Is ford admitting to their filters tearing?
by advocate. 02/16/19 12:13 PM
Caliper piston replacement.
by LeakySeals. 02/16/19 11:30 AM
Speed Bleeders - Used Them?
by john_pifer. 02/16/19 11:19 AM
4EAT Subaru
by HowAboutThis. 02/16/19 10:38 AM
delete
by beanoil. 02/16/19 10:37 AM
First oil change
by Bill_W. 02/16/19 10:18 AM
Mobil M1-110A
by Purpfox. 02/16/19 10:17 AM
Oil recommendation for 2018 titan 4x2
by Ttown. 02/16/19 10:10 AM
M1 filters?
by dogememe. 02/16/19 09:44 AM
Granatelli Indy 500 and STP :)
by shanneba. 02/16/19 08:01 AM
2010 Chevy Corvette, Castrol GTX Magnatec 5w30
by montero1. 02/16/19 07:22 AM
veloster wheels on my sonata
by JustinH. 02/16/19 07:05 AM
Beast chewing on garage door seal
by LeakySeals. 02/16/19 03:01 AM
Weird Residue in New Fram Ultra
by mphilleo. 02/16/19 01:40 AM
0w20 vs 0/5w30 (yes I know another viscosity thread)
by SnowDrifter. 02/15/19 11:42 PM
skid plate
by mobilaltima. 02/15/19 10:32 PM
krzyq, Huberthagans, 3dfever, Mahmoud, Happycamper
67248 Registered Users
99 registered members (4WD, 69Torino, 240_Ed, ABerns, 12 invisible), 2,233 guests, and 51 spiders.
Topics298,272
Posts4,988,490
Members67,248
Most Online2,474
Feb 10th, 2019
6T50 - Maxlife or Dexron VI? #4811347
07/11/18 12:29 PM
07/11/18 12:29 PM
QC
jonnycraig Offline OP
QC
2013 Buick Verano, with the 6T50 GM transmission, and 2.0T engine. 33k miles.
Soon to be tuned to 290hp/335lb-ft by BNR Performance.
I want to put in the best transmission fluid possible before doing the tune.
Would you guys absolutely recommend using only DEXRON VI for tranny fluid? I would use Amsoil fluid, but I am looking into getting a Valvoline tranny service; as it covers up to 4k in damages in the future. However the only (2) transmission fluids I can use are 'Maxlife ATF' or 'Dexron VI' both made by Valvoline. The shop is telling me the Maxlife ATF is a better fluid, but I am free to use either or, both made by Valvoline. I know the Amsoil fluid is best, but like I said, if I do the Valvoline service, I am covered for up to 4k in tranny damages in the future, seems like a no brainer. Just need to know if I should use Maxlife or Dexron VI.
Again, the shop I will do the flush with (Valvoline VPS transmission service, to be precise) are telling me that Maxlife is a superior fluid to Dexron VI, and I should do with that. But I have seen very conflicting opinions...
Thoughts?
Re: 6T50 - Maxlife or Dexron VI? [Re: jonnycraig] #4811353
07/11/18 12:32 PM
07/11/18 12:32 PM
Phoenix, Arizona - USA
SirTanon Offline
SirTanon  Offline
The Valvoline MaxLife fluid is excellent stuff. I've run it in my Fusion's 6F35 trans for some time, in place of MC Mercon LV, which is basically the same stuff as Dexron VI. All things considered, you should get excellent results from it in your 6T50.
2010 Ford Fusion SE - 2.5 liter/6F35 Trans - 268,000mi
2014 Nissan Altima SL - 2.5 liter/CVT - 61,000mi
Re: 6T50 - Maxlife or Dexron VI? [Re: SirTanon] #4811357
07/11/18 12:36 PM
07/11/18 12:36 PM
QC
QC
Thanks SirTanon.
I am reading the spec sheet of both fluids, trying to determine which is superior; but since I'm no expert on transmission fluids, it's kinda hard, to say the least, haha.
I see the Maxlife fluid is a tiny bit thinner to start out.
Do we know which has a better shear resistance? Dexron VI or Maxlife?
Someone else told me:
"id go with the maxlife, because it has additives to prevent clutch slippage and glazing and many other things, valvoline dexron vi is just a "normal" synthetic dexron vi atf"
Re: 6T50 - Maxlife or Dexron VI? [Re: jonnycraig] #4811364
07/11/18 12:42 PM
07/11/18 12:42 PM
SirTanon Offline
SirTanon  Offline
From past experience, as well as feedback that I've read on this site and others, the consensus seems to be that while the MaxLife fluid does start out thinner, it seems to be much more shear resistant, and after some use, works out to be approximately the same viscosity as the Mercon LV / Dexron VI fluids are after they shear down some.
I don't have access to any hard data on this, but it does seem to be a common thread in many discussions. Take that as you will.
Re: 6T50 - Maxlife or Dexron VI? [Re: jonnycraig] #4811378
07/11/18 12:54 PM
07/11/18 12:54 PM
St. Charles County, Missouri
csandste Offline
csandste  Offline
Maxlife worked great in my Encore
2017 Kia Soul Plus-- VWB 5-30, 54,000 miles.
Re: 6T50 - Maxlife or Dexron VI? [Re: jonnycraig] #4811390
07/11/18 01:04 PM
07/11/18 01:04 PM
San Rafael, CA
dogememe Offline
dogememe  Offline
San Rafael, CA
Real Dexron VI such as Valvoline. I don't like universal fluids for domestic applications where legit fluids are readily available. For imports where OE fluids are not in stock at your local parts store Maxlife is totally cool.
