Originally Posted by edyvw
Originally Posted by FlyPenFly
After looking at the VOA, I guess M1 10w40 is the way to go with it's lower Ca and higher Mg. This is a turbo DI engine after all. Thankfully it's significantly less expensive than the Castrol 10w40HM.
Car is running fine but it needs the timing chain system replaced (tensioner is at max extension) and I'll probably do the PCV system myself in the near future. Not burning much oil but want to keep it that way. It's a class action and TSB for Audi anyway for oil consumption and timing chain system. Apparently a lot of these engines suffered from poor quality cylinder rings from a vendor and poorly designed timing chain tensioners pre-2014.
I would stick with Castrol 0W40. You will not gain anything with HM oil.
I changed tensioner at 68k preventively and installed updated one.
Reengineered piston rings, PCV are mid-2012 as well as chain tensioner (this affects 3.0T engines too).
I would change tensioner ASAP, and stick to Castrol 0W40. PCV might alleviate some of your issues as that is first culprit.
By the way, what oil are you using now?
I think at 123k miles on this somewhat problematic engine design, I think it might make sense as preventative to keep the seals in good condition. There's Castrol 0w40 that was just changed in there now. I'm getting the tensioner and full chain service and maybe a carbon cleaning done in 2 days.
Next oil change, I'll probably switch to M1 10W40HM because of it's lower Ca content as well.
