HUBB reusable stainless steel filter?
by Vern_in_IL - 02/18/20 08:41 PM
Ultrasonic carb cleaning problems
by atikovi - 02/18/20 08:05 PM
Cheeseburger pie
by P10crew - 02/18/20 07:25 PM
The midwinter detail.
by dan_erickson - 02/18/20 05:27 PM
Tired of Using Cassette Player with iPhone
by Gebo - 02/18/20 05:04 PM
STP oil filter
by Stinky123 - 02/18/20 04:41 PM
How is this possible
by V10 - 02/18/20 04:07 PM
Monroe made in Turkey
by atikovi - 02/18/20 03:31 PM
NSFBitog
by Ursatdx - 02/18/20 03:25 PM
Wider rear tires?
by drop - 02/18/20 03:07 PM
ROCKAUTO Coupon Codes
by jrvn - 02/18/20 02:24 PM
Gold (brass?) flecks in drained Honda ATF
by TNM6i - 02/18/20 12:10 PM
What happened to licensed ATF clones?
by TimN3QE - 02/18/20 12:08 PM
E85 in non-flex fuel Ford Expy ~2013
by DriveHard - 02/18/20 11:46 AM
Jacking up a car by itself
by Alfred_B - 02/18/20 11:44 AM
Valvoline MST in 2015 Macan S
by musclecarscott - 02/18/20 11:43 AM
PH10060 oversized?
by bullwinkle - 02/18/20 11:36 AM
GardenStateAudi, Strommen95, Idaholewis, Sprite, spbonus
70746 Registered Users
79 registered members (AdditionalD, Aero540T, Ag76, AC1DD, 2009Caraman, 10 invisible), 1,660 guests, and 15 spiders.
Topics301,629
Posts5,199,491
Members70,746
Page 3 of 4 1 2 3 4
Re: I put a gallon of MMO in my gas tank... [Re: Vladiator] #5027984 03/01/19 03:33 PM
O
oil_film_movies Offline
O
More catalyst-safe (those things are expensive) is a PEA based cleaner, and using a double or triple dose of that wouldn't foul the plugs like all this MMO did.
MMO is known to have solvents, so it should remove some gum or varnish at least.
Re: I put a gallon of MMO in my gas tank... [Re: Vladiator] #5028058 03/01/19 04:35 PM
147_Grain Offline
Time to change your engine oil and filter.
2019 Subaru Crosstreck
2013 Subaru Outback 3.6
Re: I put a gallon of MMO in my gas tank... [Re: nicholas] #5028312 03/01/19 08:26 PM
dave123 Offline
Originally Posted by nicholas
Every forum has a couple of these guys - - - - I call them internet weasels.
They would never say anything like that to your face - - - - because they know you would smash it in.
Just give the weasels their forum to feel tough.........................
Of course I’d say it to his face if it was my own son I would say boy you stupid and sit him down and ask how you get so stupid. I got no problem telling someone they that dumb this world is full of idiots.
Re: I put a gallon of MMO in my gas tank... [Re: Vladiator] #5028674 03/02/19 07:06 AM
dnewton3 Offline
Global Moderator
Global Moderator
enough of the personal insults, lest some get a vacation.
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
Re: I put a gallon of MMO in my gas tank... [Re: Vladiator] #5028982 03/02/19 11:42 AM
W
wings&wheels Offline
W
Was their any indication of severe detonation? That much MMO would cause a significant decrease in octane of the resulting mix vs. pump fuel. There was an aviation accident with an ag plane where, if I remember correctly, the operator put enough MMO for the fill up into one tank which when selected, produced the expected results.
'05 Lotus Elise S/C
'85 Land Rover 90 diesel
'74 Triumph TR6
'74 BMW 2002
'72 Land Rover Series III 88"
'99 Porsche 996 (Wife's)
'01 Porsche Boxster S (mostly Wife's...)
Piper Pa28-236
Re: I put a gallon of MMO in my gas tank... [Re: wings&wheels] #5029895 03/03/19 08:02 AM
V
Vladiator Offline OP
V
I did not feel or hear any pinging/knocking/detonation. Just misfire after more than 5 minutes of idle, or at any load over 1700rpm.
