2021 Acura TLX Sports
by buster - 05/28/20 01:36 PM
Honda GC vs GS engines?
by Avery4 - 05/28/20 01:10 PM
Advanced auto parts
by Fitter30 - 05/28/20 12:52 PM
Is there a best time to switch to synthetic oil?
by Jgelack - 05/28/20 12:37 PM
Alignment good then bad
by Barkleymut - 05/28/20 11:56 AM
What's in the Box?
by BeerCan - 05/28/20 11:31 AM
High Gloss product for Silver car?
by tc1446 - 05/28/20 11:15 AM
Home HVAC advice?
by Ed_Flecko - 05/28/20 10:43 AM
Briggs decompression.
by BSeward - 05/28/20 10:34 AM
1970 Cub Cadet Model 73 with Cizek Mower
by Phishin - 05/28/20 10:19 AM
Need Jacks-Returned recalled HF last week.
by 1978elcamino - 05/28/20 10:01 AM
WSS-M2C200-D vs -D2 vs D3
by mossietheno1 - 05/28/20 09:41 AM
Three things you never sell...
by DriveHard - 05/28/20 09:34 AM
Motorex Supergliss 100K
by Taildragger - 05/28/20 07:30 AM
Dewalt titanium drill bit set
by Donald - 05/28/20 07:29 AM
Spark Plugs - 6.2L GM
by jdw1222 - 05/28/20 07:16 AM
seat belt retracts slowly
by NH73 - 05/28/20 05:19 AM
Bent Jack Stand Ratchet Bar
by The Critic - 05/28/20 01:44 AM
Can a 2005 Volvo go 300K Miles easily?
by VolvoZ - 05/27/20 11:17 PM
lr08, BlackMagicVarian, Mustache, mountaingoat, Alegrianyc
71546 Registered Users
107 registered members (69GTX, 97f150, 1978elcamino, Alfred_B, aquariuscsm, 14Accent, 9 invisible), 2,412 guests, and 27 spiders.
Topics305,978
Posts5,284,036
Members71,546
How much refrigerant is in a can? #4771400 05/29/18 05:07 PM
J
joegreen Offline OP
J
So i am in the process of buying refrigerant to fill my vehicle. It seems like an easy enough question but i couldnt find any info online. Lets say i have a can of r134a and it says net weight 12oz. Does that mean the can contains 12oz of refrigerant or does the can and refrigerant weight 12oz? Im just trying to figure out how many cans of r134a i need.
1978 Chevrolet k20
Engine: Delo 10w30xle
Transmission: Castrol transmax dex/merc
1984 Mercedes-Benz 300 turbo diesel
Engine: Delo 400 15w40le
Re: How much refrigerant is in a can? [Re: joegreen] #4771401 05/29/18 05:09 PM
K
kschachn Offline
K
http://www.businessdictionary.com/definition/net-weight.html
1994 BMW 530i, 252K
1996 Honda Accord, 288K
1999 Toyota Sienna, 434K
2000 Toyota ECHO, 284K
Re: How much refrigerant is in a can? [Re: joegreen] #4771414 05/29/18 05:22 PM
M
mrsilv04 Offline
M
You have to read the can. Some will have a small amount of oil in them as well.
I have a 12 ounce can in the garage, which is labelled as containing 11.3 ounces of R-134a, and .7 ounces of refrigerant oil.
2004 Silverado - on its 3rd Jasper engine in less than one year.
Re: How much refrigerant is in a can? [Re: joegreen] #4771415 05/29/18 05:23 PM
rollinpete Offline
Usually under the hood some where, it will tell you how much you need, for your system.
Got to go from there.
Pete.
97 Ford Expl.Sport 4.0 ohv 4wd 5spd 190k
SRGT 5w30
Whip City Wrencher
Currently under the influence of oil shocked2
Re: How much refrigerant is in a can? [Re: joegreen] #4771428 05/29/18 05:42 PM
slacktide_bitog Offline
"net weight" is the weight of just the contents inside the can smile
"tare weight" is the weight of the container itself, and "gross weight" is the "net"and "tare" weights
Re: How much refrigerant is in a can? [Re: rollinpete] #4771589 05/29/18 08:00 PM
J
joegreen Offline OP
J
I need 1lb 14oz. Im just trying to figure out how many cans i need to buy is all
1978 Chevrolet k20
Re: How much refrigerant is in a can? [Re: kschachn] #4771591 05/29/18 08:02 PM
J
joegreen Offline OP
J
Thanks i understand now
1978 Chevrolet k20
Re: How much refrigerant is in a can? [Re: slacktide_bitog] #4771593 05/29/18 08:02 PM
J
joegreen Offline OP
J
Thanks
1978 Chevrolet k20
Re: How much refrigerant is in a can? [Re: joegreen] #4771594 05/29/18 08:02 PM
J
joegreen Offline OP
J
Looks like ill get 3 cans and put 2.5 cans in.
1978 Chevrolet k20
Re: How much refrigerant is in a can? [Re: joegreen] #4771650 05/29/18 08:39 PM
T
tomcat27 Offline
T
Is your system totally empty and do you have a vacuum pump?
2019 Cherokee, 2018 Jetta, 2014 Sentra, 2001 Camry, 1995 Escort, 1970 Cougar, 2013 XT250, 2010 Vstar, 2014 CTX1300
Re: How much refrigerant is in a can? [Re: joegreen] #4771752 05/29/18 10:09 PM
L
Linctex Offline
L
There's usually enough reserve in the accumulator to handle that last 1/2 a can
Re: How much refrigerant is in a can? [Re: joegreen] #4771754 05/29/18 10:12 PM
spasm3 Online Happy
Online Happy
It seems to me that the old r12 system worked well even when undercharged or overcharged a bit. It seems to me that with the r134a systems , there is a fine line between undercharged and overcharged.
13 elantra 84k 5w30 synpwr
17 mazda cx-5 19000 miles m1 0w30
Re: How much refrigerant is in a can? [Re: tomcat27] #4778394 06/05/18 05:28 PM
J
joegreen Offline OP
J
Yes the system is totally empty. I have a gauge set and a vacuum pump. Anyway the a/c is all repaired now. thanks
1978 Chevrolet k20
Re: How much refrigerant is in a can? [Re: spasm3] #4778446 06/05/18 06:29 PM
N
nthach Offline
N
Depends on the system as well, new AC systems are very sensitive to oil and refrigerant charge. That old GM accumulator and orifice tube system can tolerate some overcharge.
If you charged in with all 3 cans, I don't think an extra 5 oz of R-134a will hurt anything. You lost some while changing out cans, purging the charging hose and gauges.
