I have the green caps on my tires that I fill with air. I want people to think I gullible and then: BLAMO
Air from a compressor seems to absorb a lot of moisture when the temperature increases. Filling one hundred tires in a tire shop daily, perhaps. Their plumbing system might help cool it down a bit. The only time I have seen considerable moisture at home is while sand blasting. Moisture while just topping off is probably minimal.