*[Redline starts somewhere around 4500rpm, so staying below 1700rpm still produced enough torque to keep the Tahoe moving up to highway speeds.]*
The misfires under load made it feel like the engine was only running on 4 cylinders, and the fact that 4 of the spark plugs were dry-ish and other 4 were pretty wet tells me that this theory may be correct.
Re: I put a gallon of MMO in my gas tank... [Re: Vladiator] #5031191 03/04/19 10:06 AM
W
W
Interesting...wonder what would cause only 4 cylinders to be firing.
'05 Lotus Elise S/C
'74 Triumph TR6
'74 BMW 2002
Piper Pa28-236
Re: I put a gallon of MMO in my gas tank... [Re: slacktide_bitog] #5031257 03/04/19 11:26 AM
SirTanon Offline
Originally Posted by slacktide_bitog
a gallon of MMO probably isn't a lot for a 30-gal gas tank, even though it is much more than you should use!
It is like putting 2 quarts, a half gallon, in a 15-gal tank, which is around the size of most cars' tanks.
Considering that the accepted ratio of MMO to gas is approximately 4oz MMO per 10 gallons of gas, for a 30 gallon tank, 12 ounces would have been the correct amount to add.. And he added more than 10 times as much.. I'd say it IS a lot for that 30-gal tank. WAY too much. I'm not at all surprised that he had so many problems. That amount of MMO was enough to treat 320 gallons!
2013 Nissan Altima SV - 2.5 liter/CVT - 125,000mi
2014 Nissan Altima SL - 2.5 liter/CVT - 68,000mi
2010 Ford Fusion - 274k mi - SOLD
Re: I put a gallon of MMO in my gas tank... [Re: Vladiator] #5032409 03/05/19 12:36 PM
CourierDriver Offline
Its 4 ounces of MMO to 10 gallons of gas....
I'd still like to have my 67 Beetle back....life was easy then..imho 2 quarts of oil roughly ,lol
Re: I put a gallon of MMO in my gas tank... [Re: Vladiator] #5032460 03/05/19 01:22 PM
Advertisement Removed
Re: I put a gallon of MMO in my gas tank... [Re: Vladiator] #5033254 03/06/19 03:56 AM
V
V
Yes I know the correct ratio as I have been following it for years since I started to understand the combustion engine. But since this truck has the "bulletproof" Small Block 350 - I decided to try this overdose.
As explained above - It ran on 4 cylinders due to the fact that the other 4 were too soaked in MMO/gas to create a spark at any type of load.
Re: I put a gallon of MMO in my gas tank... [Re: Vladiator] #5040036 03/12/19 12:28 AM
G
gfh77665 Offline
G
Ah, the 'ole Marvel MISERY Oil.
crackmeup
Re: I put a gallon of MMO in my gas tank... [Re: Vladiator] #5047533 03/19/19 02:46 AM
M
man114 Offline
M
MMO works wonders in small engines. I don’t think I’d use this quantity in a large gas engine. I run 4 oz per 5 gallons in small engines I never have those ethanol issues.
Re: I put a gallon of MMO in my gas tank... [Re: Vladiator] #5047981 03/19/19 12:59 PM
MolaKule Offline
Global Moderator
Global Moderator
I suspect the O2 and knock sensors were feeding erroneous data to the computer and because of this out-of-bounds data it really confused control of the spark timing and injector pulse widths.
As another poster mentioned, you may want to change oil and filter pronto.
Charlie Eppes: "Larry, have a minute?"
Dr. Larry Fleinhardt: "Yes. Because we all have exactly the same number of minutes at all times, do we not?" From NUMB3RS
Re: I put a gallon of MMO in my gas tank... [Re: Vladiator] #5048690 03/20/19 07:25 AM
Z
ZZman Offline
Z
Got a 2 stroke motor in that truck?....:)
2007 Hyundai Santa Fe AWD.
2005 Toyota Avalon XLS
Page 3 of 4 1 2 3 4
