'65 Mini.
by Silk. 03/19/19 02:08 AM
Our trash guy is getting on my nerves.
by Chris142. 03/19/19 01:20 AM
Ecogard trans filter
by pda1122. 03/19/19 12:11 AM
4.3 vortec issues
by mobilaltima. 03/18/19 09:17 PM
Recommendation for filter for Alfa Romeo 4C?
by phaphaphooey. 03/18/19 09:17 PM
What's the new wonder elixir?
by Yuk. 03/18/19 08:32 PM
Direct Injection Engines
by Al. 03/18/19 08:31 PM
Which mobil 1 for 19 versa?
by jahwarrior1423. 03/18/19 08:07 PM
RIP Dick Dale
by Donald. 03/18/19 08:06 PM
Found some rust on the roof of my car
by DreamerGT. 03/18/19 07:37 PM
What coolant would you run in a 1997 Dodge Ram?
by zfasts03. 03/18/19 07:11 PM
Is 10k miles too long for tire rotations?
by Nicasio. 03/18/19 06:47 PM
S-Oil Seven $14.88 on Amazon
by Nickdfresh. 03/18/19 06:41 PM
Power Steering Fluid - 07 Tahoe
by Plimbob. 03/18/19 06:38 PM
Oil / filter change 2015 Chevy Sonic 1.8l Automatic
by WyrTwister. 03/18/19 06:36 PM
drsoils, Gbear, MadMikesMech, Indyfordfan, toplscuda
67551 Registered Users
48 registered members (alcyon, Bailes1992, bcossa2001, Agnosto, Astro14, aleneros, 3 invisible), 645 guests, and 52 spiders.
Topics286,049
Posts4,901,492
Members67,551
Most Online2,967
Mar 10th, 2019
Page 1 of 5 1 2 5
'82 Ford 200 (3.3L) I6 - Front Main / Timing Cover #4682041
03/02/18 09:18 AM
03/02/18 09:18 AM
Texas, USA
WylieCoyote Offline OP
Texas, USA
Hey Guys,
I think I've finally found the source of the oil drip under my car, and I'm not sure I'm understanding the information I'm finding on seals for the front of the crankshaft. I'm finding two different seals (see attached). Is this right? Is there a seal in the block, and another in the timing cover? Everywhere I read on replacing the 'front seal' says it's done at the timing cover, but the parts information I'm finding contradicts this. Any help would be appreciated.
Re: '82 Ford 200 (3.3L) I6 - Front Main / Timing Cover [Re: WylieCoyote] #4682052
03/02/18 09:28 AM
03/02/18 09:28 AM
Lakeside, CA
Blkstanger Offline
Blkstanger  Offline
Lakeside, CA
Looks like the same seal, Just different brand options.
99 Jeep WJ 4.7 197,000 Maxlife 10w30, Fram Ultra.
Re: '82 Ford 200 (3.3L) I6 - Front Main / Timing Cover [Re: WylieCoyote] #4682055
03/02/18 09:33 AM
03/02/18 09:33 AM
Texas, USA
Texas, USA
I was hoping that was the case, but these seals are different widths.
Re: '82 Ford 200 (3.3L) I6 - Front Main / Timing Cover [Re: WylieCoyote] #4682059
03/02/18 09:37 AM
03/02/18 09:37 AM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
Generic advice follows. When I want to order parts or to look at the order parts go in. I search for an exploded diagram. If you have a 302, its an old Ford. Find a forum for the car and ask for advice. I've been on an E 28 forum since 2K. If somebody has a problem, we fix it on the interweb. grin2
Thick oil is better grin2
Re: '82 Ford 200 (3.3L) I6 - Front Main / Timing Cover [Re: WylieCoyote] #4682061
03/02/18 09:43 AM
03/02/18 09:43 AM
Texas, USA
Texas, USA
Yeah, I've been looking for conversations about this engine all morning. I keep finding people talking about their 1966 Mustangs with the I6, and their front main seal issues. I'v read through them, but am not giving them much credence, as I don't know if this engine was unchanged between 1966 and 1982. For all I know, they're not even related to each other. The 5.0 gets all the attention with this generation of Mustang, unfortunately. I could probably find 1,000 forum conversations about a front main seal on the V8.
