Rotary mower cutting performance has a high correlation to the blade tip speed. For safety reasons, the maximum blade tip speed is mandated by law. OSHA regulations require that a lawnmower blade has a maximum blade tip speed of 19,000 ft/min. The shorter the blade is, the higher the RPMs that it turns. Maximum blade tip speed is regulated by the engine's governor setting at full throttle. Lowering the throttle setting reduces the blade tip speed and cutting performance, so for the best cutting performance a rotary mower should always be run at full throttle.
Most ZTR riders have adjustments that allow you to limit the ground speed when the control levers are moved to their limits. Some ZTRs also have an adjustment that reduces the sensitivity so that it is easier to control.
