What pressure washer should I buy?
by wallyuwl. 03/25/19 11:27 AM
Natural Gas from Ohio Valley
by SubLGT. 03/25/19 11:18 AM
CVT Reliability and Durability
by raffy. 03/25/19 11:00 AM
comfortable seats
by redhat. 03/25/19 10:29 AM
walmart evinrude tcw-3 clearance score
by 1978elcamino. 03/25/19 10:15 AM
Mixing SN/d1G1 with SN+/d1G2?
by doyall. 03/25/19 10:14 AM
Best 2nd Phone Number App ?
by LoneRanger. 03/25/19 09:56 AM
Crud! Wix jacking up prices again! :(
by SubieRubyRoo. 03/25/19 09:53 AM
Interior "quick detailer"
by Redright9. 03/25/19 08:21 AM
Seafoam For Last 100 Miles Before Oil Change ?
by ChrisD46. 03/25/19 07:56 AM
WIX 57151XP factory filled with synthetic oil
by Donald. 03/25/19 06:58 AM
BMW Buying Guide: Every Model, Explained
by wemay. 03/25/19 05:43 AM
Double Din Android Auto Advice
by JeffKeryk. 03/24/19 11:25 PM
VW mk5 a/c intermittently works
by ram_man. 03/24/19 11:01 PM
DIY alignment done right?
by tookien. 03/24/19 10:03 PM
Cell phone privacy question
by loneryder. 03/24/19 10:00 PM
sonusfaber, Rollo, Drifted, Jcar516, gregjr7
67614 Registered Users
117 registered members (4WD, alteredtuning990, Aero540T, badtlc, avi1777, 97f150, 13 invisible), 2,158 guests, and 59 spiders.
Topics286,395
Posts4,907,511
Members67,614
Most Online2,967
Mar 10th, 2019
What’s the difference in these greases? #4804528
07/03/18 10:17 PM
07/03/18 10:17 PM
Georgia
Jetstreamz06 Offline OP
Georgia
What is the differences between vavoline crimson, cerulean, palladium?
Re: What’s the difference in these greases? [Re: Jetstreamz06] #4804539
07/03/18 10:24 PM
07/03/18 10:24 PM
out there
spasm3 Offline
spasm3  Offline
out there
13 elantra 75k 5w30 QSUD
03 chevy avalanche 80k synpwr 5w30
17 mazda cx-5 9500 miles m1 0w30
Re: What’s the difference in these greases? [Re: Jetstreamz06] #4804644
07/04/18 04:57 AM
07/04/18 04:57 AM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
I noticed Napa Canada carries Valvoline grease including the full synthetic grease.
If you want the job done right......do it yourself.
Re: What’s the difference in these greases? [Re: Snagglefoot] #4804656
07/04/18 06:03 AM
07/04/18 06:03 AM
wv
krismoriah72 Offline
wv
Mystik JT-6 covers all the bases. No need for boutique greases.
Re: What’s the difference in these greases? [Re: Jetstreamz06] #4804691
07/04/18 07:13 AM
07/04/18 07:13 AM
Georgia
Georgia
Thanks
Re: What’s the difference in these greases? [Re: Jetstreamz06] #4804894
07/04/18 10:24 AM
07/04/18 10:24 AM
Georgia
Georgia
What would be an example of when to use each one of these?
Re: What’s the difference in these greases? [Re: krismoriah72] #4805356
07/04/18 10:17 PM
07/04/18 10:17 PM
New Jersey
JHZR2 Offline
Global Moderator
JHZR2  Offline
Global Moderator
New Jersey
I'm not sure I'd call any of the greases listed "boutique".
Re: What’s the difference in these greases? [Re: krismoriah72] #4805371
07/04/18 11:01 PM
07/04/18 11:01 PM
Texas
4WD Online confused
4WD  Online Confused
Texas
Seems there are at least a couple JT6 choices … I use the lower temp (green tube) for boat trailer bearings and on the outboard … very waterproof and love the almost clear color …
… popular with fishermen and farmers where I live … often one in the same …
Re: What’s the difference in these greases? [Re: Jetstreamz06] #4805400
07/05/18 12:43 AM
07/05/18 12:43 AM
Snagglefoot Offline
Snagglefoot  Offline
Like this.
Re: What’s the difference in these greases? [Re: Jetstreamz06] #4805401
07/05/18 12:45 AM
07/05/18 12:45 AM
Snagglefoot Offline
Snagglefoot  Offline
There is also this that is for marine use.
Re: What’s the difference in these greases? [Re: Jetstreamz06] #4805493
07/05/18 07:44 AM
07/05/18 07:44 AM
MI
doitmyself Offline
doitmyself  Offline
MI
I'm not sure what the marketing scheme of these products are. I.E., what niche they occupy. Maybe the industrial line? They seem to have good, average attributes and are similar to other basic grease lines.
Crimson - other companies market as "multi purpose" grease. It is a lithium base grease with less high temperature tolerance, lower timken extreme pressure, etc.. Use for general purpose, low "needs" applications around the farm, etc.. Not for disc. brake wheel hubs (need higher temp. rating). Tends to be the "budget" grease.
Cerulean - other companies market this as extreme pressure,high temperature grease. This is an lithium complex base grease with higher temperature and timken extreme pressure capabilities. It "should" be good for bearing hubs of disc brake vehicles. In my opinion, this is the most common, best general use grease (lithium complex) that covers "most" average use needs.
Pallidium - similar to the Cerulean, with the traditional 3% moly added. It is better for shock loaded, sliding applications like the bushings on a tractor front end loader. I believe it is not recommended for U joints (needle bearings slide instead of spin). It's use for ball/taper wheel bearings has no consensus (Ford recommends moly wheel bearing grease,others not.). For extreme industrial applications of "sliding" parts, there are 5% moly greases.
In the Mystic line https://www.mystiklubes.com/Category.do?code=GREASE The above greases would be similar to green tube multi purpose, red tube high temp, and gray tube high temp. with moly..
Some people associate the grease colors red, blue, green, etc. as higher quality. It's just dye and makes it no better than regular honey/tan color grease.
Someone correct me if necessary. My grease expertise is marginal.
Re: What’s the difference in these greases? [Re: Jetstreamz06] #4805822
07/05/18 12:53 PM
07/05/18 12:53 PM
WA (USA)
Y_K Offline
Y_K  Offline
WA (USA)
Agree, not as much 'boutique', rather marketed as specialty. Watch for the oil viscosity though, some are better suited for bulldozers. My Landcruisers didn't like the Valvoline synthetic soap, I switched to Chevron Delo ESI grease for all 6 zerks and front wheel bearing repacks - works very well in my case
Re: What’s the difference in these greases? [Re: Y_K] #4806551
07/06/18 08:26 AM
07/06/18 08:26 AM
Snagglefoot Offline
Snagglefoot  Offline
Just curious. What did you observe in thinking that Valvoline synthetic soap was not working for you?
Re: What’s the difference in these greases? [Re: Snagglefoot] #4806879
07/06/18 03:01 PM
07/06/18 03:01 PM
WA (USA)
Y_K Offline
Y_K  Offline
WA (USA)
The soap was becoming 'dry' too quickly after application in the yoke slider. That is, the oil would be gone too quickly and the sponge left would be incosistent. Had to purge a few times. Delo ESI acts like a high quality lube, surprising for a $3+ tube stuff, more like a high end lube from LE or TRC for much less. It has its limitations as well, but for that application and climate it's simply perfect in my case. I buy a 10-pcs box at a local distributor for $33+.
