Intermittent Braking Vibration?
by Gebo - 08/23/19 10:59 AM
Northrop B-2 Spirit - First Cockpit Video
by john_pifer - 08/23/19 10:36 AM
ADBV Design - MANN Filter
by LeoStrop - 08/23/19 10:25 AM
"MYSTERY Oil" - 320 ppm Zinc
by Linctex - 08/23/19 10:20 AM
Thoughts on Time v Mileage
by BISCUT - 08/23/19 10:04 AM
Shocks / Struts
by WyrTwister - 08/23/19 08:04 AM
Stihl HT 50 CE Pole Pruner
by ssamaroo01 - 08/23/19 08:01 AM
LQ4/LQ9 direct swap for LS1?
by cwilliamsws6 - 08/23/19 08:00 AM
Fearing the RockAuto worst
by Kira - 08/23/19 07:40 AM
Minimum octane for 2016 2.0 ecoboost?
by Corollaman - 08/23/19 07:06 AM
Weedwacker advice
by supton - 08/23/19 07:05 AM
Temps pre & post diff cover change
by kehyler - 08/23/19 06:51 AM
DIY: Mazda 2.5L Skyactiv Water Pump
by The Critic - 08/23/19 06:03 AM
vavoline syncpower 4T
by bonjo - 08/23/19 03:24 AM
Great Price but...
by Marco620 - 08/23/19 02:02 AM
CV Joint Leaking Grease
by 92saturnsl2 - 08/22/19 10:20 PM
Craftsman 6 pc. Screwdriver Set $12.14
by Warstud - 08/22/19 09:32 PM
Got My ATF Replaced.
by Mr_Luke - 08/22/19 09:20 PM
Wht do people with labor intensive jobs lay on their back?
by motor_oil_madman - 08/22/19 09:14 PM
lubetech82, Lockguard, PTL, vdubw, NJ01MGM
69036 Registered Users
86 registered members (2015_PSD, 01rangerxl, aquariuscsm, 53' Stude, 1978elcamino, ArrestMeRedZ, 9 invisible), 2,148 guests, and 27 spiders.
Topics293,680
Posts5,044,887
Members69,036
Most Online3,532
Jul 30th, 2019
Page 2 of 3 1 2 3
Re: Timing chain [Re: SHOZ] #5068601 04/08/19 06:49 PM
das_peikko Offline
Isn't there supposed to be a fixture or a special tool to keep the cams from rotating while you get everything else in position?
Re: Timing chain [Re: das_peikko] #5068604 04/08/19 06:53 PM
SHOZ Offline OP
The cams have a hex as most do. The way the chain is put on (counter clockwise) you start with the chain on the crank sprocket then move the cams just a bit to match the chain and when done it's all lined up. But I did stick a screwdriver under one lobe on the exhaust cam to secure it.
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
Re: Timing chain [Re: das_peikko] #5068633 04/08/19 07:22 PM
K
kschachn Offline
K
Never mind, Shoz answered it well.
1994 BMW 530i, 246K
1996 Honda Accord, 280K
1999 Toyota Sienna, 420K
2000 Toyota ECHO, 281K
Re: Timing chain [Re: SHOZ] #5068694 04/08/19 08:31 PM
A
aquariuscsm Online Content
Online Content
A
That's a clean engine! What's your go-to oil?
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Re: Timing chain [Re: aquariuscsm] #5068720 04/08/19 08:59 PM
SHOZ Offline OP
Thanks. I use Mobil 1 and 5k mile OCI. Fram Ultra since they came out. 0W40 for the last few years, 5w30 for a couple of years.. But always has been synthetic since I dumped the factory fill. (5w20)
Here's the cams before I started.
[Linked Image]
And the amount of slack.
[Linked Image]
It takes the same chain as a Dodge and Mitsubishi motor, from their one time shared production or design arrangement.
Re: Timing chain [Re: SHOZ] #5068778 04/08/19 09:51 PM
9
92saturnsl2 Offline
9
Ouch only 97k for a chain?
I used to own a Dodge Caliber SRT4 with the 2.4L turbo World Engine, same family as this one I believe. Nice engines, very reliable. Is this engine known for eating chains/tensioners or is this an aberration?
1985 F-250HD 7.5L 4x4 135k- Castrol GTX 15w-40
04 Odyssey EX 190k Valv. Durablend 5w-30
96 Maxima GLE 268k Shell Rotella T5 10w-30
07 Chrysler Pacifica Limited 4.0L 140k Castrol Edge 0w-30 Euro
Re: Timing chain [Re: 92saturnsl2] #5068785 04/08/19 09:58 PM
SHOZ Offline OP
That's the connection. The OE chain I got is shared with the Sonata 2.4L motor too.
Re: Timing chain [Re: SHOZ] #5068846 04/08/19 11:36 PM
slacktide_bitog Offline
Nice pictures! thumbsup
IMO, if you didn't put the engine back together yet, you are probably still better off buying the new chain. Especially if the original needed replacing before 100k. There are *belts* that last longer than that mad
It seems like a difficult job that you definitely don't want to do again!
Re: Timing chain [Re: SHOZ] #5068993 04/09/19 06:57 AM
A
Online Content
A
[Linked Image]
[Linked Image]
Honestly that engine is spotless! It looks like a brand new engine. No wear whatsoever on the camshafts. That must be a really good engine!
Re: Timing chain [Re: SHOZ] #5068994 04/09/19 06:58 AM
A
Online Content
A
Have you been able to tell any difference between the oils you use? M1 0W40 is something I've always been curious about but have never tried it.
Re: Timing chain [Re: slacktide_bitog] #5068999 04/09/19 07:05 AM
SHOZ Offline OP
If I didn't want to throw away the $50 the chain I got was and the better chain is $75 I would have. I doubt if the car sees another 100k miles at least with me driving it. smile I don't drive it near as high as I did when it was new. It's suspected the chain wasn't designed for the higher rpm (7500) vs the Sonata 2.4L that the OE chain was picked off the parts shelf from.
10 years or so ago I did a V8 with DOHC but it was out of the car at the time.
Re: Timing chain [Re: aquariuscsm] #5069005 04/09/19 07:14 AM
SHOZ Offline OP
I started out using M1 5w30. Had a couple oil test done and dilution was the only problem. One test was done after two track days and a 5k mile drive in between. The engine will actually 'make' oil as the dilution adds faster that if burns any oil , if any. Loose rings and high compression design I guess.
Re: Timing chain [Re: SHOZ] #5069349 04/09/19 01:50 PM
Z
zorobabel Offline
Z
Anyone remember this thread?
1997 Maxima 206k, Castrol GTX Synblend 5W-30, PL14459
2004 Corolla 205k, VWB 5W-20-30, MGL4967
Re: Timing chain [Re: SHOZ] #5069351 04/09/19 01:55 PM
SHOZ Offline OP
Just for the record Hyundai has come out with a beefier chain but when I ordered it got the old part. Didn't know until after I got it. Mitsubishi had problems too with their Evo motors that had the same chain.
Re: Timing chain [Re: SHOZ] #5074832 04/14/19 04:22 PM
SHOZ Offline OP
Just want to say it all is back together and runs!.. I'm always nervous. Only the second time for a chain on a DOHC engine for me. Thanks for the help.
Couple of pics of the oil pump.
[Linked Image][Linked Image]
Page 2 of 3 1 2 3
