Brake Caliper Dampers?
by HangFire. 01/18/19 11:32 AM
Fully Formulated Coolant and old radiator
by Wheel. 01/18/19 11:27 AM
'15 6.7 Powerstroke UOA
by roadrunner1. 01/18/19 10:18 AM
Automotive Battery Voltage -What is ur reading?
by Patrick0525. 01/18/19 10:10 AM
Amsoil 0w-40 vs 5w-40
by Buddyp. 01/18/19 10:07 AM
M1 is changing their oils, site and adding a new oil
by Flashlightboy. 01/18/19 10:01 AM
Boiler/baseboard valve corrosion
by wormwood1978. 01/18/19 09:24 AM
Battery mfg date
by Donald. 01/18/19 08:14 AM
dexos1 Gen 2 License D10386HG025
by Virtus_Probi. 01/18/19 07:43 AM
KARMA
by Sayjac. 01/18/19 07:42 AM
Using a school bus as a camper?
by Kurtatron. 01/18/19 07:04 AM
Formula Shell Synthetic
by mmmmoil. 01/18/19 07:03 AM
free credit report
by bradepb. 01/18/19 06:25 AM
Elon Musk is running out of rich people...
by philipp10. 01/18/19 05:56 AM
Best/Cheapest UOA?
by Hemispheres. 01/18/19 05:02 AM
Hyundai/KIA Theta II multiple call campaigns
by wemay. 01/18/19 04:58 AM
How we do it in wichita! Go Shockers
by Marco620. 01/18/19 02:14 AM
Can 0w20 handle high RPMs
by Doublehaul. 01/18/19 01:16 AM
Dodge Grand Caravan OEM Floor Mats
by raburn2906. 01/17/19 11:52 PM
Mobil 1 0w30
by Doublehaul. 01/17/19 11:11 PM
Buddyp, RyanWu, Batteryspecialis, BamaDawg, JRBilt
66969 Registered Users
100 registered members (aquariuscsm, 2019StingrayZ51, andyd, badtlc, Best F100, 15 invisible), 2,197 guests, and 43 spiders.
Topics296,781
Posts4,958,806
Members66,969
Most Online2,577
Jan 14th, 2019
14 Subaru Forester 2.5L #4757094
05/14/18 02:53 PM
05/14/18 02:53 PM
TN
TTK Offline OP
TTK  Offline OP
TN
I had a 2014 Subaru Forester 2.5L CVT that I let my son-in-law have when he totaled his Honda Pilot. I drove it from new to about 45K and it never used any measurable oil in 7500 OCI, using M1 0w-20, or Castrol 0w-20 Synthetic. After having his local Subaru dealer change the oil, invoice says they used Mobil 0w-20, it seems to use some oil, especially on extended drives on the Interstate. Doesn't seem to use any with local driving. Recently I did an oil and filter change on the 14 Forester and used Valvoline full synthetic maxlife 0w-20 and he checked the oil weekly for several weeks and no usage. Then he took a trip on the Interstate for about 500 miles round trip, and when he returned the oil level was down about 1/4 quart below the full mark( based on his measurements). I had set it about 1/4 quart above the full mark when I changed it. The 14 Forester now has about 65K on it.
So, I recently found a UK 2017 FB-2.5L Forester owners manual, and it indicates that it comes from the factory with 0w-20 Synthetic oil, but 5w-30 or 5w-40 can be used, not just to top off, but as a regular replacement oil. No such statement in the US manual for this vehicle(CAFE?), but I am very tempted to switch to a 5w-30 next oil change, or maybe mobil 1 0w-40. Under high-speed driving does it seem reasonable to believe that either of these oils might help reduce oil consumption under these conditions?
2010 Volvo V70-3.2
Current Fill:Castrol Magnatec 5w-30
2018 Subaru Forester, 0w-20 Subaru oil
2001 Chevrolet Prism:Castrol Magnatec 5w-30
Re: 14 Subaru Forester 2.5L [Re: TTK] #4757111
05/14/18 03:29 PM
05/14/18 03:29 PM
VW Fanboy Island
maxdustington Offline
VW Fanboy Island
Use the same oil for a true verdict, inspect the PCV. Maybe he beats on it like crazy and tells you otherwise? Free car, why not?
You can use whatever weight you want in TN. Perhaps try a HM oil? There are many variables.
03 Jetta AWP/09A 205k kms
Edge 0W40 + Mann 719/30
Re: 14 Subaru Forester 2.5L [Re: TTK] #4757127
05/14/18 04:01 PM
05/14/18 04:01 PM
Buffalo, NY
JTK Offline
JTK  Offline
Buffalo, NY
I ran 5w30 at times in my 2014 XV Crosstrek 5spd that called for 0w20 in the OM. I didn't notice any change with performance, fuel economy or NVH. Mine would consume oil sporadically, 20wt or 30wt. I never tried a 40wt in it.
My 2012 Legacy EJ253 used no noticeable amount between OCIs (specd 5w30), nor did my Forester FB25 (0w20). I did run 5w20 quite a bit in my Forester when I couldn't find 0w20 on sale.
