PUP is now SN + ??? Formulation change??
by Lazydan. 02/22/19 04:17 PM
Got a new wireless printer/MFC
by y_p_w. 02/22/19 02:48 PM
NM
by y_p_w. 02/22/19 02:47 PM
Names of brand names quality non-pro multi-meter
by JLawrence08648. 02/22/19 02:16 PM
Lady Luck
by CourierDriver. 02/22/19 02:06 PM
Ford MPG
by Zee09. 02/22/19 02:03 PM
Canucks in need of licensed ATF+4
by StevieC. 02/22/19 12:42 PM
Viscosity of Synthetic oil in the bottle
by JLR. 02/22/19 12:35 PM
2006 Tundra trans fluid change with Toyota WS
by njohnson. 02/22/19 11:32 AM
How do you prefer your vehicle seats?
by ZZman. 02/22/19 10:35 AM
GKN awd vs the Haldex in my Chevy Equinox
by wbwanzer. 02/22/19 10:28 AM
Craftsman Tools “Ultimate Collection”
by dkryan. 02/22/19 09:38 AM
Q 50 maintenance questions
by Robertslowpoke. 02/22/19 09:19 AM
No start
by Roughneck777. 02/22/19 08:24 AM
A Quick Question for ebay Sellers...
by Touring5. 02/22/19 07:38 AM
jcthorne, duckthis1, Roughneck777, KDW, avantika31
67313 Registered Users
108 registered members (2015_PSD, 007, 2004tdigls, 1978elcamino, 240_Ed, 10 invisible), 1,841 guests, and 53 spiders.
Topics284,665
Posts4,874,810
Members67,313
Most Online2,548
Feb 16th, 2019
Tomorrow brings the switch over to Castrol #4807007
07/06/18 04:35 PM
07/06/18 04:35 PM
New Jersey
93cruiser Offline OP
New Jersey
Tomorrow my 2007 Tundra with 165k miles will start consuming the 10 gallons of Castrol Edge 0w20 that I have. I suspect everything will be fine, but nervous due to this being new but opened oil. It was oil used for testing dispensers. Dispenser was put on 5 gallon container in the off position, bottle turned over, any amount leaked was measured under varying conditions and temperatures.
I'm sure it will be fine. I will go 7k the first time on it, then back up to 10k if all seems well. I am hoping for the same results which are no oil usage, not blackening at all, sounds good when running, etc. Previous oil was mobil 1.
If all is well, the RAV4 will get it as well. 10 gallons to use up, then Idemitsu time.
Re: Tomorrow brings the switch over to Castrol [Re: 93cruiser] #4807012
07/06/18 04:39 PM
07/06/18 04:39 PM
ME
eljefino Offline
eljefino  Offline
ME
I hope you sleep tight.
Re: Tomorrow brings the switch over to Castrol [Re: 93cruiser] #4807014
07/06/18 04:40 PM
07/06/18 04:40 PM
1/2 hr N.E. of Detroit
Triple_Se7en Offline
Gonna take a half decade at least, to use that 10 gallons of oil.
Castrol Edge is good stuff, so fear-not.
2019 Hyundai SantaFe 2.4 factory fill / QS 5w20 conv. / Mahle OEM oil filter
04 Chev Colorado 3.5 QS / Valv syn 5w30 blend K&N filter
03 Chev Malibu 3.1 QS / Valv Syn 5w30 blend Fram EG filter
Re: Tomorrow brings the switch over to Castrol [Re: 93cruiser] #4807018
07/06/18 04:45 PM
07/06/18 04:45 PM
Phoenix, AZ
Nick1994 Offline
Nick1994  Offline
Phoenix, AZ
I'd send in a VOA
2015 Hyundai Sonata 2.4L 91k Motorcraft Synthetic Blend 5w30 & OEM
2000 Toyota Camry 2.2L 232k Valvoline 5w30 & Fram Ultra
1996 Jeep Cherokee 4.0L 148k Mobil 1 HM 10w40 & Fram Ultra
Re: Tomorrow brings the switch over to Castrol [Re: 93cruiser] #4807060
07/06/18 05:41 PM
07/06/18 05:41 PM
MIchigan
Warstud Offline
Warstud  Offline
MIchigan
Originally Posted By: 93cruiser
My 2007 Tundra with 165k miles will start consuming the 10 gallons of Castrol Edge
That's quite the oil burner....maybe you should try some Maxlife. LOL
Re: Tomorrow brings the switch over to Castrol [Re: Triple_Se7en] #4807079
07/06/18 06:10 PM
07/06/18 06:10 PM
New Jersey
New Jersey
Not really, we both drive 17k-19k per year. 10k oci. 2 gallons for tundra, 5 quarts for rav4. Probably 1 and 3/4 years doing quick math. I then have gallons of Idemitsu 0w20. Saving the Idemitsu since it is sealed.
