Going by HTHS
by JLTD. 02/21/19 02:59 AM
Quick Struts vs Replacing the struts by themselves
by das_peikko. 02/20/19 11:50 PM
Walmart Oil clearance # 2
by GMguy84. 02/20/19 11:14 PM
ST Syn in a TGDI?
by BTLew81. 02/20/19 09:52 PM
The Virus That Kills Drug-Resistant Superbugs
by StevieC. 02/20/19 09:50 PM
Opinion Of Dodge Nitro
by Warstud. 02/20/19 09:26 PM
Cheap first car
by LeakySeals. 02/20/19 09:08 PM
Grand Caravan break in
by pda1122. 02/20/19 09:07 PM
Million mile Lexus
by Skippy722. 02/20/19 08:57 PM
Antioxidant additive overdose
by xomyeusun. 02/20/19 08:50 PM
F15 Arrested Landing at Portland.
by PimTac. 02/20/19 08:43 PM
Why is Mobil 1 0w30x1 rated higher than most
by spiderbypass. 02/20/19 08:14 PM
Castrol Confusion
by PWMDMD. 02/20/19 07:13 PM
Crashed the Volt this morning...
by 14Accent. 02/20/19 06:55 PM
Best place to file online for Fed taxes?
by Vern_in_IL. 02/20/19 06:47 PM
vavoline instant oil change
by silver1. 02/20/19 06:23 PM
alienyouth33, RoyFJ, Intell77, RA_TJ, tiberius54
67294 Registered Users
67 registered members (Best F100, 69Torino, Billbert, bismic1, Astro_Guy, 9 invisible), 802 guests, and 51 spiders.
Topics284,589
Posts4,872,998
Members67,294
Most Online2,548
Feb 16th, 2019
How Fast to Run a ZeroTurn Mower #4792560
06/20/18 08:10 PM
06/20/18 08:10 PM
VA
Gebo Offline OP
Gebo  Offline OP
VA
I've always had rider mowers where they say to run them full throttle when mowing grass. Well, I did that today with my ZTurn and I am assuming it was very entertaining for my neighbors. At what speed do I run a ZTurn?
'98 LEX LS400 290K
'02 4Runner 230K
'05 Lex LS430 85K
'07 Lex GX470 65K
Amsoil in last two.
Schaeffer in the first two.
Re: How Fast to Run a ZeroTurn Mower [Re: Gebo] #4792567
06/20/18 08:16 PM
06/20/18 08:16 PM
out there
spasm3 Offline
spasm3  Offline
out there
I run my toro zturn at full throttle. But the hydro's control forward speed. I have a two speed selector for fast/slow.
13 elantra 75k 5w30 QSUD
03 chevy avalanche 80k synpwr 5w30
17 mazda cx-5 9500 miles m1 0w30
Re: How Fast to Run a ZeroTurn Mower [Re: Gebo] #4792569
06/20/18 08:16 PM
06/20/18 08:16 PM
Houston, Texas
motor_oil_madman Offline
Houston, Texas
The sales guy at the mower dealer said they're designed to run at top speed. Assuming it's smooth enough and the grass is at your standard weekly 3" long. Now this is only if you have a side discharge. If you have a mulch kit, you'll probably have to slow down a bit. I find a mower is like a boat, it's usually too bumpy to run them at full speed.
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: How Fast to Run a ZeroTurn Mower [Re: Gebo] #4792571
06/20/18 08:17 PM
06/20/18 08:17 PM
MI
doitmyself Offline
doitmyself  Offline
MI
You run the engine at full throttle for the steering pumps and blade speed to operate correctly. You adjust your traveling speed via the control handles to match your conditions (grass height, ground roughness, etc.). Commercial ZTR's have faster blade speeds (and other attributes) to handle faster mowing.
Re: How Fast to Run a ZeroTurn Mower [Re: Gebo] #4792582
06/20/18 08:28 PM
06/20/18 08:28 PM
Virginia
GravelRoad Offline
GravelRoad  Offline
Virginia
The same. Full throttle for fastest blade speed and adjust your driving speed according to grass/terrain.
What were you doing "entertaining for my neighbors"? Spinning in circles? crackmeup
2016 Subaru Outback Premium 2.5. PP 5w30 oem filter
2018 Hyundai Kona 1.6T. Lifetime dealer free oil/filter change
Re: How Fast to Run a ZeroTurn Mower [Re: Gebo] #4792590
06/20/18 08:32 PM
06/20/18 08:32 PM
out there
spasm3 Offline
spasm3  Offline
out there
Just be aware that while you can " zero turn" , doing so on wet grass at the shortest turning radius will tear the grass.
