Originally Posted By: Pelican
Originally Posted By: Spector
Are you saying it is overfilled by looking at the invoice and seeing 6 liters or by looking at the dipstick? Either way though I would not be concerned, a minor amount. If invoice they charged you for 6 but may have only put in 5.7.
Thanks Spector, good point! On the invoice it says 6 litres, on the dipstick I can't tell, even though I looked in the morning after the car rested overnight I could not tell. Glad you confirm my feeling about not being concerned.
So you're telling us you couldn't even confirm an actual overfill on your dipstick? You were solely going off an arbitrary number typed onto the invoice? What a nothing-sandwich!!
Maybe we should start a post that lists all the engines that do or don't tolerate slight overfills. I know a few off hand. I know there are a few corvettes where the manual states that an extra quart of oil is ok when the car is being used on the track. My 2012 regal GS holds takes 6.5 quarts of oil to get to the full line. The 2013 regal GS listed a sump capacity of 5.something quarts and had a longer dipstick, but the manual stated that an extra quart of oil is ok when used on the track. It's highly probable both the 2012 and 2013 regal GS have same oil pan with a quart difference in stated capacity. I would also assume that the 2013 Regal GS would tolerate more overfill (on paper) than my 2012.
