Oils for old engines
by puma4440 - 02/25/20 08:18 PM
Do you still use liquid and paste sealants
by WhyMe - 02/25/20 08:16 PM
VW dealer hilarity - window tinted the wrong car.
by pezzy669 - 02/25/20 07:53 PM
New style Goodyear Duratrac
by NHRATA - 02/25/20 07:44 PM
Need oil additive advise for replacement engine.
by 13Track38 - 02/25/20 07:18 PM
New member with UOA to share
by JamesGames - 02/25/20 07:10 PM
When do you do DIY?
by BMWTurboDzl - 02/25/20 06:47 PM
synchromesh
by hunter29 - 02/25/20 06:41 PM
Ever buy a stranger lunch ?
by Mr Nice - 02/25/20 06:18 PM
36 bucks for balancing two tires....
by Vern_in_IL - 02/25/20 05:20 PM
project farm like test for Maxlife vs toyota WS
by danez_yoda - 02/25/20 05:09 PM
Audi Q5 Transmission oil?
by John344 - 02/25/20 04:35 PM
Valvoline Modern engine
by Villalobos - 02/25/20 04:35 PM
Rust bubbles
by WA1DH - 02/25/20 04:27 PM
Which of these sub $4 filters
by jayjr1105 - 02/25/20 04:05 PM
Flaring tool
by P10crew - 02/25/20 01:52 PM
Hazet 600LG/8 Wrench set - $160
by drtyler - 02/25/20 01:34 PM
akarip, BJD2020, ToyTaco2002, EarlT500, Newbie111
70801 Registered Users
52 registered members (bbhero, A_A_G, Bailes1992, AC1DD, bdcardinal, 5 invisible), 1,720 guests, and 17 spiders.
Topics301,931
Posts5,205,702
Members70,801
Floor jack oil recommendation #5080713 04/20/19 10:40 AM
P
Patrick0525 Offline OP
P
I have a 1993 Hein-Werner (Winner series) 2 ton floor jack part code# 68041 and never had the oil changed.
How shall I change it? What is the procedure and is your favorite oil?
It doesn't leak..
2014 Toyota Venza 2GR-FE 96K mi
2009 Lexus ES350 2GR-FE 49K mi
Fram Ultra filter XG9972
TGMO or Idemitsu Zepro 0w20 (winter)
PP 0w20 (spring/summer/fall)
Re: Floor jack oil recommendation [Re: Patrick0525] #5080720 04/20/19 10:43 AM
M
maxdustington Offline
M
Hydro oil. I can't remember the weight.
DO NOT put ATF in there.
99 Toyota Tercel CE 5EFE/C151
PUP 5W30/Ultra
Re: Floor jack oil recommendation [Re: Patrick0525] #5080739 04/20/19 11:14 AM
R
Reddy45 Offline
R
Autozone sells hydraulic jack oil. They will have 1 kind.
Re: Floor jack oil recommendation [Re: Patrick0525] #5080746 04/20/19 11:23 AM
L
LeakySeals Offline
L
I change every 2 years on all 3 of my jacks. They are keeping me alive, the least I can do. There are 2 types.
Regular jack oil.
https://www.walmart.com/ip/Black-Jack-Hydraulic-Jack-Oil-8-fl-oz/17757422
And a "high mileage" version. LOL
https://www.walmart.com/ip/BAR-S-LEAKS-HJ12-Jack-Oil-with-Stop-Leak/16888776
I use the high mileage version, seals are the biggest issues with jacks.
06 Escalade 6.0L LQ9 AWD 170k M1 5w30
03 Maxima 3.5L 170k Maxlife HM 10w30
05 Malibu Classic 2.2 111k M1 5w30
06 Altima 2.5L 167k unk
Re: Floor jack oil recommendation [Re: LeakySeals] #5080752 04/20/19 11:35 AM
P
P
Regular jack oil.
I am sure I need the high mileage oil since I only use the floor jack 3-to-4 time per year since 1993.
Re: Floor jack oil recommendation [Re: Patrick0525] #5080789 04/20/19 12:16 PM
J
JeffKeryk Offline
J
I got some at Wally World; then a bigger bottle from Amazon.
Old floor jacks rock; I just can't pick 'em up anymore.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: Floor jack oil recommendation [Re: Patrick0525] #5080812 04/20/19 12:45 PM
L
LeakySeals Offline
L
Regular jack oil.
Any pics? I have one old orange 2 ton and over the past 5 years purchased 2 Harbor freight 3 ton (64260). I must admit the cheap HF jacks are good. Flawless actually. Like how fast the "rapid pump" works. So.. if things don't work out with the old jack, consider the HF jacks.
Re: Floor jack oil recommendation [Re: Patrick0525] #5080849 04/20/19 01:26 PM
K
Kestas Offline
Global Moderator
Global Moderator
K
I just bought a floor jack a year ago. How often should the fluid be changed?
Re: Floor jack oil recommendation [Re: Patrick0525] #5080860 04/20/19 01:48 PM
skyactiv Offline
Walmart has it the cheapest I'm guessing. Probably near the jacks on the top shelf?
Me: 18' Elantra Sport 6 speed manual
The rude guy that points out reality
Re: Floor jack oil recommendation [Re: Patrick0525] #5080867 04/20/19 01:52 PM
Yah-Tah-Hey Offline
I use Walmart jack oil. Replace it about every two years. Just about any ISO hydraulic oil should work. Probably 32 or 46. Oil for this application is nothing special. ATF will probably work too. Just don't put engine oil or brake fluid in your jack.
Re: Floor jack oil recommendation [Re: maxdustington] #5080911 04/20/19 03:00 PM
L
Linctex Offline
L
Whoever told you that you can not use ATF lied to you.
Re: Floor jack oil recommendation [Re: Kestas] #5080912 04/20/19 03:01 PM
L
Linctex Offline
L
I have never changed the oil in a floor jack or bottle jack in over 40 years of owning and using them.
Re: Floor jack oil recommendation [Re: Yah-Tah-Hey] #5080915 04/20/19 03:03 PM
L
Linctex Offline
L
ATF works just fine.
Light engine oil (5W-20, 0W-20, etc ) also works just fine and will not cause any problems.
Brake fluid is not oil. ... not even a little bit.
Re: Floor jack oil recommendation [Re: Linctex] #5080919 04/20/19 03:09 PM
K
Kestas Offline
Global Moderator
Global Moderator
K
I had a cheap floor jack I bought new 20 years ago that gave up. The fluid was black. I wonder if I could have gotten more life out of it had I changed the fluid.
Re: Floor jack oil recommendation [Re: LeakySeals] #5081075 04/20/19 05:59 PM
P
P
Regular jack oil.
The 1993 HW pic.
