Originally Posted By: 2015_PSD
Originally Posted By: ant
What about Valvoline Synpower 75w90? How does it compare to Mobil, Redline and Amsoil?
Though I initially suggested Amsoil, based upon your intended usage:
Usage is primarily driving to and from work, and once or twice a year at a local dragstrip. Would a 75w90 have advantage over Redline 75w85 in terms of wear?
In all seriousness, any oil you choose would be fine. In fact, I would look at the cheapest oil that meets specification and just change it more often than looking at a uber premium (more expensive) oil which has its strength in extended OCIs.
You're right probably don't need the most expensive oil, just need one fit for purpose. Do you see any issue with the 75w90 given that it's 50% higher viscosity?
