Lubeguard
by hardheaded. 01/22/19 02:10 PM
OEM Cap & Rotor when changing spark plugs?
by paulri. 01/22/19 01:50 PM
A young boy...
by JLTD. 01/22/19 01:34 PM
Oil weight and FM
by Brian553. 01/22/19 01:07 PM
New Bridgestone Blizzak WS90
by SubLGT. 01/22/19 12:59 PM
Southwest Airlines slides off runway
by JustN89. 01/22/19 12:55 PM
phenolic caliper pistons
by bionictony. 01/22/19 12:31 PM
SS snowblower auger to scraper gap?
by dwcopple. 01/22/19 11:47 AM
PP HM 10W-30 at Walmart for $15
by 28oz. 01/22/19 11:30 AM
2012 Camry ATF change- now or later?
by TmanP. 01/22/19 11:20 AM
Oil sampling tube
by kevmor99. 01/22/19 10:00 AM
Gas trimmers
by weeksjake. 01/22/19 09:11 AM
Supertech Heavy Duty 15W40 ...$9.64
by dblshock. 01/22/19 08:53 AM
Trooper recommends dash cameras
by FordBroncoVWJeta. 01/22/19 07:14 AM
New Harley synthetic 80w-140 gear released
by shanneba. 01/22/19 06:43 AM
Registering a Vacation Car
by ssamaroo01. 01/22/19 06:23 AM
Sam002, Binco, Coolbreez1973, jmcast1127, DF8005
67010 Registered Users
114 registered members (4x4le, ammolab, 28oz, 2004tdigls, 4WD, 12 invisible), 2,349 guests, and 32 spiders.
Topics296,983
Posts4,962,925
Members67,010
Most Online2,821
Jan 21st, 2019
Page 1 of 10 1 2 10
High RPMs...thick or thin? #4977477
01/12/19 09:26 PM
01/12/19 09:26 PM
Ice Box of the Nation
Doublehaul Offline OP
If you had a vehicle that was going to spend hour after hour at an RPM range of around 3-3500...would you be better off running a 0w20 or say a 0w40 assuming both were allowed by the OEM
2019 Toyota 4Runner 4x4 TRD
2019 Toyota Tacoma 4x4 TRD
The specs on the back are more important than the label on the front
Re: High RPMs...thick or thin? [Re: Doublehaul] #4977479
01/12/19 09:29 PM
01/12/19 09:29 PM
ON, Canada eh?
StevieC Online content
StevieC  Online Content
ON, Canada eh?
0w40 for hour after hour repeatedly. Normal driving where this isn't the case (as a contrast) I would go with the 20wt no problem.
'18 Dodge Grand Caravan GT - 18k KM - AMSOIL SS 0w30
'06 Hyundai Santa Fe - 535k KM (Dead) - AMSOIL SS 0w30
Re: High RPMs...thick or thin? [Re: Doublehaul] #4977486
01/12/19 09:36 PM
01/12/19 09:36 PM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
what vehicle? what engine? what load? 3500 in the parking lot?
what oil temps?
In general its ok to be thick you lose a little fuel economy in most engines
too thin can cause damage.. so I'd err on the side of thickness.
That all being said in a water cooled engine used normally (not raced or towing a load/trailer up a mountain for 30min or more.
its not all that important to use anything thicker than recommended.
Re: High RPMs...thick or thin? [Re: Doublehaul] #4977490
01/12/19 09:38 PM
01/12/19 09:38 PM
ME
eljefino Offline
eljefino  Offline
ME
Oil pump will make plenty of pressure and flow at that RPM, keep it thin, or, hey, stock!
Going thicker will just bypass more and have less flow to take the heat away.
Re: High RPMs...thick or thin? [Re: Doublehaul] #4977492
01/12/19 09:39 PM
01/12/19 09:39 PM
Tri State Conservative
Zee09 Offline
Zee09  Offline
Given your login name...... 0w40 smile
"If I walked on water, they'd say I couldn't swim."
Re: High RPMs...thick or thin? [Re: Doublehaul] #4977503
01/12/19 09:51 PM
01/12/19 09:51 PM
New Braunfels
Bryanccfshr Offline
Bryanccfshr  Offline
New Braunfels
0w40
For the HTHS. If you have driven your Tacoma much on the interstate yet you will realize that anything over 70 mph the transmission will downshift from 6 to 5 and find its happy place in 4th if there is any headwind , hill or heavy load. So you will be in that rpm range a lot if you take many long interstate tripsat 75-80. The faster you go the higher the load due to the nature of driving a brick into the wind.