Re: '82 Ford 200 (3.3L) I6 - Front Main / Timing Cover [Re: WylieCoyote] #4682196
03/02/18 12:11 PM
03/02/18 12:11 PM
Southeast
meep Offline
meep  Offline
Southeast
I think it's the same seal. the different outer dia is still just rubber which will compress ever so slightly. just my opinion. there should not be an inner and outer seal.
2018 F150
2015 crv (wifey!)
Re: '82 Ford 200 (3.3L) I6 - Front Main / Timing Cover [Re: WylieCoyote] #4682219
03/02/18 12:47 PM
03/02/18 12:47 PM
Texas, USA
Texas, USA
I was thinking it was odd to have two seals. Getting it fixed next week, tired of it decorating my driveway. Thanks everyone for the input.
Re: '82 Ford 200 (3.3L) I6 - Front Main / Timing Cover [Re: WylieCoyote] #4682316
03/02/18 02:25 PM
03/02/18 02:25 PM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
I've rarely seen a crankshaft seal leak, at least not that much. What I have seen leak a lot however is the oil pump seal to the block, especially if the timing cover is also the oil pump housing. Is that how it is arranged in this engine?
1994 BMW 530i, 241K
1996 Honda Accord, 267K
1999 Toyota Sienna, 409K
2000 Toyota ECHO, 280K
Re: '82 Ford 200 (3.3L) I6 - Front Main / Timing Cover [Re: WylieCoyote] #4682371
03/02/18 03:07 PM
03/02/18 03:07 PM
Texas, USA
Texas, USA
Here's what I keep finding regarding the oil pump
Re: '82 Ford 200 (3.3L) I6 - Front Main / Timing Cover [Re: WylieCoyote] #4683065
03/03/18 10:39 AM
03/03/18 10:39 AM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
I had to replace that seal on my 82 3.3L when I replaced the timing set. Also had to get a harmonic balancer from a boneyard because there was a bad groove worn in mine. Something to watch for.I only remember one "front" seal not two.
The "thinking" man's friend.
Re: '82 Ford 200 (3.3L) I6 - Front Main / Timing Cover [Re: WylieCoyote] #4683678
03/03/18 10:52 PM
03/03/18 10:52 PM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
blush Blindo here saw 3.2 as 302. ooops
Re: '82 Ford 200 (3.3L) I6 - Front Main / Timing Cover [Re: WylieCoyote] #4683791
03/04/18 07:04 AM
03/04/18 07:04 AM
dayton oh
kc8adu Offline
kc8adu  Offline
dayton oh
get the repair sleeve too.
otherwise its hit or miss on whether the new seal will ride in a different area of the balancer and avoid the groove worn into it.
Re: '82 Ford 200 (3.3L) I6 - Front Main / Timing Cover [Re: WylieCoyote] #4684943
03/05/18 10:02 AM
03/05/18 10:02 AM
Texas, USA
Texas, USA
Thanks for the tips everyone. Hoping this is the last issue for a while. Reality is starting to take hold that old cars are a rich man's hobby.
Re: '82 Ford 200 (3.3L) I6 - Front Main / Timing Cover [Re: WylieCoyote] #4685186
03/05/18 01:56 PM
03/05/18 01:56 PM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
If you have to get stuff like this repaired by pros, then, old cars aren't for you. Have you tried looking at Fairmont or Grenada sites?
Re: '82 Ford 200 (3.3L) I6 - Front Main / Timing Cover [Re: WylieCoyote] #4685223
03/05/18 02:29 PM
03/05/18 02:29 PM
Texas, USA
Texas, USA
Yeah, I'm getting the impression that if you don't have access to a lift, and don't have a 6-foot tall chest full of tools, and don't have a garage space you can dedicate to a week-long project, you've lost the battle.
I hate to give up and sell it, because it will likely be at a loss due to all the money I've poured in since purchase, but sometimes you have to draw a line and cut.
I haven't been on the Fairmount / Grenada sites, but have learned a bit from the Mustang sites and the 4-Eye / Foxbody groups on Facebook. But no matter how much I learn, I don't feel equipped to embark on projects of this size that can quickly escalate into more serious stuff. The engine has to be pulled to even work on the rear main seal, for instance. I'm not equipped for that.
We'll see how things go after the leak is fixed and they get the brand new A/C to work more than 3 days in a row.
Page 1 of 5 1 2 5
