Rust-Oleum Driveway Sealer review
by SVTCobra. 09/22/18 01:24 PM
Flush OAT/IAT mixture
by OpenClose. 09/22/18 12:20 PM
And They Say Spelling is Not Important.
by PimTac. 09/22/18 12:06 PM
Toyota Genuine oil 10W30
by gordond. 09/22/18 09:27 AM
Good Dealers
by HowAboutThis. 09/22/18 09:12 AM
electric brakes rely on heat to work?
by motor_oil_madman. 09/22/18 09:09 AM
help please 7.25 briggs idle too fast
by edwardh1. 09/22/18 08:49 AM
Java update and Flash not working
by JLTD. 09/22/18 08:47 AM
Bought a Giulia
by RamFan. 09/22/18 08:38 AM
by gordond. 09/22/18 08:37 AM
Mobil 1 Extended Protection High Mileage Test
by njohnson. 09/22/18 07:57 AM
WPA 3 Wireless Security Coming
by StevieC. 09/22/18 01:16 AM
Robo Calls/Telemarketers
by Nick1994. 09/22/18 12:47 AM
What oil should be used!
by BigShug681. 09/22/18 12:28 AM
VW Electronic Parking Brake
by StevieC. 09/21/18 11:48 PM
Leak Sealing and Mould Treatments?
by Ducked. 09/21/18 11:44 PM
UPS / FedEx / USPS
by StevieC. 09/21/18 11:21 PM
Sarrge, Big_R, gordond, mrgreggn, JRMFt11
66040 Registered Users
70 registered members (53' Stude, A310, 2013ecof150, 93cruiser, Ag76, 6 invisible), 1,871 guests, and 36 spiders.
Topics290,824
Posts4,851,057
Members66,040
Most Online3,590
Jan 24th, 2017
Dielectric grease for Toyota/Lexus coils #4675385
02/23/18 12:11 PM
02/23/18 12:11 PM
Albany, NY
ford46guy Offline OP
Albany, NY
I changed plugs in the Lexus and according to the service manual there is no mention of using any dielectric grease. I know Ford scares you about using it, like you car will explode if you don't. They even have a special product. I didn't use any grease and felt a bit guilty.
I asked a Toyota place on the way to work and a tech said it is not necessary and you are fine. He said the coil seal on the valve cover is more than enough. The coils slid right off the plugs, they must use a high quality rubber. I doubt any grease was used.
What are your opinions?
95 Tbird V8 240K PP SYNTH ULTRA 5W30
98 MGM 160K M1 HM 5W20
96 Explorer EB V6 159K PP SYNTH HM 5W30
95 Conti 155K MC 5W20
11 GS350 90K PP HM 5W30
Re: Dielectric grease for Toyota/Lexus coils [Re: ford46guy] #4675399
02/23/18 12:22 PM
02/23/18 12:22 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
In general I use it but on that engine its really not necessary. The boot on the plastic end is not deep and the seal is tight on the cover. Don't loose any sleep over it.
Re: Dielectric grease for Toyota/Lexus coils [Re: ford46guy] #4675426
02/23/18 12:53 PM
02/23/18 12:53 PM
The Northeast
mclasser Offline
mclasser  Offline
The Northeast
Some cars are worse about stuck coils than others. If you're really anal about it, get one of those $1 grease packets near the counter at AZ.
2018 Hyundai Elantra VE -- 4K
2013 Honda Pilot EX-L 4WD -- 56K
2002 Honda Accord EX-L -- 211K
Re: Dielectric grease for Toyota/Lexus coils [Re: ford46guy] #4675440
02/23/18 01:04 PM
02/23/18 01:04 PM
California
nthach Offline
nthach  Offline
California
I always use it - doesn't hurt or harm anything.
Re: Dielectric grease for Toyota/Lexus coils [Re: ford46guy] #4675468
02/23/18 01:37 PM
02/23/18 01:37 PM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
I use it all the time.
The "thinking" man's friend.
