Greetings guys ~ Richard's the name ~ Journeyman Mechanic retired ``` I've used Bathroom tissue oil ~ Bypass Filters ~ since it/Frantz showed it ```
Couple years ago ~ I hooked one up to a Paint Pressure Tank ~ moved very dirty drain oil ~ through the filter ~ with my compressor ```
Well, I forgot about it ~ for couple years ~ daughter wanted one on her car ~ so I open up ~ cleaned it up ~ it had been sitting outside for a good while ~ have a look ```
Let me see now ~ the first picture is the bottom of the Tissue Filter ~ where oil leaves ~ to return to the engine ~ in this case ~ back to the Pressure Pot ``` Next is shown what is found in the 1 1/2" tube ~ that takes oil to the top ~ of the tissue roll ~ I installed this filter ~ without a puller ~ so I pulled it out with a pair of pliers ~ look couldn't get through the filter ~ glop and gunk ~ between my fingers ~ it felt like ~ grinding compound ``` That's what is in dirty oil ~ less if you change it often ~ but ```
The oil in the pot looks like honey ~ I could use it for lube in an oil can ```
I cleaned the filter body ~ and installed it on daughters car ~ I made a heavy wire puller ~ before installing in in her car ``` Any questions ```
Richard
Richard
