AC Delco CF188
by K20FA5 - 01/20/20 05:00 PM
Wix WL10255 6,254 miles
by K20FA5 - 01/20/20 04:56 PM
when did handsfree and bluetooth
by WhyMe - 01/20/20 04:50 PM
2020 Dodge Durango GT
by parshisa - 01/20/20 04:18 PM
F1 filters
by Bettez88 - 01/20/20 04:10 PM
Limitations on bluetooth OBDII scanners?
by jayjr1105 - 01/20/20 03:27 PM
Quaker state 5w20 $1.50
by Villalobos - 01/20/20 02:00 PM
Heavy Calibers
by rrretiree7 - 01/20/20 01:09 PM
Filter Efficiency Specs
by Talent_Keyhole - 01/20/20 01:05 PM
Larger filter for 19 Ram
by Schwifty - 01/20/20 12:52 PM
Duralast Max Ceramic Pads Photos!
by NASTI - 01/20/20 11:23 AM
expensive rotors
by Donald - 01/20/20 11:19 AM
3 Fram Ultra's Cut Open
by jetman - 01/20/20 10:31 AM
Standard Cab Commercial
by Duffyjr - 01/20/20 10:17 AM
The thin grease for firearms
by fnbrowning - 01/20/20 10:07 AM
Replace coil packs with spark plugs?
by jayjr1105 - 01/20/20 09:34 AM
Michelin Premier LTX Different Tread
by chuck wood - 01/20/20 08:49 AM
Best ear plugs for concerts,clubs?
by aquariuscsm - 01/20/20 07:47 AM
ckinch1, EAC1, Kronguy, jamespeter26, RSH
70491 Registered Users
100 registered members (25ring, AandPDan, 69GTX, 06_lx, AndyB, 10 invisible), 2,785 guests, and 25 spiders.
Topics300,360
Posts5,174,145
Members70,491
Accutire tire pressure gauges - two bad right out of the package. #4877539 09/24/18 08:57 AM
M
mrsilv04 Offline OP
M
I bought one of these a few years back, and it has been perfectly reliable. I keep it on the motorcycle.
Accutire MS-4021B Digital Tire Gauge
[Linked Image]
I have now bought two since, and both have been bad, right out of the package. I've taken the batteries out of the good one, and put them in both of the bad ones, no change. Plus, the batteries out of the new ones that don't work, are fine, when placed in the known good gauge.
Both of the bad ones came from different vendors. The last one came from Amazon.
Has anyone else had bad luck with these? Two bad ones... brand new, right out of the package... shows that this company might have a QC problem.
2004 Silverado - on its 3rd Jasper engine in less than one year.
Re: Accutire tire pressure gauges - two bad right out of the package. [Re: mrsilv04] #4877550 09/24/18 09:08 AM
rooflessVW Offline
Best reliable digital gauge I have used is the BMW-branded one.
But Accu-Gage dial pressure gauges are my go-to. Never had an issue and they stay accurate indefinitely as long as you don't smack them around.
"Zed's dead baby, Zed's dead."
Re: Accutire tire pressure gauges - two bad right out of the package. [Re: mrsilv04] #4877567 09/24/18 09:21 AM
E
Eddie Offline
E
I thought I had a bad new one that read 5 psi low. I found that the head was slightly unscrewed. I tightened the head and all was well. Ed
2014 CX5 Touring 2.5L :-)
Re: Accutire tire pressure gauges - two bad right out of the package. [Re: mrsilv04] #4877571 09/24/18 09:22 AM
M
mclasser Offline
M
I got this digital tire gauge from AAP years ago for less than $10. It's accurate and still works great.
[Linked Image]
2018 Hyundai Elantra VE
2013 Honda Pilot EX-L 4WD
2002 Honda Accord EX-L
Re: Accutire tire pressure gauges - two bad right out of the package. [Re: rooflessVW] #4877593 09/24/18 09:43 AM
L
LotI Offline
L
I've moved on from digital too. Analog dial is the way to go. No batteries, easier to read, and pressures don't need to be set to the 10th of a pound anyway.
