Here is a VOA of the 100% synthetic ester based Motul Gear 300 75w-90.
Motul specs are:
STANDARDS API GL4 and GL5 / MIL-L-2105D
Viscosity 75w-90
Viscosity @ 40C 72.6 cSt
Viscosity @ 100C 15.2 cSt
Viscosity Index 222
Flash point D92 200C / 392 F
Pour Point D97 -60C / -76 F
The info slip noted that this virgin sample was a 100% synthetic Motul Gear 300 product, a
75W/90 oil. It contained 1 ppm of aluminum and 2 ppm of lead. In addition to the normal group of oil
additives, it also contained 17 ppm of silicon, which is used as an additive in this product. We are not
sure why aluminum and lead showed up in this virgin sample of oil. The flashpoint was 395 degrees.
Viscosity was okay and no water or any insolubles were present in the sample. We think this oil would
be suitable for your needs.
Motul specs are:
Viscosity 75w-90
Viscosity Index 222
Blackstone Comments:code:
Gear 300 Universal Averages
Aluminum 1 0
Chromium 0 0
Iron 0 1
Copper 0 0
Lead 2 0
Tin 0 0
Molybdenum 0 0
Nickel 0 0
Manganese 0 0
Silver 0 0
Titanium 0 0
Potassium 0 0
Boron 499 171
Silicon 17 4
Sodium 0 2
Calcium 18 4
Magnesium 1051 150
Phosphorus 1629 1903
Zinc 5 5
Barium 0 0
Should be
SUS Viscosity @ 212 72.8 67-80
Flashpoint F 395 >405
Water % 0.0
Insolubles % 0.0
