2003 Honda EX V6 with the 5speed.
Related to the other thread, except whole new possible emergency.
My funnel didnt fit so I had to use an extra length of hose on the end of it to go down the end of the dipstick to refill. (I couldnt conveniently get to the 24mm fill bolt so had to use the dipstick)
I pulled the funnel back up again and it's possible the length of hose literally went DOWN the dipstick. HELP what do I even do. >_< It was a little 3 inch length of hose - my other funnel got damaged so I temporarily rigged up this and it seemed firmly attached, then during the slow refilling I pulled the funnel up and the end is no longer attached out of the blue.
I'm looking to see if it fell off outside the hole but unless I see it i'm assuming it went down the dipstick fill hole.
No i'm not normally this incompetent, this is what happens when i'm trying to rush things on a warm day during the only time I had to work on the car.
