Vehicle in question is the S10 2.2 I4 5MT
So recently I've developed a very light lifter tick when cold and hot. It only last 30 seconds or so and goes away when you bump the throttle and doesn't come back till you shut off the vehicle. After a 5 minute restart it will do it. It has always had a knocking noise when first run, especially when real cold (below 30*F), but never a ticking noise. This all started when I changed the oil a couple weeks ago using Super Tech 5w30 Full Syn HM and a Napa Gold 1040 filter. Previous oil change was Rotella T5 10w30 and a AcDelco PF47 and it didn't do it. Oil pressure shows around 60psi stone cold and gets to around 25 when run a bit (both idle pressures). Is it simply a filter/oil issue or something sinister brewing and it's just a coincidence? Truck has turned into 1/2 daily driver with my new job and it has to get run hard to get going up the mountain roughly 3-4 days a week depending on weather.
