BMW LL04 Dissapeering?
by Bailes1992. 07/19/19 03:51 AM
Which Synthetic Oil Do You Use, And Why?
by BlueOvalFitter. 07/18/19 10:50 PM
do laptop batteries really go bad or
by WhyMe. 07/18/19 10:32 PM
2016-2017 Chevy Equinox reliability
by gregk24. 07/18/19 10:12 PM
Mann HU816 x
by IllinoisSparky. 07/18/19 09:41 PM
Seafood Combo
by vavavroom. 07/18/19 09:37 PM
‘13 Silverado 1500 Extended Cab
by parshisa. 07/18/19 09:35 PM
Where to have a watch serviced?
by E150GT. 07/18/19 08:32 PM
Stubborn diff fill plug
by HoosierJeeper. 07/18/19 08:21 PM
Big score on auto parts clearance AAP
by Marco620. 07/18/19 08:05 PM
Would this cause my jeep to stall?
by MileHigh18. 07/18/19 08:00 PM
Looking for Highlander '06,'07, '09
by Gebo. 07/18/19 06:39 PM
'03 F150 Parking Brake Adjustment
by benjamming. 07/18/19 06:17 PM
Do You Still Change Your Oil at 3K?
by Gebo. 07/18/19 05:33 PM
Any sellers on amazon for Honda A02?
by BTLew81. 07/18/19 03:44 PM
First SMR (MMR) slated to be built at Chalk River
by OVERKILL. 07/18/19 03:31 PM
Torque Specs for 2004 Dodge Ram transfer case
by diyjake. 07/18/19 02:15 PM
OAT ad NOAT
by CCI. 07/18/19 02:06 PM
Raunper, OilDrinkingHemi, suuru, Hollicrev, Richb55
68704 Registered Users
31 registered members (53' Stude, ctechbob, Bailes1992, 2015Corolla, AlienBug, 6 invisible), 713 guests, and 21 spiders.
Topics292,061
Posts5,016,115
Members68,704
Most Online2,967
Mar 10th, 2019
Page 4 of 5 1 3 4 5
Re: Amsoil or RedLine? [Re: WillB] #5020977
02/23/19 09:48 AM
02/23/19 09:48 AM
1/2 hr N.E. of Detroit
Triple_Se7en Offline
Originally Posted by WillB
Both are top notch oils - either if you have them available.
Amsoil here - no Redline available locally.
But can they remain top-notch oils, iof they need to someday conform to SN Plus and Dexos1Gen2? That would require them to offer weaker add-packs..... right? If they add/beef their base oils, isn't more PAO frowned upon by LSPI doctors? Aren't 50% of vehicles made today TGDI/GDIs? So how do the boutique oil manufacturers stay far ahead of norms like Pennzoil, Valvoline and Castrol.... among others and meet SN Plus Dexos1Gen2??
19 Hyundai SantaFe 2.4GDI Castrol Edge 5w30 / NAPA Mann-Hummel filter / 6oz Liqui-Moly Treatment
04 Colorado 3.5 Castrol Edge 0W40 Euro & K&N filter
03 Malibu 3.1 QS / Valv Syn 5w30 mix Fram EG filter
Re: Amsoil or RedLine? [Re: Ian1982] #5021288
02/23/19 04:00 PM
02/23/19 04:00 PM
Pennsylbammyvania
dailydriver Offline
dailydriver  Offline
Pennsylbammyvania
IF Red Line offered a (MUCH) reduced calcium (and sodium), much greater magnesium content oil, within my needed HTHSV spec range (but all else being equal with their current add packs/base oils), I would use it in a heartbeat, despite it not being D1G2/Ford 945B 'certified'. wink
2016 Ford Fiesta ST 17K miles
Ravenol REP 5W-30
Fram XG3600 filter
Ravenol MTF-2 in the IB6 transaxle
Re: Amsoil or RedLine? [Re: Ian1982] #5021497
02/23/19 08:04 PM
02/23/19 08:04 PM
Michigan
A_Harman Offline
A_Harman  Offline
Michigan
Originally Posted by Ian1982
Hey guys, prepping for my next OC. Going with either Redline 5w-30 or Amsoil SS 5w-30 .2013 GMC with 5.3 LC9. Whatcha guys got? Thank you in advance
I think these oils are meant for two different usage patterns. Redline is more for high temperature wear protection. AMSoil SS is more for long drain intervals. I have run Redline many times up to 8000 miles, and it does fine. AMSoil is more for 15,000 mile drain intervals. What more suits your needs?