Re: How Fast to Run a ZeroTurn Mower [Re: Gebo] #4792605
06/20/18 08:43 PM
06/20/18 08:43 PM
Buffalo, NY
JTK Offline
JTK  Offline
Buffalo, NY
Are we talking max ground speed or max governed engine RPM?
Running the engine at max RPM is recommended for pretty much all OPE.
For ground speed, you can go as fast as your terrain, mowing and safety needs dictate.
2017 Ram 1500 4x4, 3.6L. 2016 Nissan Quest SV (Babe magnet IV)
Re: How Fast to Run a ZeroTurn Mower [Re: Gebo] #4792788
06/21/18 05:57 AM
06/21/18 05:57 AM
VA
Gebo Offline OP
Gebo  Offline OP
VA
I am talking about the engine speed. It seemed hard to control the ground speed and turning and such when I had the engine RPM's at full throttle. And I do have a mulching kit.
I felt out of control but it was my first time using the ZTurn.
'98 LEX LS400 290K
'02 4Runner 230K
'05 Lex LS430 85K
'07 Lex GX470 65K
Amsoil in last two.
Re: How Fast to Run a ZeroTurn Mower [Re: Gebo] #4792878
06/21/18 07:28 AM
06/21/18 07:28 AM
Houston, Texas
Houston, Texas
You just have to learn with time. Practice with knowing where neutral is on the sticks and that will help.
Re: How Fast to Run a ZeroTurn Mower [Re: Gebo] #4792882
06/21/18 07:39 AM
06/21/18 07:39 AM
Florida, Cape Coral
Eddie Offline
Eddie  Offline
Florida, Cape Coral
Max engine RPM is required for engine cooling according to my John Deere.
CX5 Touring 2.5L :-)
Re: How Fast to Run a ZeroTurn Mower [Re: Gebo] #4792884
06/21/18 07:44 AM
06/21/18 07:44 AM
Columbus Nebraska
old1 Offline
old1  Offline
Columbus Nebraska
As others have said, you control your ground speed with the transmission, not the engine rpm. Practice, practice, practice.
2017 Nissan Frontier 4.0 5w30
1965 Mustang 200 c/4 10w30 QS defy
1964 Ford Ranchero 302 c/4 15/40 Delo
1929 ford model A No filters, and 15/40 oil
Re: How Fast to Run a ZeroTurn Mower [Re: Gebo] #4792900
06/21/18 07:58 AM
06/21/18 07:58 AM
Tri State Conservative
Zee09 Offline
Zee09  Offline
Most repeat full throttle as most ZT makers suggest that.
Mine says a minimum of 3000 rpm- I found about 3150 rpm the sweet spot for great cutting and maximum fuel efficiency.
That comes in handy when your lawn is literally a country mile.
I do have a built in tach and it makes it easy to remember your calculated "sweet spots" when you move over to other areas.
In the end you will know after you get used to it. Same with actual speed- your terrain dictates that.
"If I walked on water, they'd say I couldn't swim."
Re: How Fast to Run a ZeroTurn Mower [Re: Gebo] #4792939
06/21/18 08:27 AM
06/21/18 08:27 AM
Buffalo, NY
JTK Offline
JTK  Offline
Buffalo, NY
Gebo, when I had my Cub Z-Force ZTR, it felt the same way at full throttle. The drives put out max torque at max engine RPM, so ground speed and direction changes will be more herky-jerky unless you use a softer touch.
I get it that the manufacturers recommend full throttle for "proper engine cooling", but you don't need to run them at full throttle. You'll burn less fuel throttled down a bit and IMO, it's easier on the equipment and you throttled down some.
Re: How Fast to Run a ZeroTurn Mower [Re: Gebo] #4793009
06/21/18 09:36 AM
06/21/18 09:36 AM
VA
Gebo Offline OP
Gebo  Offline OP
VA
I'm leaning towards JTK. One thing I have noticed is that it still creeps forward in neutral with the bars laid out. I need to do a little research. IT's a Snapper/Simplicity from 2008 I purchased from my neighbor.
Since I'm running all Amsoil, that's all I need for cooling. wink
'98 LEX LS400 290K
'02 4Runner 230K
'05 Lex LS430 85K
'07 Lex GX470 65K
Amsoil in last two.
Re: How Fast to Run a ZeroTurn Mower [Re: Gebo] #4793048
06/21/18 10:05 AM
06/21/18 10:05 AM
Central Wisconsin
dwendt44 Offline
dwendt44  Offline
Central Wisconsin
Doesn't the cut look rather ragged when mowed at a
really fast pace? I usually mow at a moderate speed and the
'cut' looks pretty good after.
My 2
There's no such thing as:
Too big of a battery,
Too large of a gas tank,
or too loud of a horn,
or too bright headlights.
Moderated by  ekpolk
