Originally Posted by irv
Originally Posted by novadude
What is interesting, is I have a 2016 Colorado (mine) and a 2016 Buick Lacrosse (wifes) in the stable. The Colorado is 6 bolt, and the Buick is 5 bolt, but they both have the same size nuts and studs (same as Silverado above). The Colorado manual calls for 140 ft-lb, but the Buick manual only calls for 120 ft-lb. Makes no sense to me, but I just follow the manual regardless.
My son's 08 Malibu is 100 and my wife's car is 120. All my previous GM trucks were 140 but my Ram, with only 5 studs I believe is 120-125?
My bud and I did a little experiment. We torqued a GM truck to 120-125 and let sit for a bit then went around again and retorqued them to 140. The surprising thing was, the nuts didn't turn/get any tighter before the torque wrench clicked?
I don't know with 100% certainty but I believe my bud, being a good/decent licensed mechanic, gets his torque wrenches calibrated occasionally/annually.
Not that I recommend anyone ever torquing their nuts to below the required amount, but has anyone else ever tried this?
I thought you were supposed to loosen the lug nut before re-torqing it again?
I never heard that before, but maybe you're right? I've always just rechecked mine to ensure they are still tight/torqued to the value.
My point was, when we increased the torque value on the torque wrench, the nuts didn't get any tighter before the torque wrench clicked again.
If your checking the same torque you can just re-torque the lug nuts but if your changing the torque to a different value you should start over by loosening the lug nut then tightening it to the new value.
