(NEW) STP S3675 Cut Open
by rooflessVW. 01/17/19 10:00 PM
Anti-Counterfeiting packaging
by sloinker. 01/17/19 09:13 PM
Heavy Snow Predicted for Northeast Sat/Sun
by Donald. 01/17/19 08:34 PM
Pennzoil Ultra Plat 5w30 1.4L T Chevy Cruze 10k
by SubieBlue. 01/17/19 08:03 PM
Coated rotors
by supton. 01/17/19 07:51 PM
Good samaritan
by JLTD. 01/17/19 07:15 PM
Doing suspension work. Need alignment?
by HawkeyeScott. 01/17/19 05:45 PM
100mg CBD Cannabis Gel
by Al. 01/17/19 05:36 PM
Electric Car "Green Test"
by redbone3. 01/17/19 05:06 PM
Want to try a uoa
by Dylan1303. 01/17/19 04:56 PM
Happy Birthday, Betty White!
by eljefino. 01/17/19 04:20 PM
Fram Ultra for Ecoboost 2.7
by Purpfox. 01/17/19 04:10 PM
Idle Speed / 1998 Olds 88
by Mark72. 01/17/19 03:28 PM
Heat blanket for your oil filter!
by MrWideTires. 01/17/19 03:24 PM
Proper oil viscosities.
by Bullwinkle007. 01/17/19 03:20 PM
44$ for 5 gals of home heating oil treatment!
by Audios. 01/17/19 03:05 PM
Good job Hyundai!!!
by Andy636. 01/17/19 02:43 PM
Dickerson888, Frisky, polarisman340, jfradella, Bigyetti83
66964 Registered Users
87 registered members (advocate, 14Accent, 2015_PSD, Astro14, ArrestMeRedZ, AdditiveOCD, 8 invisible), 1,589 guests, and 34 spiders.
Topics296,757
Posts4,958,275
Members66,964
Most Online2,577
Jan 14th, 2019
BMW S54, 125,xxx, UOA report, Oil unknown #4715590
04/03/18 08:21 PM
04/03/18 08:21 PM
AZ
Exclusivs Offline OP
AZ
Background :
BMW S54 Engine : 125,xxx mi
Oil sampled immediately
Unknown brand, interval, or additives added
Silicon : I can attest from a later disgustingly filthy air filter
Re: BMW S54, 125,xxx, UOA report, Oil unknown [Re: Exclusivs] #4715592
04/03/18 08:23 PM
04/03/18 08:23 PM
PimTac Offline
PimTac  Offline
It would have been interesting to see the TBN/TAN done on that sample.
Cannot see signatures any longer so it doesn’t matter.
Re: BMW S54, 125,xxx, UOA report, Oil unknown [Re: Exclusivs] #4715606
04/03/18 08:45 PM
04/03/18 08:45 PM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
Iron,copper and lead all high. Maybe a very long OCI?
If you want the job done right......do it yourself.
Re: BMW S54, 125,xxx, UOA report, Oil unknown [Re: Snagglefoot] #4715608
04/03/18 08:52 PM
04/03/18 08:52 PM
AZ
AZ
I can certainly request from Blackstone - as from what I was reading they hold sample for a bit?
Certainly would not doubt it. Air filter had a 2013' date on it when I removed
Re: BMW S54, 125,xxx, UOA report, Oil unknown [Re: Exclusivs] #4715618
04/03/18 09:09 PM
04/03/18 09:09 PM
Minneapolis
antonmnster Offline
antonmnster  Offline
Minneapolis
Time for rod bearings. Sorry.
Re: BMW S54, 125,xxx, UOA report, Oil unknown [Re: Exclusivs] #4715674
04/03/18 10:33 PM
04/03/18 10:33 PM
West Ma.
rollinpete Offline
rollinpete  Offline
West Ma.
That's some thick oil there..lot of metal there outch..
Pete.
97 Ford Expl.Sport 4.0 ohv 4wd 5spddrive187k miles
03 Saturn Ion 2.2 L4 5spddrive236K miles
PPHM 5w30 x 2 Fram Ultra x 2
Currently under the influence of oil shocked2
Re: BMW S54, 125,xxx, UOA report, Oil unknown [Re: Exclusivs] #4715685
04/03/18 10:55 PM
04/03/18 10:55 PM
AZ
AZ
Undoubtable yes, a high showing of metals - along w/ some other oddities
Goal to post here specifically was for any helpful insight - there is a wealth of it on this site which I respect greatly
Blackstone sure provides some feedback - but as many will attest isn't most insightful
Re: BMW S54, 125,xxx, UOA report, Oil unknown [Re: Exclusivs] #4715723
04/04/18 01:27 AM
04/04/18 01:27 AM
TN USA
Crispysea Offline
Crispysea  Offline
TN USA
That engine was rode hard and put away wet! I’d trade it in before something breaks...
Re: BMW S54, 125,xxx, UOA report, Oil unknown [Re: Exclusivs] #4715771
04/04/18 05:22 AM
04/04/18 05:22 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
The rod bearings are probably done. If it were mine I would be dropping the pan to check/replace them before they do damage to the crank.
There are upgraded bearings for this engine.
Re: BMW S54, 125,xxx, UOA report, Oil unknown [Re: Exclusivs] #4715772
04/04/18 05:23 AM
04/04/18 05:23 AM
Atlanta
DuckRyder Offline
DuckRyder  Offline
Atlanta
So, a BMW M Motor. (Is this one of the ones that calls for 10/60?)
What was blackstone feedback? (you can log into your blackstone account, search by unit and then produce a report without personal info)
What is the situation/history with the car? Does it run ok? Make any noise? What (other than the suspect air filter) does a visual inspection reveal.
I think a single UOA in a vacuum tells us little, particularly with so many unknowns. Yes - it doesn’t look good, but as to why it doesn’t look good and what (if any) action is required beyond changing the oil... need to look at the whole body of information.
EDIT: Also “?” by antifreeze. Markers for coolant present. Bearings have been sitting in oil contaminated with coolant? (what did the oil look like?)
Robert
  • 2007 Toyota Prius Touring
  • 2005 Honda Civic Sedan
  • 1972 Ford F100
Re: BMW S54, 125,xxx, UOA report, Oil unknown [Re: Trav] #4715887
04/04/18 07:54 AM
04/04/18 07:54 AM
KY
MCompact Offline
MCompact  Offline
KY
^^^ This. Known issue with the S54.
Mine:
2014 M235i
2009 Cooper Clubman
1999 Wrangler Sahara
1995 318ti Club Sport
Wife's:
2015 X1 xDrive28i M Sport
Son's
2009 328i
Buy what makes you smile...
Re: BMW S54, 125,xxx, UOA report, Oil unknown [Re: MCompact] #4716080
04/04/18 10:19 AM
04/04/18 10:19 AM
AZ
AZ
Yep, has been planned well before receiving this report.
Appreciate detailed response: no alarming engine sounds - only 90mi of light driving on car once new oil was in (10w60) which was immediately. Awaiting the report from Blackstone - obviously did not try to push the engine even on fresh 10w60.
Coolant levels are leveled in expansion tank - and also dash gauge stable. Double checked actual temp via OBD2 (gave indicated dash reading)
Blackstone surprisingly gave very little input hence reason I didn't include. Just stated obvious; high metal. They noted the silicon from dirty air filter after I had told them about the car status.
Not sure how coolant would be @ level / cooling car properly if leak was present & contaminating oil. But just here to learn - and pick the brains of those others who may be of more experience.