2010 Ford Escape 2.5 ~94K Miles: Royal Purple 5W-30
2008 Ford Crown Vic P71 4.6 ~166K Miles: AMSOIL SS 0W-30
1995 Chevy Silverado 5.7 ~277K Miles: Delo 10W-30
Re: 6T50 - Maxlife or Dexron VI? [Re: dogememe] #4811401
07/11/18 01:16 PM
07/11/18 01:16 PM
QC
QC
Right, but see, that's the thing.. I'm told, Maxlife is a superior fluid to real Dexron VI.
What has higher actual real world shear resistance, etc?
I totally understand your position, and I tend to agree, but just like, GM's dexos1 gen 2 specification for their motor oils, it doesn't mean THAT much, when you have companies like AMSOIL who develop oils like Sig series which completely exceed GM's own standards, thus making it far superior than the GM specs.
Trying to find out if Maxlife is superior to Dexron VI. Yes, Dexron is the recommended fluid, but that doesn't mean much.
Re: 6T50 - Maxlife or Dexron VI? [Re: jonnycraig] #4811419
07/11/18 01:31 PM
07/11/18 01:31 PM
Ohio
beast3300 Offline
beast3300  Offline
Ohio
Full synthetic Dex6 GM branded is good stuff. I got some off Amazon last year. Works well, and you can't go wrong.
'03 Regal GS L67: PPUP 5w30/FU3980
'99 Grand Prix L36: R.I.P.
'07 LaCrosse L26: QS HM 5w30/TG3387A
ASE L1 MT
Re: 6T50 - Maxlife or Dexron VI? [Re: jonnycraig] #4811420
07/11/18 01:32 PM
07/11/18 01:32 PM
Virginia
mattwithcats Offline
Virginia
Take a look at Allison TES 295 transmission fluid.
Used in garbage trucks, and other heavy duty applications...
Just a little thicker than Dexron VI...
http://www.allisontransmission.com/parts-service/approved-fluids
2009 Smart Pure
Pennzoil Platinum Euro 0W-40, Purolator Synthetic PSL 14610, 45 mpg...
185/55R15 General HP tires, "H" speed rated, 44 psi (300 kpa)
Re: 6T50 - Maxlife or Dexron VI? [Re: beast3300] #4811454
07/11/18 02:14 PM
07/11/18 02:14 PM
Maricopa, Arizona
dave1251 Offline
dave1251  Offline
Maricopa, Arizona
All DEXRON 6 is synthetic.
don't use.
Re: 6T50 - Maxlife or Dexron VI? [Re: jonnycraig] #4811459
07/11/18 02:17 PM
07/11/18 02:17 PM
California
nthach Offline
nthach  Offline
California
I think that's a line of bologna.
MaxLife just happens to be a very good "universal" ATF that can be had for a even better price. It's a jack of all trades fluid. It's not Merc LV/Dex VI approved/licensed as GM and Ford dictate how those are to be fomulated.
I think you can't go wrong with MaxLife/Kendall VersaTrans LV/Castrol IMV Synthetic or officially-sanctioned Dex VI.
Re: 6T50 - Maxlife or Dexron VI? [Re: jonnycraig] #4811532
07/11/18 03:25 PM
07/11/18 03:25 PM
midwest
JamesBond Offline
JamesBond  Offline
midwest
I think that if you're banking on this valvoline oil change place to pay out for a new transmission just because you had the fluid serviced there you're dreaming. Especially if you have your engine aftermarket "tuned", and use a transmission fluid that's different from what the manufacturer recommends.
Re: 6T50 - Maxlife or Dexron VI? [Re: jonnycraig] #4811624
07/11/18 05:14 PM
07/11/18 05:14 PM
Hudson, NH
LeakySeals Online content
LeakySeals  Online Content
Hudson, NH
I exchanged 3 gallons of Maxlife through my 06 Escalade last year. My dash transmission temp gauge shows the transmission runs hotter than the OEM Dex VI it replaced. Some googling shows the current Maxlife has become thin.
Maxlife Dex/Merc ATF
[email protected]*C - 28.82
[email protected]*C - 5.91
VI - 156
ACDelco Dex VI
[email protected]*C - 30.6
[email protected]*C - 6.1
VI - 152
Next exchange I plan to go back to ACDelco Dex VI. See if the transmission runs cooler
06 Escalade 6.0L LQ9 AWD 165k M1 0w40
03 Maxima 3.5L POS 152k ST HM 10w30
Re: 6T50 - Maxlife or Dexron VI? [Re: LeakySeals] #4811664
07/11/18 06:01 PM
07/11/18 06:01 PM
QC
QC
VI - 156
ACDelco Dex VI
VI - 152
Thanks man.
Please keep us all posted in this thread here!
Re: 6T50 - Maxlife or Dexron VI? [Re: JamesBond] #4811665
07/11/18 06:02 PM
07/11/18 06:02 PM
QC
QC
Good point.
It's not sure I will get a tune, to be frank.
I most likely won't, as too much of a worry on reliability.
Moderated by  ekpolk