How many miles on your truck?
Do you tow or haul heavy very often?
1985 Z51 Corvette track car
2002 Camaro Z28 LS1/6-speed
2001 Dodge Ram 2500 diesel
1972 GMC 1500 shortbed project truck
Re: Amsoil or RedLine? [Re: jongies3] #5021562
02/23/19 09:15 PM
02/23/19 09:15 PM
montreal ,canada
madeej11 Offline
madeej11  Offline
montreal ,canada
Originally Posted by jongies3
Both are overkill for your engine. Run whatever's on sale at Walmart!
The OP had to repeat what his two options were at the top of page 3 and still you insist on Walmart choices!
Ian, go with Amsoil Signature series for a daily driver.
Re: Amsoil or RedLine? [Re: Ian1982] #5021613
02/23/19 09:56 PM
02/23/19 09:56 PM
sonoma
burla Offline
burla  Offline
sonoma
Nobody here ever talks about the science anymore, not even the basics, rather funny. What is modern Amsoil SS? Low viscosity, low additive oil made for di turbo's. What is redline, high viscosity high additive oil made for older style v8's or over built high taching non di engines. Go to Ram forum, the log term uoa's on redline have been as good as anything. Not knocking Amsoil, it is what it is, it is an oil built or should I say re-formulated for modern engines, but the hemi is far from a modern engine. If you believe in one oil can satisfy every application, then go for amsoil. BTW, ram forum top 4 oils used, Pennzoil number one, m1 number two despite not having or recomending it for the ms6395 spec, amsoil, and 4th is redline 5w30. People that have hemi tick over there bar far choose redline, w/o hemi tick Pennzoil PUP/PP is tops.
Re: Amsoil or RedLine? [Re: dailydriver] #5021617
02/23/19 10:01 PM
02/23/19 10:01 PM
sonoma
burla Offline
burla  Offline
sonoma
Yes, I am very disapointed they don't make a lineup that is di sn+ friendly. They got on board with low ash with their newest oils, but still left the largest part of the market out of their formula with this bad decision. Your right, if they had low calc/high mag with that zddp/moly ester/pao package, that would be the darndest oil around. 50% or better is going di, I can't believe they havem't made the switch, they loose nothing by doing so. very disapointed for folks have a di
Re: Amsoil or RedLine? [Re: Ian1982] #5021627
02/23/19 10:06 PM
02/23/19 10:06 PM
NJ
buster Offline
buster  Offline
NJ
I don't know if this has been posted before. They talk about polymeric thickeners about halfway through. For a modern daily driver I'd use Amsoil. Redline should keep the Ester/PAO formula as is, but make a more modern additive package that doesn't have the ZDP/Ca levels and overall higher SA. I wouldn't use this oil due to the LSPI issues.
2015 Mazda 3 2.0 - Mobil 1 EP 0w20
Re: Amsoil or RedLine? [Re: Pablo] #5022825
02/25/19 05:33 AM
02/25/19 05:33 AM
Taiwan, Taipei, ROC
aleneros Offline
aleneros  Offline
Taiwan, Taipei, ROC
Originally Posted by Pablo
Originally Posted by LotI
Hmmm...a renowned pyramid scheme company or a major corporation?
Tough one.
If it were me I would find a D1G2 oil and stop.
"renowned pyramid scheme company" ?
Really. Clearly you don't know what you are talking about. Why would anyone believe you?
To the OP, if you are not planning an extended OCI, Amsoil OE or XL line will be just fine. Don't let others talk you out of any motor oil if they just spew made up rubbish.
