Supertech Heavy Duty 15W40 ...$9.64
by dblshock. 01/22/19 08:53 AM
Trooper recommends dash cameras
by FordBroncoVWJeta. 01/22/19 07:14 AM
New Harley synthetic 80w-140 gear released
by shanneba. 01/22/19 06:43 AM
Registering a Vacation Car
by ssamaroo01. 01/22/19 06:23 AM
Starter cross reference?
by dlundblad. 01/22/19 05:11 AM
Barkeepers Friend
by jerseyguy123. 01/22/19 02:23 AM
Bag-in-a-box motor oils
by jtr990. 01/22/19 02:10 AM
Inventions of the 1950's - 1970's
by StevieC. 01/21/19 10:26 PM
Fireplace cleaners and price
by 97prizm. 01/21/19 10:23 PM
M1 0w40 extended oci??
by Pinoak. 01/21/19 09:46 PM
Best propane fireplace insert?
by SOHCman. 01/21/19 08:51 PM
Save 1/4 on gas!! Guaranteed!!
by Linctex. 01/21/19 08:50 PM
Funny names
by Chris142. 01/21/19 08:45 PM
Kendall vs Total Qaurtz
by zeke1985. 01/21/19 08:32 PM
Got a weird one - Helping a friend
by StevieC. 01/21/19 08:32 PM
Thanks 14Accent
by clinebarger. 01/21/19 08:07 PM
Mobil 1 5W30 C7 Z06
by PLRX. 01/21/19 07:40 PM
How cold is it? (Humor)
by StevieC. 01/21/19 07:13 PM
Binco, Coolbreez1973, jmcast1127, DF8005, FT86dude11
67009 Registered Users
103 registered members (AmoryBlaine, 53' Stude, 4WD, Arctic388, 2015_PSD, 16 invisible), 1,864 guests, and 32 spiders.
Topics296,968
Posts4,962,580
Members67,009
Most Online2,821
Jan 21st, 2019
Oil Overfill #4706092
03/25/18 07:22 AM
03/25/18 07:22 AM
Ajax,Ontario, Canada
Pelican Online content OP
Pelican  Online Content OP
Dealer overfilled my oil, TTL amount as per manual 5.7 litres, dealer put in 6 litres so it's over by 300 ml, do you see any problems with this?
Thanks to all who will reply
Re: Oil Overfill [Re: Pelican] #4706101
03/25/18 07:25 AM
03/25/18 07:25 AM
Chattanooga, TN
Spector Offline
Spector  Offline
Chattanooga, TN
Are you saying it is overfilled by looking at the invoice and seeing 6 liters or by looking at the dipstick? Either way though I would not be concerned, a minor amount. If invoice they charged you for 6 but may have only put in 5.7.
Re: Oil Overfill [Re: Pelican] #4706102
03/25/18 07:26 AM
03/25/18 07:26 AM
NY
demarpaint Offline
demarpaint  Offline
NY
No problem at all.
God Bless Our Troops
Re: Oil Overfill [Re: Pelican] #4706103
03/25/18 07:27 AM
03/25/18 07:27 AM
The Midwest
skyactiv Offline
skyactiv  Offline
The Midwest
You can quickly check the oil after driving and if you see bubbles, air is causing foaming which is bad. Highly doubt that is happening with 10 ounces though. Don't worry about otherwise.
Me: 13' VW GTI 3 door 6 speed manual
Wanted: 2019 Ford Ranger
Re: Oil Overfill [Re: Pelican] #4706144
03/25/18 08:00 AM
03/25/18 08:00 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Not a problem whatsoever.
Many people add an entire quart/liter over with no ill effects.
Re: Oil Overfill [Re: Pelican] #4706165
03/25/18 08:21 AM
03/25/18 08:21 AM
Wet side WA
JohnnyJohnson Offline
Wet side WA
Well I'm a service oriented kind of guy I'd take it back to the Stealership and I'd let them fix it and I'd check it again before I drove off!