Re: Dielectric grease for Toyota/Lexus coils [Re: mclasser] #4675532
02/23/18 02:25 PM
02/23/18 02:25 PM
Albany, NY
Albany, NY
Got plenty of it, my concern was more if does more harm than good. Since the manual didn't specify, I didn't put it in. Not a big deal to pop the coils again, but I see it is not really necessary.
Re: Dielectric grease for Toyota/Lexus coils [Re: ford46guy] #4675585
02/23/18 03:17 PM
02/23/18 03:17 PM
NJ
Leo99 Offline
Leo99  Offline
NJ
I've been using it for about 10 years and found out last year that I've been using it all wrong. So, you could say I've not been using it. Never had a stuck coil or even one that took any effort to remove.
Without data you're just another person with an opinion. W. E. Deming
2003 Corolla 250,000 miles
2004 Rav4 359,000 miles
2015 Camry 59,000 miles
Re: Dielectric grease for Toyota/Lexus coils [Re: Leo99] #4675597
02/23/18 03:39 PM
02/23/18 03:39 PM
Albany, NY
Albany, NY
Yes, being "dielectric" it only goes on non conductive surfaces like rubber or ceramic. A very thin coat as well.
Re: Dielectric grease for Toyota/Lexus coils [Re: ford46guy] #4675612
02/23/18 03:56 PM
02/23/18 03:56 PM
NJ
Leo99 Offline
Leo99  Offline
NJ
I've been sticking it on the spark plug terminals.
Re: Dielectric grease for Toyota/Lexus coils [Re: ford46guy] #4675759
02/23/18 07:20 PM
02/23/18 07:20 PM
Alaska
AlaskaMike Offline
AlaskaMike  Offline
Alaska
Actually this is a common misconception. While it's normally only recommended for inside the rubber boots when used on spark plug wires, in pretty much every other electrical application it's always used on the conductive surfaces. In RF (radio) applications it's frequently used to fill coax connectors before they're threaded together for example.
In low voltage applications like trailer towing harness connectors, it's excellent for keeping moisture out of the connections. I've also seen it used in high voltage DC applications as well.
I use the stuff in any electrical connection that might be exposed to moisture, whether rain, condensation, or any other source.
Re: Dielectric grease for Toyota/Lexus coils [Re: ford46guy] #4676548
02/24/18 02:53 PM
02/24/18 02:53 PM
Trav Offline
Trav  Offline
No, you can put it on everything with it, I get some marine injectors that have the electrical connector packed full of it.
This is the boot he is talking about, it looks like a poly material and not very long.
As opposed to this rubber one that tends to stick to the plug or tear.
Re: Dielectric grease for Toyota/Lexus coils [Re: Trav] #4676661
02/24/18 04:27 PM
02/24/18 04:27 PM
Albany, NY
Albany, NY
Ford markets a special "low voltage terminal" grease that is different from the dielectric compound.
Re: Dielectric grease for Toyota/Lexus coils [Re: ford46guy] #4676700
02/24/18 05:02 PM
02/24/18 05:02 PM
Trav Offline
Trav  Offline
I guess their terminals are different from all the other makes. LOL There are different bulb and socket grease and Ox-Gard but I cant see any difference in performance.
It wouldn't surprise me if they had a super trunk latch spring lube made with black unicorn tears.
Re: Dielectric grease for Toyota/Lexus coils [Re: ford46guy] #4677049
02/24/18 10:55 PM
02/24/18 10:55 PM
Nokesville, VA
brianl703 Offline
brianl703  Offline
Nokesville, VA
The Ford grease is actually Nyogel 760G:
Re: Dielectric grease for Toyota/Lexus coils [Re: brianl703] #4677201
02/25/18 04:44 AM
02/25/18 04:44 AM
Trav Offline
Trav  Offline
From the description it sounds similar or may be even the same as Ox-Gard. Good for pre weather pack connectors where the wire going into the terminals are exposed and subject to corrosion.
