Trailblazer tire pressures
by zrxkawboy - 03/31/20 06:01 AM
Lincoln MKZ hybrid / Sitting for 6+ weeks
by Ammofirst - 03/31/20 04:01 AM
Megapulse VEE System
by toyota62 - 03/31/20 01:35 AM
If only I had more time...
by 14Accent - 03/31/20 12:34 AM
Pennzoil Ultra Platinum 0W-40 availability.
by LTZ10 - 03/30/20 11:01 PM
Brake Fluid testing - moisture & copper
by DIY4quality - 03/30/20 10:49 PM
My E46 with BMW Style 225M wheels
by SLO_Town - 03/30/20 10:49 PM
2019/2020 VW Jetta GLI
by TCU_Adam - 03/30/20 10:00 PM
Inner Core Oil Filter
by QuangTeo - 03/30/20 09:56 PM
245/65/R17
by KE7JFF - 03/30/20 09:42 PM
Replace fuel sending unit or just roll with it?
by cwilliamsws6 - 03/30/20 09:37 PM
lawn sprinkler troubleshooting
by Burt - 03/30/20 07:44 PM
Air conditioner in a toyota avalon
by ChrisSnowden - 03/30/20 06:11 PM
CV axle shaft vertical play?
by JHZR2 - 03/30/20 05:29 PM
This is how it's done!
by Mad_Hatter - 03/30/20 04:56 PM
Android to PC pictures?
by Eddie - 03/30/20 04:30 PM
Crazy fixes that worked
by IMSA_Racing_Fan - 03/30/20 01:39 PM
Cadillac CTS 4 AWD driveline care and feeding
by IMSA_Racing_Fan - 03/30/20 12:13 PM
SantiagoT, cabriopeugeot, Z08969, TCU_Adam, deaner1979
71063 Registered Users
89 registered members (alchargo, 4WD, 007, ARCOgraphite, 94astro, askani79705, 8 invisible), 1,318 guests, and 24 spiders.
Topics303,499
Posts5,235,248
Members71,063
Page 2 of 2 1 2
Re: What's the correct way to use extended drain oil filters? [Re: wemay] #4886646 10/03/18 04:49 PM
J
jongies3 Offline
J
Change it every time, you're already in there, might as well do it! They're not that expensive.
2004 Toyota Tacoma 3.4 V6: Mobil 1 AFE 0W-30, FRAM PH3614 filter
2003 Buick Park Avenue Ultra S/C 3.8 V6: PYB 5W-30, FRAM PH3387 filter
2013 Honda 400EX ATV: Mobil 1 Racing 4t 10W-40, OEM filter
Re: What's the correct way to use extended drain oil filters? [Re: wemay] #4886648 10/03/18 04:50 PM
wemay Offline OP
Thanks everyone
19 VW Passat Wolfsburg 2.0TSI: VW 508.00 0W-20+VW o.filter+Fram CA9711 a.filter
13 Hyundai Santa Fe Sport 2.0T: Shell RGT 5W-30+H/K o.filter+NAPA 9670 a.filter
Re: What's the correct way to use extended drain oil filters? [Re: wemay] #4886681 10/03/18 05:38 PM
J
JeffKeryk Online Content
Online Content
J
Given the little bit of dirty oil in the filter, just let the pan drain a little longer and call it even...
Ha!
FYI, I am just starting to use the "every other service" myself.
I always wondered why a filter said 15K or 20K or whatever, cuz I do 5 to 7K services...
Never thought of the every other schedule...
Silly me!
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: What's the correct way to use extended drain oil filters? [Re: wemay] #4886683 10/03/18 05:42 PM
53' Stude Offline
I plan to run my last tough guard 4386 for 25k this time. Yes, i enjoy pushing the envelope smile
2009 Toyota Camry LE
161,669 miles
Valvoline Maxlife Synthetic 5w20 Dexos 1 Gen 2 SN+
Fram tough guard 4386 filter
Re: What's the correct way to use extended drain oil filters? [Re: wemay] #4886694 10/03/18 05:59 PM
A
Ablebody Offline
A
Originally Posted by wemay
Scenario:
OCI of 5K miles using Mobil 1 AP filters.
Which is best?
a. keep on the vehicle and just change the oil.
b. remove filter drain all the oil from filter and re-apply.
c. either one works, there's no downside with either.
Honestly, Ive taken them off and put back on several times. I have been putting the high temp neodymium button magnets on the space between the holes on the plate. I clean the magnets off at oil change and put the filter back on.
I also let some oil drain from filter and refill it.
Always slop oil on the seal so one hasn't ever stuck on.
Re: What's the correct way to use extended drain oil filters? [Re: wemay] #4886696 10/03/18 06:01 PM
L
Linctex Offline
L
I started working on piston engine aircraft in the 1980s.
It is VERY common in aviation to cut open aircraft engine oil filters (for various reasons)
I started to do this with various vehicles, also - more than 30 years ago.
Since I never saw any "metal" in any oil filter (just little carbon chunks) - I decided to run one (a Motorcraft FL-1a) for 30,000 miles with 3x 10K oil changes.
I did actually spin it off, drain it, and look it well over before refilling it and reinstalling it each time.
After 30,000 miles, it was just fine... a little more carbon bits, but really it was just fine.
I have reused oil filters numerous times in my life - people that say "don't ever reinstall one" are speaking from simple ignorance, and nothing more.
Re: What's the correct way to use extended drain oil filters? [Re: wemay] #4886773 10/03/18 07:40 PM
Z
ZeeOSix Offline
Z
My vote is leave it on. The small amount of oil with only 5K miles on it left in the filter won't matter one bit. Leave sleeping filters alone. grin2
Re: What's the correct way to use extended drain oil filters? [Re: wemay] #4887089 10/04/18 10:17 AM
sir1900 Offline
Scenario:
Which is best?
C. Have drained and reinstalled numerous times. Never a problem. Perhaps I'm just lucky. The only reason I would keep the filter on and change the oil only is if accessibility to the filter is not as easy and/or will create a huge mess every time the filter is removed.
2015 Infiniti Q50
Mobil1 5W-30 + FRAM PH6607
2015 Nissan Murano
Mobil1 AFE 0W-20 + Mobil 1 M1-108A
Re: What's the correct way to use extended drain oil filters? [Re: addyguy] #4887131 10/04/18 11:26 AM
P
Patman Offline
Global Moderator
Global Moderator
P
Originally Posted by addyguy
+1 to this!
Do NOT understand going to all the effort to do all the things for an OC, and not changing the filter while you are there.
I find changing the filter to be messy and annoying, so I'd rather just do it every other time, especially when I know the Ultra can easily handle double OCIs for me with room to spare. I will do the filter every time on my Corvette while it's still under warranty but once that's over I will do double OCIs on it too. It's not a money issue, it just makes that oil change more enjoyable for me (the one without the filter change)
2018 Corvette, 19k, M1 ESP Formula 5w30 & NAPA Gold
2006 Civic EX Coupe, 155k, PUP 5w20 & Fram Ultra
2010 BMW 328i X-Drive,127k, GC 0w40 & Fram Ultra
Page 2 of 2 1 2