I am not afraid of 0w20, I am running my toyota care oil toward its 5k. Then the 0w40 goes in for 5k. One more toyota care oil change after that and I can run higher HTHS oil full time and push it a little longer perhaps.
I run nearly 400 miles, 240 of it @80 mph every couple of weeks, to and from where I work rotationally.
So hours of hours of sustained 3500 rpm and there is a load on it, the truck wouldn’t stick to 4th to stay in the power band if there wasn’t.
5th and 6th are more handy at 50-60mph, for fuel economy,
2018 Trd Pro 4Runner
2018 Tacoma off-road
Dealer 0w20 to M1 0w40 FS -it depends
Re: High RPMs...thick or thin? [Re: eljefino] #4977507
01/12/19 09:54 PM
01/12/19 09:54 PM
'Stralia
Shannow Online content
Shannow  Online Content
'Stralia
Sorry mate, that's not how it all works.
The Dunning Kruger effect is real.
The Galileo Fallacy is real.
Roll them into one neat package and crackmeup crackmeup crackmeup
Re: High RPMs...thick or thin? [Re: eljefino] #4977510
01/12/19 09:56 PM
01/12/19 09:56 PM
New Braunfels
Bryanccfshr Offline
Bryanccfshr  Offline
New Braunfels
All of those post and you don’t understand that hydrodynamic lubrication tenacity improves with viscosity. You can not pump a fluid wedge into a journal bearing.
Re: High RPMs...thick or thin? [Re: Doublehaul] #4977517
01/12/19 10:04 PM
01/12/19 10:04 PM
Canyon County Idaho
CT8 Online content
CT8  Online Content
Canyon County Idaho
0w-40.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: High RPMs...thick or thin? [Re: Doublehaul] #4977531
01/12/19 10:29 PM
01/12/19 10:29 PM
FL, USA
gregk24 Offline
gregk24  Offline
FL, USA
IF manufacturers allows both grades, I would go with the 0w40.
2012 Honda Accord EX-L K24z3
54,xxx miles
PPPP 0w20 / Fram Ultra
2014 VW Jetta SE 1.8T ea888
40,xxx miles
Castrol OEM dealer fill / OEM filter
Re: High RPMs...thick or thin? [Re: Doublehaul] #4977544
01/12/19 10:46 PM
01/12/19 10:46 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
That sounds like my OLD 1-ton F350 dually with 4.10 gears.... hours and hours at 3000+ RPM
SAE 30 and 15W-40 is all it has run on.... those HD (diesel type) oils will last you just fine
Re: High RPMs...thick or thin? [Re: Doublehaul] #4977551
01/12/19 10:57 PM
01/12/19 10:57 PM
Kendall, FL
wemay Offline
wemay  Offline
Kendall, FL
xw40
18 Sportage 2.4L AWD:
Now: M1AP 5/20 + M1-104
Next: QSUD 5/30 + S2808XL
13 Santa Fe Sport 2.0T:
Now: EDGE 5/40 + OEM
Next: Same
Re: High RPMs...thick or thin? [Re: Doublehaul] #4977565
01/12/19 11:24 PM
01/12/19 11:24 PM
Maricopa, Arizona
dave1251 Online happy
dave1251  Online Happy
Maricopa, Arizona
We need more information. What is the oil temp, how many quarts of oil, the engine, load and a few more tidbits will help. In reality the OEM does similar testing with recommended grade prior to production.
don't use.
Re: High RPMs...thick or thin? [Re: Doublehaul] #4977573
01/12/19 11:39 PM
01/12/19 11:39 PM
Colorado Springs
edyvw Offline
edyvw  Offline
Colorado Springs
Same dilemma.
I need high rpm's to keep up and pass traffic on I70 going to ski. Once I hit I70 in Denver toward ski resorts I am above 4,5000 rpm's for 45 minutes or more, hitting regularly redline on altitude between 5,800ft and 12,000ft going up some really steep grades at that rpm.
I added last time 2qts of 0W40 (old version) i had left over from my CC I used once. But I am seriously thinking next week to switch completely to 0W40 FS.
How is your mpg on your Toyota's after switching to 0W40 (not my primary concern, just asking)?
15' Toyota Sienna AWD (Mobil1 5W30 EP+OEM filter).
11' VW Tiguan 2.0T (Castrol 0W40+MANN filter)
Re: High RPMs...thick or thin? [Re: Doublehaul] #4977580
01/12/19 11:46 PM
01/12/19 11:46 PM
N.A.
Onetor Offline
Onetor  Offline
N.A.
the latter.
Page 1 of 10 1 2 10
