Originally Posted By: IndyFan
Originally Posted By: troutfisher
So I have 2005 Chevy 1500 Regular Cab 2wd with the nv3500 5 speed trans,today launching my new 18” polar kraft for the first time,was a bad experience,had to slip the clutch the whole way out of the water,with a bit of tire spin,
Rewarded by the nice smell of burnt clutch in the parking lot, truck does wonderful towing the boat otherwise it’s just the 20 seconds pulling it out of the water,I feel like if I do this every time,I am going to burn the clutch up,
So anybody else launch boats with a 2wd stick?
How do you do it?
I do with my Jeeps all the time, in 2wd. They have very low 1st gear ratios and excellent traction control, so I never have to engage 4wd. Sounds like you may need a lower 1st gear.
As you already know Jeep is a different animal.
A stock 2 WD vehicle with a stick on a wet boat ramp sucks. With 3.73 rear you might be able to get away with it, depending on the weight of the boat, 4.10 is better. The parking brake trick helps, chocks with rope attached that are holding the vehicle are even better, having two assistants to pull them out of the way helps, or a long 2x6 used as a chock and one assistant works. Or just drive over the thing. The boat I pulled weighed more than the 2WD PU by a lot. Same boat 4WD in 4L with a stick and granny gear was very easy. In the perfect world having the right vehicle for the job is everything. Even something as simple as getting a 2WD stick with a 3.00 rear up car ramps can be a PITA. Ask me how I know.
I remember seeing a guy in a VW Golf with a 5 speed try to pull a Whaler out on a low tide. He thought he was smart with FWD on a less slick part of the ramp would help. His stick driving skills were marginal, and the boat and trailer pulled the little VW into the drink. Not good!