2004 Corolla 128335
Out: VML 5w-30 TG4967 OCI 5007 Miles
In: EDGE EP 5W-30 Bosch 3311 122537 7-18-18
2006 Duramax 74615
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: Oil Overfill [Re: Pelican] #4706168
03/25/18 08:24 AM
03/25/18 08:24 AM
USA
slacktide_bitog Offline
USA
There will be no problems smile
Re: Oil Overfill [Re: Linctex] #4706171
03/25/18 08:25 AM
03/25/18 08:25 AM
Champlain/Hudson Valley
Kira Offline
Kira  Offline
I'm actually surprised that there isn't a chart with various engines' "allowable overfills" being circulated about.
Even when "sloping driveways" were mentioned as design considerations no actual angles were ever given by the engine designers.
I guess you're OK with your slight overfill too.
Last oil change I measured my new oil volume EXACTLY and it's 1/8" over the FULL mark.
I drained 11.5 qts of oil from a neighbor's 2002 Audi 3.0l V6 (calls for 6l). THAT was overfilled....you should've seen the smoke!
Re: Oil Overfill [Re: Pelican] #4706190
03/25/18 08:45 AM
03/25/18 08:45 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Close the hood and forget it, 300ml isn't bothering anything.
Re: Oil Overfill [Re: Pelican] #4706199
03/25/18 08:52 AM
03/25/18 08:52 AM
Ottawa, Ont CANADA
2K2AcuraTL Offline
2K2AcuraTL  Offline
Ottawa, Ont CANADA
Drive on .. and sleep well..
02 Acura TL-P
13 Acura MDX-Elite
Both on PP and PP Ultra & Petro-Can Duradrive synth ATF
Re: Oil Overfill [Re: Pelican] #4706207
03/25/18 09:09 AM
03/25/18 09:09 AM
TX, USA
JMJNet Offline
JMJNet  Offline
TX, USA
In reality, they cannot charge you 0.7L so they round it up to the nearest whole amount.
I don't think they really overfill it.
Did you check the dipstick when you get home or whatever your next destination is?
By the way, there is also some error in the dipstick.
  • 2017 Toyota Sienna
Re: Oil Overfill [Re: Pelican] #4706209
03/25/18 09:13 AM
03/25/18 09:13 AM
Florida
SilverSnake Offline
SilverSnake  Offline
Florida
I never understand these threads on oil overfills. If it is overfilled and you are in the least bit concerned (and you must be since you started this thread), take it back to the dealer. A quick alternative, would be to pump out the overfilled amount with a dip stick pump. Cheap and easy to use. If that is not an option put the car up on ramps and drain enough out to get the level in the crosshatched area. If you take too much you can always add a little to adjust. All the dipsticks I have ever seen on any car or truck says "DO NOT OVERFILL." They don't say "Do Not Overfill Except for the Allowable Overfill." They do not say, "Don't Worry About Overfilling Just a Little Bit." They do not say, "Close the Hood and Forget It." I sleep well when the oil in my engines is within the safe zone on the dipstick.
2016 Charger, 6.4L-485 HP (PUP 0W-40)
2017 BMW 330i, 2L-248 HP (BMW 0W-20)
2018 Jeep GC, 5.7L-360 HP (PUP 5W-20)
2008 20KW Generac (Amsoil 10W-30/30)
Re: Oil Overfill [Re: Spector] #4706231
03/25/18 09:32 AM
03/25/18 09:32 AM
Thanks Spector, good point! On the invoice it says 6 litres, on the dipstick I can't tell, even though I looked in the morning after the car rested overnight I could not tell. Glad you confirm my feeling about not being concerned.
Re: Oil Overfill [Re: Pelican] #4706236
03/25/18 09:35 AM
03/25/18 09:35 AM
Thank you all for your advice, much appreciated.
Re: Oil Overfill [Re: Pelican] #4706237
03/25/18 09:39 AM
03/25/18 09:39 AM
OH
SatinSilver Offline
SatinSilver  Offline
OH
The Matrix has an updated dipstick that allows an extra half qt of oil in the engine compared to the old one. It even says so on the Amsoil site when you input the car's information. I was wondering why they were over filling it when I would supply the oil. They would return the jug with a half qt of oil and I was thinking there should a full qt remaining in the container. I thought they were being sloppy. Because if I bought four 5 qt jugs I'd be getting and extra oil change. Originally it had a four qt fill.
