0w20 vs 0/5w30 (yes I know another viscosity thread)
by SnowDrifter. 02/15/19 11:42 PM
skid plate
by mobilaltima. 02/15/19 10:32 PM
The Last Gladiators (French)
by Marco620. 02/15/19 08:54 PM
Rural King 5W30 Citgo Superguard blend 5qt jug $9.91
by tenderloin. 02/15/19 08:34 PM
Meet Watson!
by spasm3. 02/15/19 08:16 PM
Tie Rod and Ball Jt. Recommendations/Advi
ce
by coopns. 02/15/19 08:11 PM
Uninstall Avast
by willbur. 02/15/19 06:58 PM
Need a new toliet
by JLawrence08648. 02/15/19 06:55 PM
Help Me Choose A Smartphone
by Warstud. 02/15/19 05:29 PM
Source for Torque Wrench Calibration?
by SubLGT. 02/15/19 05:09 PM
Transmission Scraping Noise
by bprat318. 02/15/19 04:59 PM
Ok to mix gear oil viscosities?
by zuluplus30. 02/15/19 04:11 PM
Tore Wheel Cylinder Boot on 2007 Tacoma
by john_pifer. 02/15/19 04:10 PM
Spotify to home theater
by Malo83. 02/15/19 03:19 PM
6.0 powerstroke for a forever truck
by FLORIDA. 02/15/19 02:55 PM
Atwoods PYB 5QT jug $7.99 after rebate !!
by GMguy84. 02/15/19 02:52 PM
Torque Wrench Accuracy
by Kjmack. 02/15/19 12:57 PM
Thoughts on pennzoil 0w30 lx
by 750HMF. 02/15/19 12:26 PM
3dfever, Mahmoud, Happycamper, jftcat, TexasForever
67246 Registered Users
37 registered members (bfleeman, BrianF, Blkstanger, anndel, 1WildPig, Ag76, 2 invisible), 770 guests, and 56 spiders.
Topics298,255
Posts4,988,167
Members67,246
Most Online2,474
Feb 10th, 2019
Thick or Thin: What's more important for storage? #4810997
07/11/18 07:00 AM
07/11/18 07:00 AM
Michigan
Building3 Offline OP
Michigan
So for cars that are not used that much, for instance not at all in the winter in northern climates and perhaps once a week or so during nice weather, what's more important, a thin oil, say 0w-30 or something like that which may circulate quickly; or a thicker oil like 15w-50 that might adhere to bearings and other internal parts better than thin. I don't have enough technical knowledge to know, but both arguments sound reasonable.
Re: Thick or Thin: What's more important for storage? [Re: Building3] #4811007
07/11/18 07:13 AM
07/11/18 07:13 AM
'Stralia
Shannow Online content
Shannow  Online Content
'Stralia
Both of the statements that you provide as "bookend" arguments aren't factual, or realistic.
Just use what's in the book. And give it a decent run when you have the opportunity.
Re: Thick or Thin: What's more important for storage? [Re: Building3] #4811009
07/11/18 07:21 AM
07/11/18 07:21 AM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
What temperatures will you be starting the engine?
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Thick or Thin: What's more important for storage? [Re: Building3] #4811016
07/11/18 07:28 AM
07/11/18 07:28 AM
WNY
redhat Offline
redhat  Offline
WNY
I'm sure my fellow IT folks on here will get it when I say:
I was coming in here thinking this might be about network attached storage.
17 Taurus Limited AWD - Dealer Fill of MCSB 5W-20 FL500S, 16k
14 Civic EX Coupe - NAPA Syn 0W-20 TG7317, 64k
09 Accord Sedan 5MT - Traveler 15W-40 XG7317, 151k
87 Regal Limited - 20W-50 VR1 WIX 51042
Re: Thick or Thin: What's more important for storage? [Re: CT8] #4811019
07/11/18 07:31 AM
07/11/18 07:31 AM
Michigan
Michigan
Cars will be started at 55F (in a heated garage) and up to 95F in the summer time. Cars will be driven in temps as low as 40F up to 95F
Re: Thick or Thin: What's more important for storage? [Re: Building3] #4811056
07/11/18 07:53 AM
07/11/18 07:53 AM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
Thicker oil.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Thick or Thin: What's more important for storage? [Re: Building3] #4811059
07/11/18 07:55 AM
07/11/18 07:55 AM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
After a prolonged period of time the grade of the oil isn't going to make a bit of difference in regards to the residual film thickness. After a few hours the film thickness is down to a few microns regardless of the viscosity of the oil.
1994 BMW 530i, 241K
1996 Honda Accord, 267K
1999 Toyota Sienna, 409K
2000 Toyota ECHO, 280K
Re: Thick or Thin: What's more important for storage? [Re: Building3] #4811075
07/11/18 08:07 AM
07/11/18 08:07 AM
Fort Lauderdale, FL
DoubleWasp Online content
DoubleWasp  Online Content
Fort Lauderdale, FL
Oil weight will be much less a factor than making sure the system is primed before starting the engine.
