Originally Posted By: wag123
I am the one in this thread to point out that flashing brake lights were not DOT approved and illegal in
SOME states.
Just because something is not DOT approved for inclusion by manufacturers in new vehicles does not necessarily mean that it is illegal.
The photometric requirements and behavior of brake lamps is outlined in Federal Motor Vehicle Safety Standard No. 108 - they are required to burn steadily when the brakes are applied. There is no allowance for flashing. Because it is a federal safety standard, states may not override it. In the event of a conflict ('my state's motor vehicle code says it's okay for brake lights to flash'), the state loses.
It wouldn't be much of a federal
safety standard if states could override parts of it arbitrarily, would it?
Quote:
The legality of installing/using an accessory after a vehicle is manufactured is entirely up to the states.
Only if the accessory is not regulated by or in conflict to federal safety standards. For example, if you want to put a Rudolph nose on the center of your front grille at Christmas, chances are it is not going to affect the crashworthiness of your vehicle, so would not be prohibited to sell or install. However, if the Rudolph nose is one that lights up bright red, that would be in violation of FMVSS 108 and would not only be illegal but unwise for obvious reasons.
Flashing brake lamps are not legal for passenger vehicles, regardless of what the people selling/installing these modifications or your state says. I can only assume that the sellers/installers are clueless about the law - it is either that, or they are outright lying.
We had this discussion over in the motorcycle section, my post below has cites:
https://www.bobistheoilguy.com/forums/ub...mod#Post4772803