03 Honda Interceptor
11 Kawasaki KLR 650
12 Ford E450 Cutaway
19 Buick Regal TourX http://www.fuelly.com/car/buick/regal_tourx/2019/loti/943992
Re: Accutire tire pressure gauges - two bad right out of the package. [Re: mrsilv04] #4877615 09/24/18 10:12 AM
A
ARCOgraphite Offline
A
Man I have been getting "Fleabay quality stuff from amazon lately - had to send back a lot of defective stuff.
AFA digital readout - Too many parts on the digital.
Ill stick with the simple pencil gauge.
I REALLY like dial , but one drop and your accuracy is toast.
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#8 60864mi-Subaru Idemitsu 0W20 + SOA Filter
Re: Accutire tire pressure gauges - two bad right out of the package. [Re: mrsilv04] #4877670 09/24/18 11:03 AM
supton Online Content
Online Content
How bad are the pencil ones? I have a few floating around but have never bothered to "gauge" them against one another.
2011 Toyota Camry, base, 2.5L/6MT, 200k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 157k, ours
1999 Toyota Camry LE, 2.2L/4AT, 220k, his
Re: Accutire tire pressure gauges - two bad right out of the package. [Re: mrsilv04] #4877941 09/24/18 03:41 PM
Stevie Offline
I have lots of the digital gauges that have given problems.
I use this one on my compressor as you can see the pressure as you are adding and I like the fitting that goes on tire valve. Doesn't lose air as connecting and disconnecting. problem is you have to change air line fitting to US ($1)
https://www.ebay.com/itm/Car-Digita...re-Air-Inflator-Tool-220PSI/142159629891
The pencil ones that Discount Tire gives you for free work great. Always accurate every time I check them.
Re: Accutire tire pressure gauges - two bad right out of the package. [Re: rooflessVW] #4878093 09/24/18 06:39 PM
Carmudgeon Offline
I have a couple Accutire Pro gauges from 20+ years ago. They're almost identical to the BMW-branded version, except they have a zero calibration button.
Always been accurate, and have never needed a battery. I'm not sure the current incarnations are of the same quality.
Re: Accutire tire pressure gauges - two bad right out of the package. [Re: mrsilv04] #4878350 09/25/18 05:28 AM
CapriRacer Offline
Could you tell us what was wrong with them?
CapriRacer
Visit my web site: www.BarrysTireTech.com
Re: Accutire tire pressure gauges - two bad right out of the package. [Re: CapriRacer] #4878515 09/25/18 08:20 AM
Duffyjr Offline
That would be nice, I have one in my wish list at amazon. I had two of them but forgot to take one out of the glove box of a car I sold a couple months ago. I found them to be a nice little gauge, they read the same back to back, I've had so many that wouldn't do that. They are also accurate when I compare them with my Longacre.
89 GMC Sierra Advanced 5w30/51036 Wix
08 Lucerne CX Advanced 5w30/1040 Gold
18 Toro Super Recycler T5 10w30
Re: Accutire tire pressure gauges - two bad right out of the package. [Re: supton] #4878645 09/25/18 10:32 AM
A
A
A good pencil is easily w/in 0.5 PSIG of a cal'd gauge on a pressure vessel. I usually buy three and keep the 2 that agree. Its just a general reference and I try keep the tires balanced within 1/4 psig of setpoint when I find the "sweett spot" ( usually stay within 2 psig up or down from door placard)… Once I ran 37 psig on 235 55r 16 (?) and pounded the strut top bearing race to pieces, - Same on a Mazda 626 I ran 35 on a 32 setpoint and pounded out the strut top steering ball race.
Tires are the first point of suspension compliance – and need to be compliant to some degree to absorb sharp road impacts.
Also try to get a low pressure pencil I think its 5-50psi rated. Don't get the 0-100 for a car.