Re: Tomorrow brings the switch over to Castrol [Re: 93cruiser] #4807195
07/06/18 08:41 PM
07/06/18 08:41 PM
NY
mx5miata Offline
mx5miata  Offline
NY
Hopefully it doesn't contain any debris or moisture in it.
NAPA FULL SYNTHETIC 0w20 Partsplus oil filter
Wix air filter
Re: Tomorrow brings the switch over to Castrol [Re: mx5miata] #4807204
07/06/18 08:53 PM
07/06/18 08:53 PM
Mississippi
TheLawnRanger Offline
Mississippi
Does Castrol have a reputation for containing debris and moisture? I use magnatec and have not seen this as of yet.
'99 Cavalier 5w 30 SuperTech conventional
'11 Impala 5w 30 Magnatec full synthetic
'12 Colorado 5w 30 Magnatec full synthetic
*regular Wix oil filters for all
Re: Tomorrow brings the switch over to Castrol [Re: TheLawnRanger] #4807214
07/06/18 09:06 PM
07/06/18 09:06 PM
Mahzurrah!
KCJeep Offline
KCJeep  Offline
Mahzurrah!
Uh no. He's talking about opened oil.
2018 VW Passat GT VR6 - 4k - Valvoline MST 5w40 - VW OEM filter
2012 KIA Sedona 95k - PP HM 10w30
2009 Ford Focus 133k - Supertech FS HM 5w30
2004 Jeep Grand Cherokee, gone but not forgotten.
Re: Tomorrow brings the switch over to Castrol [Re: KCJeep] #4807224
07/06/18 09:14 PM
07/06/18 09:14 PM
Mississippi
Mississippi
Ok, that's good. I use open oil at times as well but it's usually left over from the last oil change and stored in a dry place. Thanks for the reply.
Re: Tomorrow brings the switch over to Castrol [Re: KCJeep] #4807487
07/07/18 08:22 AM
07/07/18 08:22 AM
Anytime you leave a half-quart leftover oil in the garage, it's opened oil the next time you need to use it.
You still use it - don;t you?
OP never said the container came with no lid or cap on it. He claimed the contents were not sealed - as new oil generally is. Had the turned over container not had a cap/lid, all of the oil would have dispensed on the floor. So obviously it was capped / lid in some manner. From the sounds of it, just a little seeped out instead.
Re: Tomorrow brings the switch over to Castrol [Re: 93cruiser] #4807490
07/07/18 08:27 AM
07/07/18 08:27 AM
PimTac Offline
PimTac  Offline
So, this oil fell off the back of a oil dispenser to paraphrase a familiar saying?
Cannot see signatures any longer so it doesn’t matter.
Re: Tomorrow brings the switch over to Castrol [Re: PimTac] #4807526
07/07/18 09:09 AM
07/07/18 09:09 AM
New Jersey
New Jersey
Not really. Testing of new dispensers requires oil to test them. When they were done testing, I took two 5 gallon containers, leaving about another 100 gallons of 5w20, 10w30, 5w30, and some 40 weight. By the time I got back again, they called a used oil company that pouredit all into a drum and sucked it out into their tanks. More testing soon, they have another 100 gallons to test after some improvements to dispenser. Why they don't use a ball valve is beyond me.
Re: Tomorrow brings the switch over to Castrol [Re: 93cruiser] #4807556
07/07/18 09:37 AM
07/07/18 09:37 AM
PimTac Offline
PimTac  Offline
Thanks for clarifying. It sounds like a huge waste to me. I agree, a ball valve would be ideal or a system that is already tested so this waste doesnt have to repeat itself for every new customer.
Re: Tomorrow brings the switch over to Castrol [Re: PimTac] #4807608
07/07/18 10:38 AM
07/07/18 10:38 AM
New Jersey
New Jersey
They have dispensers, but they designed new and improved dispensers, so they need to test them. Big waste of money for the manufacturer. Ball valve and done. I was told that method(ball valve) was too expensive, so they came up with whatever.
Gets me oil so I am fine with it.
I tried getting the dispensers, but no dice. Now the fun of pouring from a 5 gallon container starts.
Moderated by  ekpolk