I've worked it out to where I pull the appropriate fuse before storing, and then priming the engine before re-inserting said fuse before actual starting.
Re: Thick or Thin: What's more important for storage? [Re: Building3] #4811119
07/11/18 08:37 AM
07/11/18 08:37 AM
Hudson, NH
LeakySeals Offline
LeakySeals  Offline
Hudson, NH
Maybe the clinging molecules in castrol edge magnatec would help?
06 Escalade 6.0L LQ9 AWD 165k M1 0w40
03 Maxima 3.5L POS 152k ST HM 10w30
Re: Thick or Thin: What's more important for storage? [Re: Building3] #4811126
07/11/18 08:46 AM
07/11/18 08:46 AM
5600 feet elevation, Arizona
double vanos Offline
0w40
Sabine Schmitz is the Queen of the 'Ring; Svetlana Kapanina is the Queen of the SKIES...
Re: Thick or Thin: What's more important for storage? [Re: Building3] #4811189
07/11/18 09:55 AM
07/11/18 09:55 AM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
For storage the biggest issue is "drain off". It happens sometimes, mostly with synthetic oils. But, that's a very broad category in the US ...
Some oils have a lower surface tension based on the chemistry. Lower surface tension helps them attain things like 0W, etc. but it means they are less likely to maintain capillary fill. Small voids will always have a film of oil once wetted. But they can loose the thicker film cushion. Start the motor after sitting for a while (week) and they rattle until ALL the oil circulates. And since half the engine is lubed by splash and sling oil (not pumped oil), they can be quite noisy.
Good old dino oils have a mix of hydrocarbon chains by their nature. They almost always have higher surface tension and better capillary fill. They are almost always quieter on cold start after sitting.
The other issue is the filter and the anti-drain-back-valve. You want the best one you can get so that oil does not drain back into the sump. For me, that's always been WIX or Baldwin. Napa GOLD same. Use best filter you can (for construction, not necessarily efficiency).
So something like Chevron Supreme 10W-30 (easily good down to 0*F) and a Napa Gold filter means more robust residual film, quiet cold starts, and good lubrication. It's the residual oil film that has to do all the work until the oil is moving well. Sling oil off the crank is only oil that gets to cylinder walls and some cam systems.
Pumped pressure is there simply to overcome gravity for the upper end. It does not do much for a lot of the motor. So I think about residual oil film strength and film thickness over time, for seldom used vehicles (ranch trucks that only run seasonally, tractors, etc.).
If your vehicles seldom run, maybe this is the approach to take ...
Re: Thick or Thin: What's more important for storage? [Re: Building3] #4811265
07/11/18 11:21 AM
07/11/18 11:21 AM
WY
sloinker Offline
sloinker  Offline
WY
Ester based oils have an inherent polar affinity for metal surfaces.
Re: Thick or Thin: What's more important for storage? [Re: kschachn] #4811604
07/11/18 04:46 PM
07/11/18 04:46 PM
'Stralia
'Stralia
Bearings and pistons will still be chock a block full after years of sitting.
I've NEVER pulled apart a dry engine.
Re: Thick or Thin: What's more important for storage? [Re: Building3] #4811629
07/11/18 05:22 PM
07/11/18 05:22 PM
Fredericksburg, VA
JAG Offline
JAG  Offline
Fredericksburg, VA
I donít think itís an issue worth spending much thought on, from a lubrication on startup perspective. It might help to have a bottle of Hy-per Lube Zinc Replacement additive in the oil since it has viscous polymer esters that are attracted to metal more so than Groups II-IV. Itís not a question of how thick are the oil films when the engine is off. Most of those thicknesses are next to zero because two or more parts have a compressive load on them, and since there is no motion, the films collapse to near zero. However, viscous esters are preferentially attracted metals more so than less polar oils, causing their concentration next to the surfaces to be higher than their concentration away from the surfaces, especially when the engine has been sitting for a long time. Because they are viscous, they help with lubrication when the engine is started up. I have no idea how much difference it would make but it only costs about $16.
Engines that sit outside and are infrequently used can have corrosion issues, albeit likely minor enough not to show up visually but enough to show up in a UOA. Some people have used oils that have additives that inhibit corrosion in the vapor phase. Some boat engine oils have these, such as Valvoline: https://www.valvoline.com/en-australia/our-products/engine-oil/valvoline-4-stroke-outboard-oil
Re: Thick or Thin: What's more important for storage? [Re: Shannow] #4812031
07/12/18 07:36 AM
07/12/18 07:36 AM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
Absolutely, I didn't mean for my post to imply otherwise. I tried to word it carefully as a specific response to the question title of "Thick or Thin: What's more important for storage?" I was pointing out that after a prolonged drain time the viscosity is not the determining factor in residual film thickness.
1994 BMW 530i, 241K
Moderated by  ekpolk
