Mitsubishi Mirage for Basic Transportation
by parimento1 - 04/02/20 12:54 AM
Amsoil EaOM103
by Lufty - 04/02/20 12:46 AM
Wheel bearing grease discussion
by Zahndkile - 04/01/20 11:10 PM
Low mileage Hundai Kona 5w-20 or 5w-30?
by j_mac - 04/01/20 10:43 PM
Napa platinum and Napa oil
by NavyVet88 - 04/01/20 10:29 PM
5.0 oil leak f150
by oilstudent24 - 04/01/20 09:17 PM
Dodge Durango 3.6L - HPL 5w-20 - 5,000 Miles on oil
by wwillson - 04/01/20 09:14 PM
Does a cold engine make more power?
by Avery4 - 04/01/20 08:48 PM
Facebook Marketplace riddled with scam RV ads
by atikovi - 04/01/20 08:14 PM
2017 Corvette / 14.4k / ACDelco MTF
by dparm - 04/01/20 08:10 PM
Replacing Rusty Brake Lines
by 92saturnsl2 - 04/01/20 08:08 PM
2017 Corvette / 14.4k / ACDelco 75w90 gear oil
by dparm - 04/01/20 07:59 PM
Pennzoil Ultra Additive Fallout in Sump
by 5AcresAndAFool - 04/01/20 07:50 PM
2008 BMW M3, BMW TwinPower Turbo 10W-60, 4915 mi
by d00df00d - 04/01/20 07:41 PM
2017 Corvette / Mobil 1 ESP 0w40 / 7.1k miles
by dparm - 04/01/20 07:40 PM
Just when you think it can't get any worse
by Chris142 - 04/01/20 07:40 PM
VIRGIN NAPA PRO SELECT 21334
by 53' Stude - 04/01/20 07:18 PM
M1 5W30 EP Users ?
by ChrisD46 - 04/01/20 07:15 PM
VIRGIN MO-899 CUT OPEN
by 53' Stude - 04/01/20 07:06 PM
When to replace a battery?
by Chris142 - 04/01/20 06:49 PM
Code, Adam1, ripcord, KenoshaWizard, junipertoxic
71074 Registered Users
39 registered members (bbhero, clinebarger, carlprop, blufeb95, azianbob, Bill_W, 2 invisible), 911 guests, and 22 spiders.
Topics303,467
Posts5,235,671
Members71,074
Intake Resonator delete #4780459 06/07/18 06:45 PM
Marco620 Offline OP
15' Civic 1.8 i-vtec 319,500 mi M1 0w30 & LG Biotech,Castrol CVT Fluid,GUMOUT/ PEA
Doberman Whisperer! HondaGuru.
E pluribus unum.
Re: Intake Resonator delete [Re: Marco620] #4780478 06/07/18 07:00 PM
Marco620 Offline OP
Sounds ultra loud now. Seems to run a hint cooler on freeway too. Butt dyno says 1 hp max... But boy is she louder now.
E pluribus unum.
Re: Intake Resonator delete [Re: Marco620] #4780484 06/07/18 07:07 PM
E
eljefino Offline
E
I've overwhelmed by all the absence.
Re: Intake Resonator delete [Re: Marco620] #4780528 06/07/18 07:40 PM
gathermewool Offline
Nope.
14 Forester XT Touring FA20DIT (Cobb Stage 1)
Castrol Magnatec 5W-30 D1G2 + FU filter (2nd OFI) (77,760mi, 3/7/20)
15 Legacy Premium FB25
Magnatec 0W-20 D1G2+ FU filter (2nd OFI) (54,621mi, 3/4/20)
Re: Intake Resonator delete [Re: Marco620] #4780543 06/07/18 07:47 PM
2
2strokeNorthstar Offline
2
Nice. I got 2psi more boost deleting the factory stuff on a 2013 juke nismo. Intake and inter cooler pipes. Some noise is fine.
2001 F150 5.4L
2013 Nissan Juke Nismo
2000 Honda S2000
1998 BMW 328i
Re: Intake Resonator delete [Re: Marco620] #4780612 06/07/18 08:42 PM
9
901Memphis Offline
9
I have no idea what I'm looking at
2012 Chevy Cruze LT 1.4T - 69k - M1HM 5w30 + Fram Ultra
2002 Buick Century 147k - Built 4T65e(Maxlife) - GTX 5w30 + Fram XG3980
Re: Intake Resonator delete [Re: Marco620] #4780637 06/07/18 09:02 PM
A
andyd Offline
A
And you have company. I liked the way the stock system sounded on the 528e. My '88s had 44mm pipes exiting the cat, with a resonator ahead of the muffler.and out. Mellow and not fatiguing on highway. Guys, I'm looking at 6K$ worth of hearing aid so I can hear my grandsons speak. To many DBs for too long and the ears wear out.
Thick oil is better grin2
Re: Intake Resonator delete [Re: Marco620] #4780846 06/08/18 02:20 AM
Nick1994 Offline
Looks like a radiator hose to me...
I deleted the resonator on my Camry too. Not for performance, but because the replacement was expensive because the hose broke. $3 of Home Depot PVC fixed that issue crackmeup
Here's the link to that butcher job:
https://www.bobistheoilguy.com/forums/ub...ato#Post4049903
2015 Hyundai Genesis 5.0L 58k Mobil 1 5w30 & Wix
2000 Toyota Camry 2.2L 238k Mobil Super HM 10w40 & Fram Ultra
1996 Jeep Cherokee 4.0L 150k Mobil 1 HM 10w40 & Fram Ultra
Re: Intake Resonator delete [Re: 2strokeNorthstar] #4781694 06/08/18 08:30 PM
That means you’re likely over-boosting. Changing parts on a (modern) turbo vehicle-without a tune is foolish. There are no ifs ands of buts about it. You may have “gained” boost, but your ECU may be pulling timing or trying to compensate for the changed intake and wrong MAF sensor reading via massive adjustments to fuel trim.
Re: Intake Resonator delete [Re: Marco620] #4781889 06/09/18 04:33 AM
N
NGRhodes Offline
N
Intake resonators are not just for sound reduction but allowing a reserve of air to help flow during the pumping pulses.
You won't automatically gain power from removal and probable that you will reduce power.
I do know some car do get gains from a shorted cold air intake and turbos add another dimension.
This link below is a good read.
http://planetsoarer.com/resonator/resonator.html
