Royal purple discontinuing 30-1218 ?
by jmj540. 03/19/19 10:02 PM
Nissen Radiator Review
by zmelli. 03/19/19 09:01 PM
March madness
by gman2304. 03/19/19 08:36 PM
Shell Rotella T6 5W-30 Multi
by kstanf150. 03/19/19 08:21 PM
New Toyota Tacoma oil recommentation
by Moondawg. 03/19/19 08:11 PM
Which oil for modified turbo engine?
by headoff93. 03/19/19 08:02 PM
Problems After Adding 2 Stroke To Diesel
by InfernoRedBeast. 03/19/19 07:47 PM
Amsoil filter
by Bill_W. 03/19/19 07:01 PM
My $1 ocod 4k
by Pinoak. 03/19/19 06:58 PM
GMC tailgate latch repair question
by aquariuscsm. 03/19/19 06:49 PM
Can I Use Maple Syrup Instead Of Oil ?
by Warstud. 03/19/19 06:09 PM
Should criminals be given a second chance?
by ZZman. 03/19/19 04:28 PM
Oil recommendations for old car
by chromedome. 03/19/19 04:06 PM
Reply Box Window
by das_peikko. 03/19/19 03:45 PM
New plants around the yard
by gregk24. 03/19/19 03:24 PM
New Nissan Titan XD w/5.6l oil choices
by josephp732. 03/19/19 03:20 PM
Gran Prix Tour RS tires
by HangFire. 03/19/19 01:50 PM
mm2020, emepher, headoff93, yahtzee, jmd
67560 Registered Users
90 registered members (2015_PSD, aaronc7, 01rangerxl, 69GTX, ABCarr, 7 invisible), 1,517 guests, and 58 spiders.
Topics286,092
Posts4,902,408
Members67,560
Most Online2,967
Mar 10th, 2019
'09 Honda Civic 103K AT fluid spill & fill #4742849
04/29/18 09:46 PM
04/29/18 09:46 PM
Connecticut, USA
bmwpowere36m3 Offline OP
Connecticut, USA
2009 Honda Civic, 103K miles, original fluid, no abnormal AT behavior
Drained ~3qts and replaced with VM Maxlife ATF. I'll repeat a couple more times. Drain plug debris was wiped on blue rag.
Re: '09 Honda Civic 103K AT fluid spill & fill [Re: bmwpowere36m3] #4743118
04/30/18 08:53 AM
04/30/18 08:53 AM
Oklahoma
Schmoe Offline
Schmoe  Offline
Oklahoma
Wow...blot test doesn't look that bad. One thing I've noticed with the Honda ATF is that it has a smell like no other ATF. Must be the magic juice.....
01 Supercrew Lariat 4X4
06 Accord EX-L V6
14 CRV EX-L (RIP) 2018 CRV EX-L
Re: '09 Honda Civic 103K AT fluid spill & fill [Re: bmwpowere36m3] #4743186
04/30/18 09:38 AM
04/30/18 09:38 AM
New York
NoNameJoe Offline
NoNameJoe  Offline
New York
103K and changing the fluid for the first time? shocked2 I would be too nervous.
Yup, I love the smell. I've used other ATF's like Dex/Merc and they smell so [censored] bad. Castrol Import ATF smells like fish, Valvoline MaxLife ATF smells like [censored].
I used those on Nissan cars. For Honda I only use Honda fluids.