2017 Ram 1500 4x4, 3.6L. 2016 Nissan Quest SV (Babe magnet IV)
Re: 14 Subaru Forester 2.5L [Re: maxdustington] #4757133
05/14/18 04:09 PM
05/14/18 04:09 PM
TN
TTK Offline OP
TTK  Offline OP
TN
The Valvoline 0w-20 was a high mileage full synthetic. I did pick up a new PCV for the vehicle but have not installed it just because I have not had access to the vehicle since I changed the oil.
2010 Volvo V70-3.2
Re: 14 Subaru Forester 2.5L [Re: TTK] #4757202
05/14/18 05:12 PM
05/14/18 05:12 PM
pa
benjy Offline
benjy  Offline
pa
first off we all know the CAFE rules in the USA no matter the wear or whatever!! in the heat of tenn a 10w or even a 15W would be a good choice! i surely would not be concerned with minimal consumption though. some Subies suck oil, low tension oil rings + anything to get better CAFE is in the mix. be sure to attend to that CVT as they can be problematic at best as the miles add up. after dumping the OE oil in girlfriends 13 malibu 2.5 LS @ a thou + down a qt i put in spec dexos 5-20, 3 thou later + looking for its 3rd qt i dumped it + put in a fake synthetic 10-30 + her usage is minimal between yearly changes less than 10 thou + a fresh filter at 6 months.
Re: 14 Subaru Forester 2.5L [Re: benjy] #4757212
05/14/18 05:21 PM
05/14/18 05:21 PM
TN
TTK Offline OP
TTK  Offline OP
TN
Thanks for the suggestions. Actually, the car is now in central Virginia, but the weather is not much different temp wise. We will have to watch it further to determine the actual extent of the consumption, and the effects of different oils on it. But, I think you are correct, even a 10w-30 would be okay, and probably with lower NOACK.
2010 Volvo V70-3.2
Re: 14 Subaru Forester 2.5L [Re: TTK] #4757475
05/14/18 10:07 PM
05/14/18 10:07 PM
Central Coast California
RedOakRanch Offline
RedOakRanch  Offline
I would think the new driver is the reason not the oil. My wife's 2016 Outback burned oil once, we were driving at 85-90mph for 3 hours straight. At 75 and under it burns nothing in 6k miles.
1994 Ford Crown Vic 207k-Frankenbrew 0w20,30,40!
2005 Chevy 1500 Crewcab 4X4 180k-BC 0w30 $2/qt
2016 Outback 2.5 Limited 60k-shop brand?
Re: 14 Subaru Forester 2.5L [Re: TTK] #4757801
05/15/18 09:47 AM
05/15/18 09:47 AM
PA
ridgerunner Offline
ridgerunner  Offline
PA
I am using Amsoils SS 0-20 in my 2013 subi. It has a NOACK of 8.5. Amsoils 5-20 has a NOACK of 5.8. Big difference in NOACK.
Re: 14 Subaru Forester 2.5L [Re: RedOakRanch] #4757812
05/15/18 09:53 AM
05/15/18 09:53 AM
PimTac Offline
PimTac  Offline
This. I can think of a number of examples where a vehicle that had a different driver developed issues. My theory all along was that the newer driver drive the car harder and thus exacerbated any issues that were lurking.
Cannot see signatures any longer so it doesn’t matter.
Re: 14 Subaru Forester 2.5L [Re: PimTac] #4757840
05/15/18 10:29 AM
05/15/18 10:29 AM
TN
TTK Offline OP
TTK  Offline OP
TN
I would say, yes, he probably drives the vehicle more spirited than I did.
2010 Volvo V70-3.2
Re: 14 Subaru Forester 2.5L [Re: TTK] #4757993
05/15/18 02:05 PM
05/15/18 02:05 PM
NJ
bluesubie Offline
bluesubie  Offline
NJ
It feels like deja vu all over again. grin2
In addition to what I said on the Forester forum, just to add that even though 0W-20 is the recommended choice in N. America the 2014 owner's manual does require thick grades in high temps.
From page 11-11:
Quote:
NOTE
Engine oil viscosity (thickness) affects fuel economy. Oils of lower viscosity provide better fuel economy. However, in hot weather, oil of higher viscosity is required to properly lubricate the engine.
https://stis.subaru.com/proxy/160663/pdf/ownerManual/160663_2014_Forester/MSA5M1403DSTIS_12.pdf
Unless you have an extended warranty, I'd be tempted to try a High Mileage 10W30. Maybe an HM 5W-20 but even an HM 10W-30 would probably work well for consumption. Basically, feel free to experiment IMO!
edit: Looks like 5W-30 can be used in anything in Japan. They do allow 5W-40 in the BRZ (which specs 20 grade here) but I only see the 5W-30 listed for all cars.
https://www.subaru.jp/accessory/engine_oil/lineup/standard03.html
'04 Subaru Forester 2.5XT
Castrol Edge High Mileage
