I jumped on the Rotella bandwagon and put some of it in my 2006 GSXR 600, but ever since then I have had a lot of trouble getting from 1st to 2nd (stuck in neutral... rev up, look like a noob), and a lot of issues with upshifting and finding that the gear did not change (shift, get on throttle only to realize that it's still in the same gear). I also notice that my engine runs a lot hotter (10-20 degrees consistently). I have found that I need to go much faster to get the temp gauge to go below 200, when before I could get to 190 by just getting a little airflow in there. I am disappointed in this oil and will be switching back to something more motorcycle specific. That being said, I did buy the oil on Scamazon, so maybe I got something counterfeit.
Either way, I was looking at probably going back to Valvoline dino motorcycle oil, or maybe trying Castrol Actevo semi-synthetic next. I was certainly surprised by the lackluster performance of the Rotella. I also used an OEM oil filter, same as the previous oil, which was Valvoline motorcycle oil.
