kind of crap.
And any shop that talks the customer into going with a non-factory size tire are a bunch of hacks.
Re: Alignment problem - help me understand [Re: das_peikko] #5085073 04/24/19 06:01 PM
M
MParr Offline
M
Those guys suck.
What these guys said. Tire shops love to sell alignments, especially lifetime alignments and balances. That’s how they Hoover up lifetime customers. They get you in there and tell you this or that needs to be replaced or your tire or tires are wearing irregular and make another sale.
2019 VW Tiguan SE Now: Factory fill & OEM filter
2017 Ford Escape SE 2.0T Now: Motorcraft 5W30 SynBlend & NAPA Gold 1348
Re: Alignment problem - help me understand [Re: SlavaB] #5085196 04/24/19 07:54 PM
double vanos Offline
Tire size visual difference [Linked Image]
Sabine Schmitz is the Queen of the 'Ring; Svetlana Kapanina is the Queen of the SKIES...
Re: Alignment problem - help me understand [Re: ARCOgraphite] #5085935 04/25/19 12:35 PM
G
geeman789 Offline
G
And it might not be easily adjustable ... on many cars, the only adjustment available is toe. Which is why techs often see green and move on ...
2011 SUBARU Impreza 5-door manual / 2016 HONDA Pilot / 2011 MAZDA 2 auto
Re: Alignment problem - help me understand [Re: SlavaB] #5085968 04/25/19 01:41 PM
SHOZ Offline
My Gen Coupe has always pulled to the right. The caster was off with the left leading the right and is not factory adjustable. I got some adjustable tension rods and can slightly adjust the camber, enough to cancel the pull almost. Who knows what it really reads as I always have to do it after an alignment. Tires wear nice and even.
And if your strut uses two bolts on the bottom to attach to the hub, there are camber adjustment bolts you can buy that are eccentric and can usually get 2* more camber.
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
Re: Alignment problem - help me understand [Re: SlavaB] #5085975 04/25/19 01:50 PM
Chris6391 Offline
I have two sportages and do my own alignments as I saw the incompetence at Sears and Firestone. Not too hard. Mine are SM?? 05 and an 08. The wheel track is identical front and back.A straight level with a laser measured across the center of the tire shooting at a known distance target(ruler with a dot on it) from the center of the wheel hub mounted on a 2x4 does it for me. That's all the machines do. The only good thing they have is the tire plates. My way in the driveway I make an adjustment and pull it back and then forward to let the tires settle their footprint and take another measurement to see if I have it. Mine don't have camber bolts but my Sedona did and I just make sure I am on a level part of my driveway and use my level vertically up the tire away from the flex footprint area.
Page 2 of 2 1 2