2015 Civic LX Coupe
Re: '09 Honda Civic 103K AT fluid spill & fill [Re: NoNameJoe] #4743478
04/30/18 02:20 PM
04/30/18 02:20 PM
DFW
JustN89 Offline
JustN89  Offline
DFW
Got some Maxlife on my favorite hat last time I serviced the transmission on the Impala. I got the stain out but the smell seemingly won't every go away. frown
Re: '09 Honda Civic 103K AT fluid spill & fill [Re: bmwpowere36m3] #4752459
05/09/18 10:17 PM
05/09/18 10:17 PM
texas
joel95ex Offline
joel95ex  Offline
texas
my automatic accord trans went over 500k miles..... and honda AT's have a rep for being the weak link. i always did a drain/refill every 30k. i recommend not letting it go 100k again if you plan on keeping it
95 Accord 4cyl Vtec. 500,000+miles. RIP 😢
2013 sonata 117k miles
PP, QSUD,10w-30 fram ultra filter
07 civic SI 132k miles PP, M1 10w-30 fram ultra
Re: '09 Honda Civic 103K AT fluid spill & fill [Re: bmwpowere36m3] #4754143
05/11/18 11:50 AM
05/11/18 11:50 AM
Oakville, Ontario
Patman Offline
Global Moderator
Patman  Offline
Global Moderator
Oakville, Ontario
I love how easy the trans fluid change is on an 8th gen Civic! I always do a drain and fill, drive a few miles, and then do another drain and fill, since each time you drain it only 50% of the old fluid will come out. But if you do the double drain and fill about every 30-50k that should be good enough. I always use the OEM fluid from the Honda dealer.
2018 Corvette, 9k, M1 ESP Formula 5w30 & NAPA Gold
2006 Civic EX Coupe, 149k, PUP 5w20 & Fram Ultra
2010 BMW 328i X-Drive,113k, GC 0w40 & Fram Ultra
Re: '09 Honda Civic 103K AT fluid spill & fill [Re: Patman] #4754256
05/11/18 02:13 PM
05/11/18 02:13 PM
New York
NoNameJoe Offline
NoNameJoe  Offline
New York
sick
Yup, you don't have to go search for a socket either since the plug is just a 3/8 drive. The one thing I think would have made it even better is if the drain plug were right on the bottom facing down.
2015 Civic LX Coupe
Re: '09 Honda Civic 103K AT fluid spill & fill [Re: bmwpowere36m3] #4757882
05/15/18 12:23 PM
05/15/18 12:23 PM
Connecticut, USA
Connecticut, USA
Did another spill & fill after about a week of driving. The fluid looked about the same as the first time and a little bit on the magnet.
Re: '09 Honda Civic 103K AT fluid spill & fill [Re: bmwpowere36m3] #4758753
05/16/18 12:23 PM
05/16/18 12:23 PM
Storrs, Connecticut
jeepman3071 Online content
jeepman3071  Online Content
Storrs, Connecticut
Should be fine. My friend's mom has a 2006 Civic with 220k+ on it. It had one drain and fill at the dealer when it had 150k miles, and she wanted me to change it at 200k. I did 3 drain and fills until the fluid came out pink (using only Honda fluid) and the transmission has shifted perfect since.
2000 Jeep Cherokee 4.0L (181k) - Pennzoil 10w30, Napa Gold 1516, Magnefine trans filter
2009 BMW 328i (38k) - Castrol Edge Euro 0w40, MANN HU816X
Re: '09 Honda Civic 103K AT fluid spill & fill [Re: bmwpowere36m3] #4758875
05/16/18 02:37 PM
05/16/18 02:37 PM
Los Gatos, CA
JeffKeryk Offline
JeffKeryk  Offline
Los Gatos, CA
Our old 95 Accord became a gift to a friend. He totaled it with almost 300K; it was running fine.
Trans saw lotsa Honda fluid , some regular Dextron and lotsa MaxLife.
Never a problem.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: '09 Honda Civic 103K AT fluid spill & fill [Re: bmwpowere36m3] #4758917
05/16/18 03:40 PM
05/16/18 03:40 PM
st louis, mo
brages Online content
brages  Online Content
st louis, mo
what can BROWN do for you?
Re: '09 Honda Civic 103K AT fluid spill & fill [Re: bmwpowere36m3] #4789874
06/18/18 10:07 AM
06/18/18 10:07 AM
Connecticut, USA
Connecticut, USA
Did another this past weekend
Re: '09 Honda Civic 103K AT fluid spill & fill [Re: bmwpowere36m3] #4789902
06/18/18 10:26 AM
06/18/18 10:26 AM
The Northeast
mclasser Offline
mclasser  Offline
The Northeast
Mmmm looks like Naked Juice.
2018 Hyundai Elantra VE
2013 Honda Pilot EX-L 4WD
2002 Honda Accord EX-L