Dear Pablo,
Quick question:
My car calls for VW502 00, OCI: 1 year / (15000KM)
Would it be OK to use Amsoil SS 5W-30?
PS: UOA is relatively high price in my country ( ~75~80 USD)
Many thanks.
David
Re: Amsoil or RedLine? [Re: aleneros] #5022864
02/25/19 07:03 AM
02/25/19 07:03 AM
Duvall WA - Pacific NW USA
Pablo Offline
Pablo  Offline
Originally Posted by aleneros
Dear Pablo,
Quick question:
Many thanks.
David
What car? What year? How many miles?
DIRECT JOBBER - PABLO - for all your Amsoil needs
http://oilslubesandfilters.shopamsoil.com/
Re: Amsoil or RedLine? [Re: Ian1982] #5022870
02/25/19 07:19 AM
02/25/19 07:19 AM
TX
s2krunner Offline
s2krunner  Offline
TX
I think some of guys should have read posted date before recommend to OP lol
2018 Chevy Camaro 6.2L V8
2017 Ford Explorer 3.5 V6
2011 Ford Ranger 4 banger
Re: Amsoil or RedLine? [Re: Ian1982] #5022972
02/25/19 09:48 AM
02/25/19 09:48 AM
ON, Canada eh?
StevieC Offline
StevieC  Offline
ON, Canada eh?
Amsoil has been good for me in the last decade I have been using it. Allowing me to go further between oil changes with the massive amounts of miles I drive weekly. 300K miles on my Santa Fe with 0 consumption when a defective camshaft let go. So they know what they are doing compared to other brands. If you decide to go that route you can use it with confidence.
I've got it in our families vehicles as well along with the ATF's.
It's up to you, just wanted to share my experience with the product.
'18 Caravan - 40k KM - AMSOIL SS 0w20, Fram Ultra, TC-W3 500:1
'06 Santa Fe - 535k KM (Retired)
There is no such thing as "lifetime" fluids! mad
Re: Amsoil or RedLine? [Re: Pablo] #5023021
02/25/19 10:54 AM
02/25/19 10:54 AM
Taiwan, Taipei, ROC
aleneros Offline
aleneros  Offline
Taiwan, Taipei, ROC
Dear Pablo,
Quick question:
Many thanks.
David
It’s a 2017 Skoda Kodiaq (26XXX KM so far).
(gasoline EA888 gen3b. 2.0L, Same as 2018 VW New Tiguan)
https://www.greencarcongress.com/2017/05/20170523-tiguan.html
Re: Amsoil or RedLine? [Re: Ian1982] #5023074
02/25/19 11:38 AM
02/25/19 11:38 AM
Suomi
Bjornviken Offline
Bjornviken  Offline
Suomi
Amsoil
Re: Amsoil or RedLine? [Re: aleneros] #5023121
02/25/19 12:09 PM
02/25/19 12:09 PM
MN
oil_film_movies Offline
MN
Dear Pablo,Quick question:My car calls for VW502 00, OCI: 1 year / (15000KM)Would it be OK to use Amsoil SS 5W-30? PS: UOA is relatively high price in my country ( ~75~80 USD)Many thanks. David
It’s a 2017 Skoda Kodiaq (26XXX KM so far). (gasoline EA888 gen3b. 2.0L, Same as 2018 VW New Tiguan)https://www.greencarcongress.com/2017/05/20170523-tiguan.html
https://www.amsoil.com/lit/databulletins/g3395.pdf
and pick the 0w-40 one, preferably. You could pick any one of them.
Amsoil SS 5w-30 has an HTHS that volkswagen says is too low. VW 502 says you need an HTHS 3.5 or greater.
Re: Amsoil or RedLine? [Re: Ian1982] #5023128
02/25/19 12:15 PM
02/25/19 12:15 PM
ON, Canada eh?
StevieC Offline
StevieC  Offline
ON, Canada eh?
The HTHS numbers are higher on the Amsoil XL / OE series oils and they are less expensive. Just in case you want to add that for consideration.
Page 4 of 5 1 3 4 5
